TI-59 Magnetis Card difference
03-16-2019, 05:15 PM
I have a bunch of TI59 magnetic cards for programs that looks different from each other, one having arrows to indicated side number and other with no arrows and a darker colour.
Does anybody know the difference between them?
I searched everywhere and did not find anything.
The only difference I could find is that the one with arrows I could write and read and the other I could write, but not read.
Thanks in advance
JL
03-16-2019, 11:53 PM (This post was last modified: 03-24-2019 11:14 PM by SlideRule.)
RE: TI-59 Magnetis Card difference
Perhaps a silly question but are the non-read cards you refer to the plastic only cards for with the plug in ROM's?
SlideRule
03-17-2019, 02:44 AM
(03-16-2019 05:15 PM)Jlouis Wrote:  Hi,
Thanks in advance
JL
The dark ones that are shiny on the back are for the TI-58 which has no card reader. They're only to label the function keys for programs you enter manually.
Tom L
I don't care for whom you voted. If you put ice in your beer, you're crazy.
03-17-2019, 03:02 AM
(03-16-2019 11:53 PM)SlideRule Wrote:  Perhaps a silly question but are the non-read cards you refer to the plastic only cards for the plug in ROM's?
SlideRule
No, they have a magnetic strip. I can record a program, the calculator shows 1 at the end.
03-17-2019, 03:04 AM
Thanks in advance
JL
No, these ones are from thicker paper. They don't pass on the card reader.
I will take a picture or look for one in internet.
Thanks anyway.
03-17-2019, 03:07 AM (This post was last modified: 03-17-2019 03:09 AM by Jlouis.)
Look like this
See attachment
03-17-2019, 01:36 PM
I am not an expert on TI at all here, but to me it seems that the cards on the left side was made for the SR-52 and the one on right side was made for the TI-59.
03-17-2019, 06:41 PM
Nope, that's not it, Sylvain. :-)
The SR-52 cards look like this:
SR-52 showing cards
I think those are versions of the TI-59 cards, but I don't recall seeing them without the arrows.
03-17-2019, 07:15 PM
(03-17-2019 06:41 PM)Gene Wrote:  The SR-52 cards look like this:...
Yes, but these are pre-programmed cards (I have some of those). But what do blank SR-52 cards look like? I have yet to see one.
Max
NB: The ones with the arrows are definitely Ti-59.
[Image: images?q=tbn:ANd9GcR8he73WsXHYjKgzSkc4gx...0mXdfMzEgj]
03-17-2019, 08:36 PM (This post was last modified: 03-17-2019 08:37 PM by Dieter.)
(03-17-2019 07:15 PM)Maximilian Hohmann Wrote:  NB: The ones with the arrows are definitely Ti-59.
?!? – the card in the picture looks different from both card types in the wallet.
May it be possible that this is some third-party stuff? In the Eighties I bought a pack of 120 cards for the HP-41. They looks similar, but not intentical to genuine HP cards: it looks like the blackmarkings have been printed over.
Dieter
03-17-2019, 09:31 PM
Dieter
Yes Dieter, the cards in picture looks like white, and mine loois like the picture above.
I tend to agree with you about the cards without arrows is a third party and lower quality.
03-17-2019, 11:36 PM
(03-17-2019 06:41 PM)Gene Wrote:  Nope, that's not it, Sylvain. :-)
I stand corrected Gene. Smile Thank you!
03-18-2019, 02:14 AM (This post was last modified: 03-18-2019 02:15 AM by Gene.)
Sylvain, that may turn out to be the ONLY time I ever have that distinction. You are an incredible source of knowledge. :-)
Here's another picture. Top LEFT card is a blank SR-52 card. It is not a pre-recorded card.
Card
03-18-2019, 03:57 PM
Hi!
(03-18-2019 02:14 AM)Gene Wrote:  Here's another picture. Top LEFT card is a blank SR-52 card. It is not a pre-recorded card.
Card
That looks really different from Ti-59 Blank cards.
In the meantime I found some of the "mystery" sepia coloured blank cards from the photo above in one of my calculator heaps. They were in a card wallet that came with a Ti-58. So my guess is that they are not magnetic, but just plastic cards that you can use to remember which label you assigned to your programmed function.
Max
03-18-2019, 05:17 PM
Jlouis said that this is not the case:
(03-17-2019 03:02 AM)Jlouis Wrote:  No, they have a magnetic strip. I can record a program, the calculator shows 1 at the end.
However, I wonder if this "1" really is a sure sign of a correctly recorded card track. Maybe the calculator displays this although no data have been written.
The TI-59 experts here will know more.
Dieter
03-18-2019, 10:04 PM (This post was last modified: 03-18-2019 10:06 PM by Jlouis.)
Dieter
Yes, the 1 indicates the card was written in bank 1.
I just recorded a program in bank 2, the result after the recording is 2.
Attached is a picture of two of my cards, with and without arrows.
03-18-2019, 10:19 PM
(03-18-2019 10:04 PM)Jlouis Wrote:  Yes, the 1 indicates the card was written in bank 1.
Have you been successful to load back those programs into the calculator? I just eperimented with the arrowless card and it does not record anything. The one with the arrows works, so it is not the calculator.
Max
03-18-2019, 11:12 PM
Max
No, when reading the calculator return a blinking 2 digits number, and acc the manual it is error reading.
03-18-2019, 11:28 PM
The magnetic side of the two cards are different. One is darker than the other.
Jeez, I find nothing in the internet!
Never mind, I will only work with the arrow one.
The problem is that I am liking the TI-59. What's going on with me?
I think I need to see a doctor! Smile
03-19-2019, 12:05 AM
Well, the manual says there are arrows in the card, which let me assume that or I have an aftermarket product or the card reader is fooling me indicating that the card was recorded.
Thank you very much to all of you that have helped me.
JL
