modular exponentiation?
06-25-2018, 04:31 PM (This post was last modified: 06-25-2018 04:44 PM by Thomas Klemm.)
RE: modular exponentiation?
Finally a solution for Java that might be accepted:
Map Reduce
import java.math.BigInteger;
import java.util.stream.IntStream;
public class SumModPow {
    private static final BigInteger M = BigInteger.valueOf(10).pow(10);
    public static void main(String[] args) {
        System.out.println(
            IntStream.rangeClosed(1, 1000)
                .mapToObj(n -> {
                    BigInteger m = BigInteger.valueOf(n);
                    return m.modPow(m, M);
                .reduce(BigInteger.ZERO, BigInteger::add)
                .mod(M)
Parallel Streams
With this small change we can run the calculation in parallel:
        System.out.println(
                .parallel() // add this line
                .mapToObj(n -> {
                .mod(M)
This would not be possible using a classic for-loop.
Will it be faster on a MacBook with 4 cores?
Guess what: it makes it even a bit slower.
These are the results for the real time of 20 runs:
Sequential
         0.2200 ####
         0.2300 #####
         0.2400 #######
         0.2500 #
         0.2600 ##
               0        10
min      =          0.2130
max      =          0.2690
mean     =          0.2388
sigma    =          0.0130
mode     =          0.2400
median   =          0.2385
Parallel
         0.2400 #########
         0.2500 ########
         0.2600 ##
               0        10
min      =          0.2360
max      =          0.2620
mean     =          0.2498
sigma    =          0.0074
mode     =          0.2400
median   =          0.2490
We have to increase the upper limit to 10000000 to notice the difference:
Sequential
real    0m35.134s
user    0m36.712s
sys    0m0.298s
Parallel
real    0m17.546s
user    0m56.692s
sys    0m0.420s
During this run the CPU was used up to 350% by this program:
  PID USER      PRI  NI  VIRT   RES S CPU% MEM%   TIME+  Command
32002 tom         0   0  9.6G  253M ? 341.  1.5  0:44.54 /usr/bin/java -cp parallel-10000000 SumModPow
That's why the real-time is smaller than the user-time.
Premature Optimization
Quote:Programmers waste enormous amounts of time thinking about, or worrying about, the speed of noncritical parts of their programs, and these attempts at efficiency actually have a strong negative impact when debugging and maintenance are considered.
We should forget about small efficiencies, say about 97% of the time:
premature optimization is the root of all evil.
Yet we should not pass up our opportunities in that critical 3%.
-- Donald Knuth
My Python program above runs in about 0.045s.
It's not1 optimised but doing so wouldn't gain that much.
It took me much longer to write the Java program.
And today the biggest cost is our time. Not only the time that you spend to implement a piece of code. But also the time you or others must spend debugging and maintaining your code.
Contrary to what others might think I consider this a reasonable interview question.
Because it could lead the discussion into different directions.
[1]: Ok, it's a bit optimized in that instead of a list-comprehension (using []) the corresponding generator (using ()) is used. Thus not the whole list has to be kept im memory. Instead summation and producing the arguments can be interleaved. But even this doesn't change much.
06-25-2018, 05:42 PM (This post was last modified: 06-25-2018 05:44 PM by StephenG1CMZ.)
(06-25-2018 02:44 AM)Thomas Okken Wrote:
(06-25-2018 02:04 AM)brickviking Wrote:  Man, am I glad I've never tried to apply for a professional programmer's job. I've never even heard of binary multiplication chains. I've certainly heard of powers-of-two multiplication by bit-shifting though. I don't know if this is the same thing, nor would I have any idea how to apply that to the OP.
It's not the same thing. The idea is that, for example,
a^10 = (a^5)^2 = (a*a^4)^2 = (a*(a^2)^2)^2
meaning: you can compute integral powers by a sequence of multiplications and squares. This is more efficient than a sequence of multiplications; the repeated-squaring approach takes O(log n) operations, as opposed to n-1 multiplications for the simplistic approach.
