Update of ILPilbox to v1.4
06-17-2014, 09:07 PM
ILPilbox v1.4 is a performance update. The speed with the loop controller on the real HP-IL side remain stable, but the transfer speed with the controller on the Virtual HP-IL side (i.e. Emu71/Win) had been increased between 10%-50% to version 1.3. 10% were measured on a very fast multi core host system, whereas the 50% were measured on a slow host system with a P4/3.2GHz.
The update is available at http://hp.giesselink.com/hpil.htm.
The absolute speed depends on various factors like the performance of the host PC, the PIL-Box firmware, the devices attached on HP-IL bus, ...
ILPilbox with PIL-BOX CON
ILPilbox v1.3:    3.85 -> 448 bytes/s
ILPilbox v1.4:    3.16 -> 546 bytes/s
ILPer direct over COM-Port
xxx:2        2.61 -> 661 bytes/s
xxx TO :3    2.25 -> 722 bytes/s
ILPilbox v1.3 with PIL-BOX COFF
xxx:2        3.05 -> 565 bytes/s
xxx TO :3    2.61 -> 661 bytes/s
ILPilbox v1.4 with PIL-BOX COFF
xxx:2        2.93 -> 588 bytes/s
06-17-2014, 10:20 PM
RE: Update of ILPilbox to v1.4
I was just about to try a JPC ROM file to real 71B transfer. It should come in handy.
Thanks, Christoph.
Dave
06-18-2014, 01:04 PM
(06-17-2014 09:07 PM)Christoph Giesselink Wrote:  ILPilbox v1.4 is a performance update.
I just dropped it into my setup with multiple ILPer instances running on local PC and everything is OK. I have not done any performance testing, but all has worked perfectly.
Thanks Christoph!
