(42S) Subfactorial
09-06-2021, 04:43 PM
(42S) Subfactorial
This is a request by Marko Draisma and gratitude to Mr. Draisma.
Calculating the Subfactorial A common, and perhaps the most straight forward, formula to calculate the subfactorial is: !n = n! × Σ((-1)^k ÷ k!, k=0 to n) Yes, the subfactorial is written with the exclamation point first. The subfactorial finds all the possible arrangements of a set of objects where none of the objects end up in their original position. For example, when arranging the set {1, 2, 3, 4} the subfactorial counts sets such as {2, 1, 4, 3} and {3, 4, 1, 2} but not {1, 4, 3, 2}. For the positive integers: !n < n!. I am going to present two programs. The first will use the formula stated above. The second uses this formula, which will not require recursion or loops: !n = floor[ (e + 1/e) × n! ] - floor[ e × n! ] Note: Since the N! function on the DM42 accepts only positive integers, we can use the IP (integer part) to simulate the floor function. integer(x) = { floor(x) if x ≥ 0, ceiling(x) if x < 0 The following programs can be used on Free42, HP 42S, or Swiss Micros DM42. Version 1: The Traditional Route Registers used: R01: k, counter R02: sum register R03: n!, later !n Code: 01 LBL "!N" Version 2: Closed Formula I only put 2 in the label to distinguish the two programs. Code: 01 LBL "!N 2" Examples !4 = 9 !5 = 44 !9 = 133,496 Sources: "Calculus How To: Subfactorial" College Help Central, LLC .https://www.calculushowto.com/subfactorial/ Retrieved September 5, 2021. Weisstein, Eric W. "Subfactorial." From MathWorld--A Wolfram Web Resource. https://mathworld.wolfram.com/Subfactorial.html Retrieved September 5, 2021 Blog Link: http://edspi31415.blogspot.com/2021/09/s...orial.html |
09-06-2021, 06:50 PM
(This post was last modified: 09-06-2021 06:55 PM by John Keith.)
RE: (42S) Subfactorial
A simpler formula for the first program is a(n) = (n-1)*(a(n-1) + a(n-2)). Maybe not as easy to implement with a 4-level stack because you have to keep the two previous values to compute the current one.
The second formula can also be simplified to round(n!/e). More information and formulas at A000166. On Free42 or the DM42 you have over 30 digits of precision so your first program (either formula) will be exact for fairly large values of n. |
09-07-2021, 02:21 PM
(09-06-2021 06:50 PM)John Keith Wrote: A simpler formula for the first program is a(n) = (n-1)*(a(n-1) + a(n-2)). Maybe not as easy to implement with a 4-level stack because you have to keep the two previous values to compute the current one. We can use https://mathworld.wolfram.com/Subfactorial.html, #5 !n = n * !(n-1) + (-1)^n Code: def subfac(n, r=0): # integer n > 0 |
09-08-2021, 10:26 PM
(09-06-2021 06:50 PM)John Keith Wrote: The second formula can also be simplified to round(n!/e). More information and formulas at A000166. Another perspective is with n! numerator, n!/!n is best approximation for e With (n-1)! numerator, (n-1)!/!(n-1) is also best approximation for e Difference of two fraction should be as tiny as possible, but not zero. numer(n!/!n - (n-1)!/!(n-1)) = n! * !(n-1) - (n-1)! * !n = (n-1)! * (n * !(n-1) - !n) Minimizing numerator (but not zero), last term should be ±1 (depends on parity of n) !n = n * !(n-1) ± 1 With !1 = round(1!/e) = 0, !2 = round(2!/e) = 1, !2 = 2 * !1 + 1 !n = n * !(n-1) + (-1)^n |
09-09-2021, 07:24 AM
(09-07-2021 02:21 PM)Albert Chan Wrote:Shouldn't that be for i in range (2,n) ? Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE |
09-09-2021, 07:45 AM
(This post was last modified: 09-09-2021 07:46 AM by Werner.)