Is this the kind of knowledge that you would require a job applicant to have, where you would toss their application in the trash if they don't implement an integral power this way? I doubt it. I've never been asked this kind of question in a job interview (and I am a programmer, not a scientist or engineer who dabbles in programming). The only time in my life where knowing the repeated-squaring algorithm was useful to me was when I implemented Y^X in Free42.
Your mileage may vary. Smile
(06-25-2018 02:04 AM)brickviking Wrote:  I'm a bit lost as to what modular exponentiation is, too. I guess I haven't been kicking around the maths courses long enough.
Taking something to the power of something, and then taking the remainder of that, modulo something else. When the exponents get large, this requires clever algorithms to get accurate results. Again, not something programmers tend to encounter. Mathematicians, maybe, but anyone else? Seems like a weird interview topic to me, for any job that isn't pure mathematics.
(06-25-2018 02:04 AM)brickviking Wrote:  (Post 249)
I have to ask: why do you do that? Smile
Oops: New Reply is inserting a Quote!
I too would have flunked that math test...
My A level math covered modular arithmetic and exponentiation, but it was too long ago to remember them ever being combined.
The straightforward for loop has the advantage of clarity and easily predictable performance (assuming an average execution time for each loop), whereas the mathematical shortcut relies on memory of a trick - and is harder to test for errors if your memory lets you down.
Back at the start of my software engineering career, I don't remember doing well on any math algorithms in interviews, but in the job itselfI did implement a 100% performance gain in a sqrt function. The trick there was to choose a good guess for the initial root.
I also implemented DSP software in assembler, which I understood well enough to code and test - but couldn't begin to talk about in interviews (apart from explaining the code, rather than the math)
Stephen Lewkowicz (G1CMZ)
06-25-2018, 10:09 PM
(06-24-2018 09:08 PM)Valentin Albillo Wrote:  3) Actually, I've been sometimes in charge of selecting programmers to hire and if I were to pose this same question to the people applying for the job and some of them would produce code which computed the integer powers N^N by performing N multiplications in a loop, both their code and their application would've been thrown to the garbage bin at once, for being so utterly inefficient.
I'd choose people who are resourceful, even if they don't know every algorithm off by heart. I've been programming professionally for 34 years and never had any reason to use modular exponentiation, let alone implement it efficiently. (If I specialized in cryptography, it would be a different matter!). I only really discovered the fast binary algorithm for modular exponentiation through solving challenges on HackerRank, since I figured there probably had to be a faster than O(n) algorithm so I went looking on Wikipedia to find it.
— Ian Abbott
06-25-2018, 10:21 PM
It's a post counter, and I use it to give me a rough idea of what threads I visited and what order I replied in. It also lets me know how many posts I've actually made on a particular forum; although most forums now have a handy post counter nearby the username, some older forums don't (i.e. the good old newsgroup days).
And besides, it makes a great conversation starter. Or at least a puzzler. You're not the first to ask me, and I'll be willing to be you won't be the last. Smile
Now, let's see if I've got a rough idea of the mathematical concept behind this.
(Post \( 3^3*3^2+2^2+3\))
Regards, BrickViking
06-25-2018, 10:45 PM
I'm with you on that. I didn't know what "modular exponentiation" was myself. I just intuitively knew what I wanted, did "man dc" and found the phrase there.. Wink
My colleague was just looking for someone that could "think" and basically know how to get there..
Cheers!
06-28-2018, 12:42 AM
(06-24-2018 09:18 AM)Didier Lachieze Wrote:  On the HP Prime in CAS mode:
\[\LARGE irem( \sum_{n=1}^{1000} (powmod(n,n,10^{10})), 10^{10})\]
or, if you want to copy/paste to the emulator:
irem(Σ(powmod(n,n,10^10),n,1,1000),10^10)
Wow, almost instantaneous!
My HP 50 version,
\<< PUSH CASDIR MODULO \-> m
  \<< 10 DUP ^ MODSTO 0 1 1000
    FOR n n DUP POWMOD
      IF DUP 0 <
      THEN MODULO +
      END +
    NEXT MODULO MOD m MODSTO POP
is rather slow and clunky due to the HP 50's quirky POWMOD function. It takes about 130 seconds to run, or about 2.5 seconds on the emulator.
