Bug in (7820) - REDIM
06-04-2015, 04:51 PM
REDIM does not work in Home, but works in CAS. In the program can be used CAS.REDIM but it's slower than it should.
06-04-2015, 04:57 PM
RE: Bug in (7820) - REDIM
(06-04-2015 04:51 PM)slawek39 Wrote:  REDIM does not work in Home
Works fine here... REDIM(M1,{2,3}), REDIM(u1,5) etc
TW
06-04-2015, 05:04 PM (This post was last modified: 06-04-2015 05:08 PM by slawek39.)
It does not work:
[[1,2],[3,4]]->M1
REDIM(M1,{2,4})
The matrix is unchanged
06-04-2015, 05:28 PM
(06-04-2015 05:04 PM)slawek39 Wrote:
(06-04-2015 04:57 PM)Tim Wessman Wrote:  Works fine here... REDIM(M1,{2,3}), REDIM(u1,5) etc
It does not work:
[[1,2],[3,4]]->M1
REDIM(M1,{2,4})
Same here. Matrix unchanged.
06-04-2015, 06:37 PM
To clarify, REDIM doesn't work in HOME in RPN mode. Works ok in Textbook mode.
06-06-2015, 05:56 AM
(06-04-2015 06:37 PM)John Colvin Wrote:  To clarify, REDIM doesn't work in HOME in RPN mode. Works ok in Textbook mode.
Correction: REDIM does work in RPN mode, but you gotta use it with RPN syntax (because you're in RPN mode!). Example: 'M1' [Enter] {3,4} [Enter] REDIM [Enter]
<0|ΙΈ|0>
-Joe-
06-06-2015, 06:07 AM
(06-04-2015 05:28 PM)Francois Lanciault Wrote:
(06-04-2015 05:04 PM)slawek39 Wrote:  It does not work:
[[1,2],[3,4]]->M1
REDIM(M1,{2,4})
Same for me, whatever the mode (RPN, textbook or algebraic).
06-06-2015, 06:33 PM
I used the matrix template to create the matrix and then stored it in M1. Then I entered
'M1' and { 3, 4} and REDIM()--no change. Maybe something in the settings.
06-07-2015, 02:33 AM
Anyway, does appear to be an issue here. Its on the list to resolve. Thanks.
TW
