NumWorks firmware version 13/ß14 2020
03-28-2020, 06:50 PM (This post was last modified: 06-03-2020 02:49 AM by compsystems.)
version 13.x More info
https://tiplanet.org/forum/viewtopic.php...32#p252132
03-28-2020, 07:27 PM
RE: NumWorks firmware version 13.1 March 2020
(03-28-2020 06:50 PM)compsystems Wrote:  More info
They finally fixed the Python input command. Yay!
Tom L
Cui bono?
03-30-2020, 05:43 PM
(03-28-2020 07:27 PM)toml_12953 Wrote:  They finally fixed the Python input command. Yay!
Tom, what was the problem with the input command?
03-31-2020, 02:06 AM
Here's an example:
>>> a=input('x? ')
x? 62
>>>print(a)
666put('x? ')
Tom L
Cui bono?
03-31-2020, 08:34 AM
Number of the Beast
Everything will be alright in the end. If it's not alright, then it's not the end.
04-01-2020, 04:01 PM
13.2
Mathplotlib https://tiplanet.org/forum/viewtopic.php...ba#p252187
04-01-2020, 09:21 PM
(03-31-2020 02:06 AM)toml_12953 Wrote:
(03-30-2020 05:43 PM)Don Shepherd Wrote:  Tom, what was the problem with the input command?
Here's an example:
>>> a=input('x? ')
x? 62
>>>print(a)
666put('x? ')
Thanks Tom. I just received my Numworks calc today and have been playing with it. Entering:
a=input('x? ')
62
print(a)
directly into the Python shell on the calc was a frustrating experience, trying to do shift lock as required and not finding the single quote on the keyboard at all (I found it under the toolbox key). I can now see the value of writing Python scripts on the computer (Chromebook in my case) and uploading. And I see the output 62 instead of the 666 stuff.
Thanks for the info you provided. I'm looking forward to learning both Python and the Numworks calculator.
04-02-2020, 02:42 AM
(04-01-2020 04:01 PM)compsystems Wrote:  13.2
Yes! A great release that also gives more memory for Python.
Tom L
Cui bono?
06-03-2020, 02:48 AM (This post was last modified: 06-03-2020 02:36 PM by compsystems.)
ß14.x
https://tiplanet.org/forum/viewtopic.php...3f#p253519
[Image: image.php?mode=thumbnail&image_id=12531]
06-03-2020, 06:09 AM
RE: NumWorks firmware version 13/ß14 2020
Picture too small: can't read a thing. Tongue