06-28-2018, 06:07 PM
(06-28-2018 12:42 AM)John Keith Wrote:  My HP 50 version,
    FOR n n DUP POWMOD
      IF DUP 0 <
      THEN MODULO +
      END +
I wonder why POWMOD is so slow? Does it do POW followed by MOD?
— Ian Abbott
06-28-2018, 09:40 PM
(06-28-2018 06:07 PM)ijabbott Wrote:  I wonder why POWMOD is so slow? Does it do POW followed by MOD?
No, it works in the usual way but it is more primitive than the Prime's version, thus requiring the check for negative values. Also integer comparisons are very slow for some reason. About 20 seconds of that run time is taken by the < function.
Additionally, the prime is almost 100 * as fast as the HP 50 which accounts for most of the difference. Smile
06-28-2018, 09:56 PM
(06-28-2018 09:40 PM)John Keith Wrote:  Also integer comparisons are very slow for some reason. About 20 seconds of that run time is taken by the < function.
You could probably just ditch the following:
IF DUP 0 <
THEN MODULO +
END
I have no HP 50g thus I can't verify my assumption.
But the final MODULO MOD should take care of possible negative values.
06-29-2018, 12:47 AM
(06-28-2018 09:56 PM)Thomas Klemm Wrote:  You could probably just ditch the following:
IF DUP 0 <
THEN MODULO +
END
You're right, it returns the correct value in 93.4 seconds without the test clause.
07-08-2018, 09:50 PM
Has anyone written a POWMOD -like function for the HP-48? Just wondering before I go off and try it myself..
07-09-2018, 02:32 AM
(07-08-2018 09:50 PM)Bill Duncan Wrote:  Has anyone written a POWMOD -like function for the HP-48? Just wondering before I go off and try it myself..
There's a "Fast Powering algorithm f exponentiation (mod n)" program called PWR in Anthony Shaw's "MODULO" package for the 48: https://www.hpcalc.org/details/6015
<0|ɸ|0>
-Joe-
07-09-2018, 05:18 AM
Cf. Modular Arithmetic for the HP-48
Since PLUS is only used by TIMES it can be inlined.
And then you can keep TIMES in a local variable leading to:
@POWER ( a b n -- a ^ b % n )
« @TIMES ( a b n -- a * b % n )
  « 1000000 → a b n k
    « a k / IP a k MOD
      b k / IP b k MOD
      → x y u v
      « x u * k SQ *
        x v * k *
        y u * k *
        y v *
        4 →LIST
        n MOD
        @PLUS ( a b -- a + b (mod n) )
        « → a b
          « a b +
            IF n OVER ≤
            THEN DROP a n - b +
            END
        STREAM
  → n TIMES
  « 1 ROT ROT
    WHILE DUP
    REPEAT → r a b
      « IF b 2 MOD
        THEN a r n TIMES EVAL @ r → a * r (mod n)
        ELSE r
        END
        a DUP n TIMES EVAL @ a → a ^ 2 (mod n)
        b 2 / IP
    END
    DROP2
(07-09-2018 02:32 AM)Joe Horn Wrote:  There's a "Fast Powering algorithm f exponentiation (mod n)" program called PWR in Anthony Shaw's "MODULO" package for the 48: https://www.hpcalc.org/details/6015
Quote:MODPND
Returns a (mod n). This function assumes that a and n have been entered using the # symbol, which allows for large integers (up to about 10^18). By using MODPND in PRODN, numbers whose product do not exceed 10^18 can be multiplied (mod n). If these programs were implemented in machine language, larger integer arithmetic could be made feasible. For me, small numbers have plenty of interesting properties, so I'm not so concerned about this.
#9876543210987654
#1234567890123456 ---> #90000006
Thus I assume that it will work only up to 109.
Quote:Just wondering before I go off and try it myself.
Just go for it! And post your result.
07-09-2018, 09:55 AM
Here's a POWMOD programme for the 38G:
http://www.hpmuseum.org/forum/thread-338...ght=modulo
07-09-2018, 01:37 PM
(03-15-2015 08:22 AM)Gerald H Wrote:  The programme MMOD finds
X * H MOD M.
