First python project : HP41 emulator + hints of workflow
05-25-2021, 11:04 AM (This post was last modified: 05-25-2021 11:10 AM by ggauny@live.fr.)
RE: First python project : HP41 emulator + hints of workflow
here same issue with little thing more : green dashes as you can see on attachement. And sometime not good on terminal as attachement 2.
On 41c. And on G2.
Gérard.
05-25-2021, 06:39 PM (This post was last modified: 05-26-2021 07:13 AM by Oulan.)
(05-25-2021 11:04 AM)ggauny@live.fr Wrote:  Hi,
On 41c. And on G2.
The 3 hexs numbers are the 3 first levels of the cpu return stack, just an hint for debugging key mapping, you can forget it ... see infos() function in nut.py, just remove all the lines and add pass:
  def infos(self,c):
    pass
The size of the text is the default text size of the UI of the prime (I use medium, it seems that you use large, so the redraw bugs). Actually I didn't find an easy way to set the text size from python (perhaps some hpprime.eval('xx') can do the trick).
05-26-2021, 08:10 AM
Hi Olivier,
Ok, thanks.
Gérard.
05-26-2021, 09:38 AM (This post was last modified: 05-26-2021 09:47 AM by Oulan.)
Next release : py41d at the same link :
You can swap SQRT and SQR and 1/X and y^x with:
L:132  (-_inv,  _KF,  _KF,  _KF,  _q6,  _KF,  _KF,    0),  # x^y     F
L:139  (-_sqx,  _KL,  _KL,  _KL,  _KL,    0,  _KL,    0),  # x²      L
Just add 2 '-' in key.py at lines 132 and 139 to toggle SHIFT at keypress
Olivier
05-26-2021, 02:19 PM
Just to follow up on my previous post. Py41b works on g1. Py41c and Py41d do not. I've tried changing config.py to restrict number modules loaded but it didn't help. Heap:1024 and Stack:40000 memory 12.34MB
Maybe hp team can comment on what's the issue here.? It would be great if this excellent program would work on g1 as it evolves!
06-03-2021, 09:00 AM
Great job Olivier!
Could you please take into account the color theme when in dark mode?
Thanks a lot.
06-04-2021, 02:01 PM
(06-03-2021 09:00 AM)Massimo Gnerucci Wrote:  Great job Olivier!
Thanks a lot.
New py41e version at link
Now can import/export raw files
06-04-2021, 04:29 PM
Thanks a lot.
What a service!
Thank you very much Olivier.
06-04-2021, 04:40 PM
Just another thing I just discovered: BST doesn't get NULLed when kept pressed.
06-05-2021, 10:14 AM
(06-04-2021 04:40 PM)Massimo Gnerucci Wrote:  Just another thing I just discovered: BST doesn't get NULLed when kept pressed.
That is the normal behavior of a real HP 41.
So the emulator do the same.
06-05-2021, 01:03 PM
Ooops, shame on me!
I stand corrected. Sorry.
06-05-2021, 06:53 PM
And thanks for the update of go41cx!
06-06-2021, 09:14 AM
Hello Olivier,
I'm wondering if you will give us a user manual ?
For example, how to call a program and execute it or else. I have some problem to do this, maybe it was too helpfull for others followers.
Good sunday !
Gérard.
06-07-2021, 06:14 AM
(06-06-2021 09:14 AM)ggauny@live.fr Wrote:  Hello Olivier,
Good sunday !
About the HP41 calculator, your can find informations at LINK, LINK or at LINK.
For the emulator part, you have now a picture of the keymap at LINK.
06-07-2021, 12:31 PM
An online version of the 41C manual is available here.
06-07-2021, 03:25 PM (This post was last modified: 06-07-2021 03:42 PM by ggauny@live.fr.)
Thank you all, but I've already all this texts and my own french manuals HP 41C and HP41CX. I was thinking little manual *How to do* as with Warren Furlow emulator, we can clic on the screen to have possibility *Get User Code*, *Save User Code* for example, load *MOD* for card reader and so on you see ?
But I've enjoy your super great emulator on my Primes !
Gérard.
06-10-2021, 01:44 AM (This post was last modified: 06-10-2021 02:11 AM by Liamtoh Resu.)
here is a link for the:
HP-41C OPERATING MANUAL A Guide for the Experienced User
"https://web.archive.org/web/20180104042855/http://www.decadecounter.com/vta/pdf/HP%2041C%20Operating%20Manual.pdf"
It is a 17mb download, 74 pages and text search is not enabled.
other links:
http://www.jeffcalc.hp41.eu/hpplus/files/techrefman.pdf
hp41 related sites
http://www.jeffcalc.hp41.eu/emu41/index.html
http://www.*****/Intro.cfm
note: It is quite a jump for me from using the hp35 in 1975 to
optaining a hp33s by chance at Walmart. I missed alot of
hp calculators along the way. I now have the 33s, 50g, 35s, and the prime g2.
Thanks.
06-10-2021, 07:48 PM
(06-10-2021 01:44 AM)Liamtoh Resu Wrote:  here is a link for the:
There is a search-enabled version on Eric Rechlin's HP Calculator Literature page.
— Ian Abbott
06-10-2021, 09:20 PM
A question about the hp41c emulator:
Does any one have a recommendation for which 41c/41cv/41cx document
to start with for someone who has never used a hp41c calculator?
I like the idea of having two calculators in one!
Thanks.
06-11-2021, 12:12 AM
(06-10-2021 09:20 PM)Liamtoh Resu Wrote:  A question about the hp41c emulator:
Thanks.
I would recommend the original HP-41C Owner's Handbook and Programming Guide. It assumes you know nothing about HP calculators and is a great example of the friendly, well written calculator manuals that HP used to write.
https://literature.hpcalc.org/community/...hpg-en.pdf