Code: 00 { 32-Byte Prgm } Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE |
09-09-2021, 12:31 PM
If you want to make the routine behave like N!, with the Free42 extensions, include his after FUNC 11
Code: 00 REAL? Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE |
09-09-2021, 03:33 PM
(09-09-2021 07:24 AM)Werner Wrote:(09-07-2021 02:21 PM)Albert Chan Wrote:Shouldn't that be No, Python use 0-based indexing, open-intervals. To loop from 2 to n, we need range(2, n+1) Mathematica have Subfactorial[n], but DIY is trivial, just nest (n+1) - 2 = n-1 times: In[1]:= subfac[n_] := Nest[{1+First[#], 1-Times@@#}&, {2,0}, n-1] // Last // Abs In[2]:= subfac[30] Out[2]= 97581073836835777732377428235481 In[3]:= Round[30!/E] Out[3]= 97581073836835777732377428235481 |
09-11-2021, 08:24 AM
(09-06-2021 04:43 PM)Eddie W. Shore Wrote: The subfactorial finds all the possible arrangements of a set of objects where none of the objects end up in their original position. I believe such arrangements are called "derangements" in combinatorics, so the subfactorial is the number of derangements. Great word! — Ian Abbott |
09-11-2021, 04:15 PM
(This post was last modified: 09-11-2021 04:40 PM by C.Ret.)
RE: (42S) Subfactorial on HP-15C
(09-06-2021 06:50 PM)John Keith Wrote: [...]The second formula can also be simplified to round(n!/e). More information and formulas at A000166. The round trick give me the idea for a short and fast code for my HP-15C : Quote:In[2]:= subfac[30] 30 f D compute !30 and f PREFIX display 97.58107385 E 30 these makes 9/10 digits are alright, fast and not bad for a truthfully Voyager oldie ! 5 f D display exactly 44, let verify the statistics : 12345 - 21345 - 31245 - 41235 - 51234 * 12354 - 21354 - 31254 * 41253 * 51243 - 12435 - 21435 - 31425 - 41325 - 51324 - 12453 - 21453 * 31452 * 41352 - 51342 - 12534 - 21534 * 31524 * 41523 * 51423 * 12543 - 21543 - 31542 - 41532 * 51432 * 13245 - 23145 - 32145 - 42135 - 52134 - 13254 - 23154 * 32154 - 42153 - 52143 - 13425 - 23415 - 32415 - 42315 - 52314 - 13452 - 23451 * 32451 - 42351 - 52341 - 13524 - 23514 * 32514 - 42513 - 52413 - 13542 - 23541 - 32541 - 42531 - 52431 - 14235 - 24135 - 34125 - 43125 - 53124 * 14253 - 24153 * 34152 * 43152 * 53142 - 14325 - 24315 - 34215 - 43215 - 53214 * 14352 - 24351 - 34251 * 43251 * 53241 - 14523 - 24513 * 34512 * 43512 * 53412 * 14532 - 24531 * 34521 * 43521 * 53421 * 15234 - 25134 * 35124 * 45123 * 54123 * 15243 - 25143 - 35142 - 45132 * 54132 * 15324 - 25314 - 35214 * 45213 * 54213 * 15342 - 25341 - 35241 - 45231 * 54231 * 15423 - 25413 * 35412 * 45312 - 54312 - 15432 - 25431 * 35421 * 45321 - 54321 - Total : 5! = 120 arrangements (- & *) !5 = 44 derangements ( * ) How the asterisk are randomly distributed makes me believe of un vrai dérangement. Couldn't Albert Chan please verify that with 30 elements, he exactly gets 97581073836835777732377428235481 asterisks (*) ? ![]() |
09-12-2021, 12:05 AM
(This post was last modified: 09-12-2021 12:25 AM by Gil.)
Dividing 30! by 2.718281828... (100 digits) gives
the following digits: 97581073836835777732377428235480.9687... The above rounded number is then correctly the one given in the previous post ending by 481. Regards, Gil |
09-12-2021, 12:46 PM
(09-12-2021 12:05 AM)Gil Wrote: Dividing 30! by 2.718281828... (100 digits) gives Thanks, Gil If we consider removed fractional part, (1-0.9687) = 0.0313 ≈ 0.970/31 Let P(n) = !n/n!, abs_error(P(30)) < 1/31! Consider only n-th element, probability of derangemnt = 1-1/n (i.e. n-th element cannot be at n-th place) To count derangements, we have to remove over-counted cases. Example: 12345 has all elements in the wrong spots. Recursively apply Inclusion Exclusion Principle to remove over-counts: P(n) = 1 - 1/1*(1 - 1/2*(1 - 1/3*( ... (1 - 1/(n-1)*(1-1/n))))) = 1 - 1 + 1/2! - 1/3! + 1/4! - ... + (-1)^n/n! 1/e = 1 - 1 + 1/2! - 1/3! + 1/4! - ... + (-1)^n/n! + (-1)^(n+1)/(n+1)! + ... With alternate signs, abs_error( P(n)-1/e ) < 1/(n+1)! → abs_error( !n - n!/e ) < 1/(n+1) For n≥1, 1/(n+1) ≤ 1/2 : !n = round(n!/e) |