MMOD
X MOD 1000000►I:
X-Ans►X:
H MOD 1000000►J:
H-Ans:
((X*Ans MOD M+((X*J MOD M+I*Ans MOD -M)
MOD -M))MOD -M+I*J )MOD M►X:
Stealing this idea I reduced the TIMES program:
  « 1000000 → a b n k
    « a k MOD a OVER -
      b k MOD b OVER -
      → y x v u
      « x u * n NEG MOD
        x v * n MOD
        + n NEG MOD
        y u * n MOD
        + n NEG MOD
        y v *
        + n MOD
  → n TIMES
  « 1 ROT ROT
    WHILE DUP
    REPEAT → r a b
      « IF b 2 MOD
        ELSE r
        END
        b 2 / IP
    END
    DROP2
Thanks to Gerald and kind regards
10-26-2018, 06:08 PM
I just want to mention, that my favorite HP-16C is also able to solve the original problem.
With the modular exponentiation function, which I presenetd in this thread http://www.hpmuseum.org/forum/thread-11674.html in the "General Software Library", it is possible to compute the last (up to) 18 digits of \(\Bigg(\sum_{n=1}^{1000} n^{n} \bmod 10^{10}\Bigg) \bmod 10^{10}\) very easily.
There is only one smal problem left: The computation lasts for about 8 hours.
Best regards
Hartmut
10-26-2018, 07:37 PM
(10-26-2018 06:08 PM)wynen Wrote:  There is only one smal problem left: The computation lasts for about 8 hours.
Wow. I'd hate to see a big problem.... Smile
10-27-2018, 12:24 AM
Here is a poor man's version, using old luajit 1.18
No 64-bits integer (only 53-bits float), no built-in powmod ...
PHP Code:
function powmod1e10(x,y)            -- x^1e10
if == 1 then return x end     -- assumed 0 <= 1e10
    local p
math.floor(y/2)
local t powmod1e10(xp)
local b 1e5               -- last 5 digits
    t
= (2*b) * 1e10        -- t*1e10
if == p+p then return t end
if <= 9e5 then return 1e10 end
    b
1e5                     -- odd ybig x
return ((x-b) * (t%1e5) + b*t) % 1e10
end
PHP Code:
function modsum(n)                  -- sum(i^ii=1..n) % 1e10
    local t
0
for 1,do = (powmod1e10(ii)) % 1e10 end
return t
end
Some benchmark from my 20 years old Pentium 3:
modsum(1e3) ==> 9110846700 (0.00 seconds)
modsum(1e4) ==> 6237204500 (0.04 seconds)
modsum(1e5) ==> 3031782500 (0.57 seconds)
modsum(1e6) ==> 4077562500 (7.10 seconds)
10-27-2018, 05:46 AM (This post was last modified: 10-27-2018 05:51 AM by Ángel Martin.)
(06-25-2018 03:43 PM)Thomas Okken Wrote:
(06-25-2018 02:49 PM)Bill Duncan Wrote:  When did this forum get so serious?
AFAIK, it's a place that we can share ideas, pass on a little knowledge, learn new things and most of all, have some fun!
So seriously, let's get back to having fun with the friendly exchange of ideas in the forum?
I honestly have no clue what you are complaining about. Sure, sometimes discussions get heated and even name-calling may happen... but I see no trace of anything like that in this thread. Where do you think we went wrong?
I for one understand Bill's sentiments. More often than none there's a certain Damocles sword pending over always ready to be let loose. So I too claim the right to goof up.
Modular exponentiation, of all things is a tricky one to grasp - more so if you had no exposure to Modular math. Thank you Thomas for your informative responses and clarifications, I'm sure that helped may folks.
Cheers,
ÁM
"To live or die by your own sword one must first learn to wield it apply."
10-27-2018, 05:55 AM (This post was last modified: 10-27-2018 05:56 AM by Ángel Martin.)
(10-26-2018 06:08 PM)wynen Wrote:  I just want to mention, that my favorite HP-16C is also able to solve the original problem.
This picked my curiosity: I'm going to try running your program on V41 Turbo mode, using the 16C Simulator Module... will keep you all posted
