Spectrum analysis (Fourier)
07-29-2015, 12:13 PM
Hello everyone,
let's suppose we have the following signal: f(t)=4+(4/pi)*sin(2*pi*800*t)+(4/(3*pi))*sin(2*pi*2400*t)+(4/(5*pi))*sin(2*pi*4000*t). Ok, this is the resulting waveform (time domain, 4 is the average value): ![]() Now the (banal) question is, how can I determine (i.e. to plot) the spectrum (in the frequency domain) of the function on the Prime, something like this below ? ![]() Any hint would be helpful. TIA and best, Aries |
07-30-2015, 02:29 AM
(This post was last modified: 07-30-2015 02:30 AM by Brad Barton.)
RE: Spectrum analysis (Fourier)
You're looking for the FFT (Fast Fourier Transform) algorithm. I'd give you more info, but I've loaned out the book I had for it. Google FFT, and you should be able to find what you're looking for.
There are some constraints, such as needing 2^n digitized samples and a couple other things, but it's definitely doable. |
08-12-2015, 11:52 AM
Thanks for your help, Brad, you're right, FFT algorithm is really what I was looking for and I've found it:
http://www.codeproject.com/Articles/9388...-algorithm Now I hope to succeed in implementing the Danielson-Lanzcos algorithm into the HP Prime. Best, Aries ;-) |
08-13-2015, 09:43 PM
(This post was last modified: 08-17-2015 07:16 PM by toshk.)
(i don't have Hp prime to try it.) but works on Emulator.
the App assumes that you place your signal function on F0(X). visualize your signal function (play with scales/auto zoom or whatever you want) for better representation of the signal. Type >>Spect>>Enter. PHP Code: #pragma mode( separator(.,;) integer(h32) ) |
08-14-2015, 08:48 AM
Thanks for your great app, toshk, very very kind of you, it's just what I was looking for and thanks for your great tools on control systems design and analysis (Bode, Nyquist and Nichols charts) too ;-)
What about Routh-Hurwitz and the root-locus methods ? Are you going to implement those on your future versions ? Happy August holidays, Aries ;-) |
08-14-2015, 09:37 AM
The posted code has a syntax error: H1:={'D2','D1','5'}; in the Set() procedure.
I think this is due to the use of H1 as a list variable, which is a global reserved variable of type real. -Dale- |
08-14-2015, 04:33 PM
(This post was last modified: 08-14-2015 04:36 PM by toshk.)
(08-14-2015 09:37 AM)DrD Wrote: The posted code has a syntax error: H1:={'D2','D1','5'}; in the Set() procedure.Open Statistics 1var Shift>>1 recompile the empty Statistics 1Var. and recompile my code too. |
08-14-2015, 05:06 PM
(08-14-2015 08:48 AM)Aries Wrote: Thanks for your great app, toshk, very very kind of you, it's just what I was looking for and thanks for your great tools on control systems design and analysis (Bode, Nyquist and Nichols charts) too ;-)My thoughts: For Root-Locus method i think Geometric App is a good candidate. but not animated enough to move points along a path. or move a set of conjugate pairs to its new locations. Also too many rules associated with this method...nevertheless if done on Matlab is doable on temperament Prime.(just less real estate screen). Roth-Hurwitz: i always wanted to implement that on prime...one of these days i will. i tend to use Ackermann's method (space vector) for calculating sensitivity gain K. |
08-14-2015, 05:46 PM
(08-14-2015 04:33 PM)toshk Wrote: Open Statistics 1var Hello, It is always a good idea to fully qualify your app functions - especially for something being shared. Statistics_1Var.H1 would work no matter where the user might be. TW Although I work for HP, the views and opinions I post here are my own. |
08-14-2015, 06:24 PM
(This post was last modified: 08-14-2015 06:42 PM by toshk.)
(08-14-2015 05:46 PM)Tim Wessman Wrote:(08-14-2015 04:33 PM)toshk Wrote: Open Statistics 1var Noted.....and fixed. Thanks. The code was meant for Spectrum(App) based on Statistics_2vars, then to be based on Statistics_1var and finally it striped it done to just app. Any chance to bring back fine(.) or fine dash(-) or tinnier version of the icons in Statistics_2var App? (real estate price is less attractive with is jumbo icons |
09-06-2015, 12:17 PM
(08-14-2015 05:06 PM)toshk Wrote:(08-14-2015 08:48 AM)Aries Wrote: Thanks for your great app, toshk, very very kind of you, it's just what I was looking for and thanks for your great tools on control systems design and analysis (Bode, Nyquist and Nichols charts) too ;-)My thoughts: Thanks toshk, great ideas and I'm looking forward to your updates ;-) Best, Aries :-) |
