HP 82160A HP-il Interface looptest
11-26-2014, 05:02 PM
I purchased an HP82160A HP-IL Interface for my HP41CV. Unfortunately I have no other HP-IL gear at the moment, but like to test the Interface, if it works. Is there a short program example or even a built in "loop test". I appreciate any hints ... Best regards Ralf -- real: HP48SX, WP34S, WP31S, HP41CV on phone: go41cx, free42, droid48 |
11-27-2014, 01:51 AM
RE: HP 82160A HP-il Interface looptest
(11-26-2014 05:02 PM)workspace Wrote: Is there a short program example or even a built in "loop test". The command PWRUP or PWRDN should give you your loopback test. If the two wire are connected together, one of the above commands will not give you any feedback. If the two wire are disconnected or broken then the "TRANSMIT ERR" message will be displayed on the LCD. Best regards, Sylvain |
11-27-2014, 07:56 AM
Hi Sylvain,
thank you very much indeed. First I tried 01 LBL AAA 02 PWRUP which did not work, but a direct XEQ PWRUP worked perfect. Thanks and regards Ralf ps: Now I need get some HP-IL stuff ;-) -- real: HP48SX, WP34S, WP31S, HP41CV on phone: go41cx, free42, droid48 |
11-29-2014, 03:55 PM
(11-27-2014 07:56 AM)workspace Wrote: ps: Now I need get some HP-IL stuff ;-)Get a PIL box from J-F! Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
11-29-2014, 11:47 PM
(11-29-2014 03:55 PM)Marcus von Cube Wrote:(11-27-2014 07:56 AM)workspace Wrote: ps: Now I need get some HP-IL stuff ;-)Get a PIL box from J-F! 1+ For *ANY* HP-IL work, a PIL-Box (here) is absolutely essential and a real joy to use. Once you have that working, look closely at Christoph's Virtual HP-IL Extensions (here). Useful, easy to learn and use, and fun. --Bob Prosperi |
11-30-2014, 11:41 AM
.. actually I already started to read the documentation from J.F., the HP-IL reference specification and "Control the world with HP-IL"....
