HP-35s complex numbers in polar mode
05-17-2020, 10:04 PM
I bought myself a new HP-35s this winter (2020).
I have a problem with keying in complex numbers i polar mode.
That is when the |absolute value| is a result of an operation,
or if [enter] i pressed just before [blue-shift] [i] [value] [ENTER]
- RPN modus.
- Polar modus
- Emptying the stack. [blue-shift][CLEAR][STK][ENTER]
Example:
[2] [sqrt] [blue-shift] [i] [45] [ENTER]
This gives an error message: SYNTAX ERROR.
Example:
[0.41] [ENTER] [1] [+] [blue-shift] [i] [45] [ENTER]
Example:
[2] [ENTER] [blue-shift] [i] [45] [ENTER]
So my question is. How shall I key in the following?:
|sqrt{2}| r{45} (that is 1+i1)
Best regards, Kjetil
05-18-2020, 08:07 AM
RE: HP-35s complex numbers in polar mode
[sqrt] is an operation key, not a number entry key.
You could enter the number as two numbers and multiply them together:
2
[sqrt]
1Θ45
[x]
Or enter the approximate value of sqrt(2) as part of the number:
1.41421356237Θ45
[enter]
Or just enter it in rectangular form since you already know it:
1i1
[enter]
— Ian Abbott
05-18-2020, 09:20 AM
The Θ key is made to enter inline values in polar mode, ex: 1.414Θ0.7
I like this answer from ijabbott :
(05-18-2020 08:07 AM)ijabbott Wrote:  2
[sqrt]
1Θ45
[x]
I also suggest using the RAD mode and entering the number in the exponential form (r.e^(iΘ)):
[pi]
[4]
[i]
[e^x]
[2]
[SQRT]
05-18-2020, 09:21 AM
Ian Abbott,
Thanks a lot for your prompt response.
I like Your first solution that multiplying the “real” number (2 [sqrt]) with 1Θ45.
But when it comes to the two latter solution, I am not able to see those as answers to my question.
I should of course explicitly stated that my example, «keeing in» √2Θ45, was meant as a part of a larger calculation.
Again, thanks a lot for taking your time.
05-18-2020, 09:55 AM
Pinkman
Thanks a lot for Your comments!
Using exponential form (r e^(iΘ)) was interesting. – It is of course due to my limited math skills, but I have to look into Your suggestion more closely.
05-18-2020, 12:36 PM
Thanks to both for Your help. This is, as far as I could see, the right solution:
2 [√] 1 [Θ] 45 [×]
By the way; on my old HP-42S, (in polar mode), I could just press:
2 [√] 45 [COMPLEX]
05-18-2020, 06:15 PM
We all wished the 35s was a 42s...
But it’s a good calculator and you could add a small program to create the same function.
C001 LBL C
C002 ENTER
C003 SIN
C004 i
C005 x
C006 x<>y
C007 COS
C008 +
C009 x
C010 RTN
Usage:
2
[SQRT]
45
XEQ C
[Enter]
I used the z = r(i.sinΘ+ cosΘ) form to handle deg or rad modes. Unfortunately there is no flag giving the polar or rectangular mode, otherwise we could have simulated the whole behavior of the 42s.
Thibault
