Prime Key Font
08-05-2014, 10:24 PM (This post was last modified: 08-05-2014 10:26 PM by Tim Wessman.)
Prime Key Font
For those of you looking to make documents and such, here is the TTF font that was made to do so. I wanted to tweak the character mapping first before release to fix a few problems. It is quite good now and I think ready to let loose so to speak.
Here is the key mapping:
[attachment=986]
[attachment=987]
TW
10-10-2014, 08:02 PM
RE: Prime Key Font
Tim, is there a similar font file for the creation of menu items?
Graph 3D | QPI | SolveSys
10-12-2014, 08:47 PM (This post was last modified: 10-12-2014 08:56 PM by Tim Wessman.)
RE: Prime Key Font
No, there is not. It would be pretty much impossible to do. However, you can get a very nice look in the document simply by making the text white with black background.
What I probably should do is make it easier to get menu key graphics alone in the screenshot utility built into the emulator or connkit.
TW
10-13-2014, 01:38 AM
RE: Prime Key Font
Last font question: What is the font used in the HP Prime? Is that a freely available TTF as well? I vaguely remember you posting about it in the past but cannot seem to find the post.
10-13-2014, 02:08 AM (This post was last modified: 10-13-2014 02:08 AM by Tim Wessman.)
RE: Prime Key Font
Droid Sans family. The primary font is Droid Sans Fallback Full. Connkit should have a copy locally in the directory.
TW
11-12-2014, 07:31 PM
RE: Prime Key Font
Some of the characters in the HP Prime's font are different from the ones available freely on the net (e.g. J in Droid Sans and similar fonts dips below like the bottom portion of p or q). I don't suppose there is an HP-modified version you can distribute.
11-12-2014, 07:47 PM (This post was last modified: 11-12-2014 08:02 PM by Tim Wessman.)
RE: Prime Key Font
It is in the connkit install directory.
Also, for the future we'll be installing it on the system and so I renamed it and gave a new identifier to something like Prime Sans instead to avoid conflicts.
TW
