Queen Board
09-28-2020, 10:58 PM
Queen Board
Does anyone have a copy of this program from the HP19c/29C applications book. The one I have from my Museum flash drive is missing steps 48 and 49.
cheers
Tony
09-28-2020, 11:42 PM
RE: Queen Board
From my copy (same source) the lines are visible:
48: 5
49: -
Maybe that copy of the file is damaged, or maybe I don't misunderstand your request?
09-29-2020, 12:10 AM (This post was last modified: 09-29-2020 12:10 AM by teenix.)
RE: Queen Board
Thanks,
I have on Page 53...
45  ST+1
46  RCL1
47  RTN
50 RTN (at top of next column)
51 *LBL 0
cheers
Tony
09-29-2020, 01:15 AM
RE: Queen Board
My bad, without the exact page, I was looking at the prior program in the Queen Board Chapter.
I have 2 original copies of this manual, and they are not only different from what you've described, they are also different from each other.
The first manual, which appears to be the same as the version in the MoHPC scan (same covers, inside title page, etc.), includes line 48:
44 1
45 ST+1
46 RCL1
47 RTN
48 *LBL 7
Test for good position
51 *LBL 0
but no line 49, although the comment for that line is visible (as it is in the MoHPC copy).
The 2nd copy I have is marked on the back cover "5955-2111 Rev. B 9/77"
This copy gets it right:
44 1
45 ST+1
46 RCL1
47 RTN
48 *LBL 7
49 RCL2 Test for good position
51 *LBL 0
Quite an interesting find, thanks for that Tony.
09-29-2020, 02:15 AM (This post was last modified: 09-29-2020 03:55 AM by teenix.)
RE: Queen Board
Hi Bob,
Thanks.
Sorry I meant only line 49 was missing and replaced with your code and now it works :-)
All good now, I had a few problems with others but after some fiddling they work too.
cheers
Tony
09-29-2020, 11:18 AM
RE: Queen Board
from my 'errata' archives: data & full source unreferenced with doc
HP-19C/29C Programming Problems
The Queen Board game on pp. 52-54 of the applications book will work if you add step 49 "RCL 2", and change step 79 "GT09" to"GT05".
Bob Miller
BEST!
SlideRule
09-29-2020, 12:26 PM (This post was last modified: 09-29-2020 12:29 PM by teenix.)
RE: Queen Board
(09-29-2020 11:18 AM)SlideRule Wrote:  from my 'errata' archives: data & full source unreferenced with doc
Bob Miller
BEST!
SlideRule
Updated, thanks for the help :-)
cheers
Tony
