HP 50g — import statistical data into hypothesis test
12-08-2018, 11:34 PM
RE: HP 50g — import statistical data into hypothesis test
(12-08-2018 10:52 PM)DavidM Wrote:  That's where the magic happens. The ST2 program is run, which outputs (in order) x1, x2, s1, s2, n1, n2. These values are then automatically inserted into their corresponding fields in the form. You are then free to enter whatever you like for α and "pooled?" to continue.
oh! That is absolutely marvellous, thanks very much indeed Smile
yes, works perfectly. No need to reach for the Prime and its Import function any more Smile
thanks again, great stuff.
Noted re caveats.
Cambridge, UK
41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot
Casio, Rockwell 18R
12-08-2018, 11:47 PM
(12-08-2018 10:52 PM)DavidM Wrote:  - I have no idea if the dimensions of this sample ΣDAT are correct for this type of application
Strictly speaking there is no need for the sample sizes to be the same for a Student's t-test, I think, but if you had different sizes samples you'd not be able to deal with them together in ΣDAT, anyway (e.g. the MTWR will insert a 0 for an empty element), so in that case you'd have to do it entirely differently.
In my case, the samples are generally the same size, so your method works perfectly, thanks again.
Cambridge, UK
Casio, Rockwell 18R
