(41C) Pythagorean Triples
10-15-2019, 12:57 PM
(This post was last modified: 10-15-2019 03:20 PM by SlideRule.)
An extract from PROGRAMMABLE CALCULATORS Implications for the Mathematics Curriculum, Clearinghouse for Science, Mathematics and Environmental Education, Ohio State University, December 1980
"Independent Study with a Programmable Calculator … pg. 49 … The following material is an excerpt from Mathematical Recreations for the Programmable Calculator (Mohler and Hoffman, 1981) a collection of programming problems designed to teach the standard techniques of programming … Pythagorean Triples … pg. 50 … Write a program which searches out and finds all Pythagorean triples … PYTR Program for the HP-41C … pg. 77 … Parts of the extract are difficult to read BUT the HP-41C program listing is only slightly fuzzy near the bottom of the listing. BEST! SlideRule |
06-25-2022, 03:40 PM
(This post was last modified: 06-25-2022 03:52 PM by Thomas Klemm.)
RE: (41C) Pythagorean Triples
On page 26 we find:
Quote:Our calculators used Reverse Polish Notation, which is a great convenience and posed no difficulty to the children. No one in this forum is surprised by that. I picked the problem to print primitive Pythagorean triples. Here's a program for the HP-42S: Code: 00 { 99-Byte Prgm } # Example 12 XEQ "PPT" 3 4 5 5 12 13 15 8 17 7 24 25 21 20 29 9 40 41 35 12 37 11 60 61 45 28 53 33 56 65 13 84 85 63 16 65 55 48 73 39 80 89 15 112 113 77 36 85 65 72 97 17 144 145 99 20 101 91 60 109 51 140 149 19 180 181 117 44 125 105 88 137 85 132 157 57 176 185 21 220 221 143 24 145 119 120 169 95 168 193 23 264 265 Make sure to SF 21 and hit R/S to get to the next triple. The program is based on the following Python program: Code: def primitive(m): References |
06-26-2022, 09:29 AM
(This post was last modified: 06-26-2022 01:53 PM by C.Ret.)
(06-25-2022 03:40 PM)Thomas Klemm Wrote: But it should also work with the HP-41C after the obvious transformations. As usual, Thomas Klemm produces an excellent algorithm. I particularly like how the GCD determination is efficiently incorporated into the code. So I grabbed my HP-41C and its trusty 82240A to make the obvious transformations needed to aim and print: 01 LBL"PYTH" 02 STO 04 XEQ 04 04 LBL 01 05 RCL 04 STO 05 07 LBL 00 08 DSE 05 XEQ 02 DSE 05 GTO 00 12 DSE 04 GTO 01 14 GTO 04 15 LBL 02 16 RCL 04 RCL 05 18 LBL 03 19 STO Z MOD X≠0? GTO 03 23 10^X X≠Y? RTN 26 + CLA 28 RCL 04 ARCL X "┝," ST* Y X^2 STO Z 34 RCL 05 ARCL X ACA ST* Z X^2 ST+ T 40 - FMT ACX RDN ACX RDN ACX 47 LBL 04 48 ADV 49 END Shorter than the original code, this one just displays triples in a different order. |
06-27-2022, 05:51 AM
With obvious transformations, I thought more of something like: STO+ ST X \(\mapsto\) ST+ X.
Thanks for improving my program. Using DSE instead of ISG avoids the calculation of the index. Also by using it twice in a row we still use a step size of 2: Code: 07 LBL 00 I should have remembered that with STO Z we also have tuck ~ swap over: Code: 18 LBL 03 I would probably rather use SIGN instead of 10^X to map \(0 \mapsto 1\) but its nice to add both \(1 + 1 = 2\) and use the result as a factor when calculating \(2 \cdot m \cdot n\) in the following steps: Code: 23 10^X X≠Y? RTN I wasn't aware of FMT or probably just forgot about it. It makes for a nice listing: Code: 40 - FMT ACX RDN ACX RDN ACX Well done! |
06-29-2022, 01:02 PM
very timely: https://www.youtube.com/watch?v=QJYmyhnaaek
Great visual content for math, love that channel/ |
07-01-2022, 11:55 AM
(06-29-2022 01:02 PM)Ángel Martin Wrote: very timely: https://www.youtube.com/watch?v=QJYmyhnaaek That was a great video, thanks for posting! Additionally, Berggren's method does not require GCD and is pretty fast and simple on any calculator that can handle matrices. It generates all primitive triples but in a different order than the complex squaring method. |
07-03-2022, 08:18 AM
(This post was last modified: 07-03-2022 02:06 PM by C.Ret.)
(07-01-2022 11:55 AM)John Keith Wrote: Additionally, Berggren's method does not require GCD and is pretty fast and simple on any calculator that can handle matrices. It generates all primitive triples but in a different order than the complex squaring method. Thanks for pointing out this method which easily produces tons of primary Pythagorean triples using a very simple recursive program on an advanced calculator natively manipulating vectors and matrices: PYT: « 1 + [[ 1 2 2 ][ 2 1 2 ][ 2 2 3]] → T n M \(T=\left[a_0,b_0,c_0 \right]\) « " " 1 n 2 * SUB T →STR + PR1 STR→ IF n N < THEN M T 2 DUP2 GET NEG PUT * n PYT \(\left[a_1,b_1,c_1\right]=\begin{bmatrix}1&-2&2\\2&-1&2\\2&-2&3\\\end{bmatrix}\times \left [ a_0,b_0,c_0 \right ]=\begin{bmatrix}1&2&2\\2&1&2\\2&2&3\\\end{bmatrix}\times \left [ a_0,-b_0,c_0 \right ]\) M T * n PYT \(\left[a_2,b_2,c_2\right]=\begin{bmatrix}1&2&2\\2&1&2\\2&2&3\\\end{bmatrix}\times \left [ a_0,b_0,c_0 \right ]\) M T 1 DUP2 GET NEG PUT * n PYT \(\left[a_3,b_3,c_3\right]=\begin{bmatrix}-1&2&2\\-2&1&2\\-2&2&3\\\end{bmatrix}\times \left [ a_0,b_0,c_0 \right ]=\begin{bmatrix}1&2&2\\2&1&2\\2&2&3\\\end{bmatrix}\times \left [ -a_0,b_0,c_0 \right ]\) END » » Store max depth into N register: 4 'N' STO Set printer online, aim to it and print by typing: [ 3 4 5 ] 0 PYT |
07-03-2022, 10:46 AM
RE: (41C) Pythagorean Triples | |||
07-03-2022, 01:41 PM
(07-03-2022 10:46 AM)Thomas Klemm Wrote:(07-03-2022 08:18 AM)C.Ret Wrote: using a very simple recursive program on an advanced calculator natively manipulating vectors and matricesDo you mind posting the program? Sorry, as I posted this morning, I was so caught up in my attempt to come up with a version for HP-41, that I completely forgot to post the code for HP-28S. Tonight, after a day full of other Sunday activities, my version for HP-41 is still not finalized. I believe I will revise the way I support recurring calls as well as matrix products in my HP-41C. |
07-03-2022, 01:55 PM
(07-03-2022 08:18 AM)C.Ret Wrote: PYT: That's a great program! I'm glad you posted it before I posted my sad attempt. ![]() |
