Incorrect Constants
02-02-2018, 04:12 AM
Incorrect Constants
I see that corrected constants haven't made it into the newest firmware (mmHg, cal, inH2O for example)
Tom L
Cui bono?
02-02-2018, 05:20 AM
RE: Incorrect Constants
TW
Although I work for the HP calculator group, the views and opinions I post here are my own.
02-02-2018, 06:48 AM
I guess this refers to CAS constants. If someone want to have them updated, please correct the code below:
  // fundemental metric units
  const mksa_unit __m_unit={1,1,0,0,0,0,0,0,0};
  const mksa_unit __kg_unit={1,0,1,0,0,0,0,0,0};
  const mksa_unit __s_unit={1,0,0,1,0,0,0,0,0};
  const mksa_unit __A_unit={1,0,0,0,1,0,0,0,0};
  const mksa_unit __K_unit={1,0,0,0,0,1,0,0,0};
  const mksa_unit __mol_unit={1,0,0,0,0,0,1,0,0};
  const mksa_unit __cd_unit={1,0,0,0,0,0,0,1,0};
  const mksa_unit __E_unit={1,0,0,0,0,0,0,0,1};
  const mksa_unit __Bq_unit={1,0,0,-1,0,0,0,0,0};
  const mksa_unit __C_unit={1,0,0,1,1,0,0,0,0};
  const mksa_unit __F_unit={1,-2,-1,4,2,0,0,0,0};
  const mksa_unit __Gy_unit={1,2,0,-2,0,0,0,0,0};
  const mksa_unit __H_unit={1,2,1,-2,-2,0,0,0,0};
  const mksa_unit __Hz_unit={1,0,0,-1,0,0,0,0,0};
  const mksa_unit __J_unit={1,2,1,-2,0,0,0,0,0};
  const mksa_unit __mho_unit={1,-2,-1,3,2,0,0,0,0};
  const mksa_unit __N_unit={1,1,1,-2,0,0,0,0,0};
  const mksa_unit __Ohm_unit={1,2,1,-3,-2,0,0,0,0};
  const mksa_unit __Pa_unit={1,-1,1,-2,0,0,0,0,0};
  const mksa_unit __rad_unit={1,0,0,0,0,0,0,0,0};
  const mksa_unit __S_unit={1,-2,-1,3,2,0,0,0,0};
  const mksa_unit __Sv_unit={1,2,0,-2,0,0,0,0,0};
  const mksa_unit __T_unit={1,0,1,-2,-1,0,0,0,0};
  const mksa_unit __V_unit={1,2,1,-3,-1,0,0,0,0};
  const mksa_unit __W_unit={1,2,1,-3,0,0,0,0,0};
  const mksa_unit __Wb_unit={1,2,1,-2,-1,0,0,0,0};
  vecteur & usual_units(){
    static vecteur * usual_units_ptr=0;
    if (!usual_units_ptr){
      usual_units_ptr=new vecteur;
      *usual_units_ptr=mergevecteur(
                   mergevecteur(makevecteur(_C_unit,_F_unit,_Gy_unit,_H_unit,_Hz_unit,_J_unit,​_mho_unit),
                        makevecteur(_N_unit,_Ohm_unit,_Pa_unit,_rad_unit,_S_unit,_Sv_unit,_T_unit))​,
                   makevecteur(_V_unit,_W_unit,_Wb_unit)
    return *usual_units_ptr;
  const mksa_unit __Angstrom_unit={1e-10,1,0,0,0,0,0,0,0};
  const mksa_unit __Btu_unit={1055.05585262,2,1,-2,0,0,0,0,0};
  const mksa_unit __Curie_unit={3.7e10,0,0,-1,0,0,0,0,0};
  const mksa_unit __FF_unit={.152449017237,0,0,0,0,0,0,0,1};
  const mksa_unit __Fdy_unit={96485.3365,0,0,1,1,0,0,0,0};
  const mksa_unit __Gal={0.01,1,0,-2,0,0,0,0,0};
  const mksa_unit __HFCC_unit={1400,1,0,0,0,0,0,0,0};
  const mksa_unit __L_unit={0.001,3,0,0,0,0,0,0,0};
  const mksa_unit __P_unit={.1,-1,1,-1,0,0,0,0,0};
  const mksa_unit __R_unit={0.000258,0,-1,1,1,0,0,0,0};
  const mksa_unit __Rankine_unit={5./9,0,0,0,0,1,0,0,0};
  const mksa_unit __St_unit={0.0001,2,0,-1,0,0,0,0,0};
  const mksa_unit __Wh_unit={3600,2,1,-2,0,0,0,0,0};
  const mksa_unit __a_unit={100,2,0,0,0,0,0,0,0};
  const mksa_unit __acre_unit={4046.87260987,2,0,0,0,0,0,0,0};
  const mksa_unit __arcmin_unit={2.90888208666e-4,0,0,0,0,0,0,0,0};
  const mksa_unit __arcs_unit={4.8481368111e-6,0,0,0,0,0,0,0,0};
  const mksa_unit __atm_unit={101325.0,-1,1,-2,0,0,0,0,0};
  const mksa_unit __au_unit={1.495979e11,1,0,0,0,0,0,0,0};
  const mksa_unit __b_unit={1e-28,2,0,0,0,0,0,0,0};
  const mksa_unit __bar_unit={1e5,-1,1,-2,0,0,0,0,0};
  const mksa_unit __bbl_unit={.158987294928,3,0,0,0,0,0,0,0};
  const mksa_unit __bblep_unit={.158987294928*0.857*41.76e9,2,1,-2,0,0,0,0,0};
  const mksa_unit __boe_unit={.158987294928*0.857*41.76e9,2,1,-2,0,0,0,0,0};
  const mksa_unit __bu={0.036368736,3,0,0,0,0,0,0,0};
  const mksa_unit __buUS={0.03523907,3,0,0,0,0,0,0,0};
  const mksa_unit __cal_unit={4.1868,2,1,-2,0,0,0,0,0};
  const mksa_unit __cf_unit={1.08e6,2,1,-2,0,0,0,0,0};
  const mksa_unit __chain_unit={20.1168402337,1,0,0,0,0,0,0,0};
  const mksa_unit __ct_unit={0.0002,0,1,0,0,0,0,0,0};
  const mksa_unit __dB_unit={1,0,0,0,0,0,0,0,0};
  const mksa_unit __d_unit={86400,0,0,1,0,0,0,0,0};
  const mksa_unit __deg_unit={1.74532925199e-2,0,0,0,0,0,0,0,0};
  // const mksa_unit __degreeF_unit={5./9,0,0,0,0,1,0,0,0};
  const mksa_unit __dyn_unit={1e-5,1,1,-2,0,0,0,0,0};
  const mksa_unit __eV_unit={1.60217733e-19,2,1,-2,0,0,0,0,0};
  const mksa_unit __erg_unit={1e-7,2,1,-2,0,0,0,0,0};
  const mksa_unit __fath_unit={1.82880365761,1,0,0,0,0,0,0,0};
  const mksa_unit __fbm_unit={0.002359737216,3,0,0,0,0,0,0,0};
  const mksa_unit __fc_unit={10.7639104167,1,0,0,0,0,0,0,0};
  const mksa_unit __fermi_unit={1e-15,1,0,0,0,0,0,0,0};
  const mksa_unit __flam_unit={3.42625909964,-2,0,0,0,0,0,1,0};
  const mksa_unit __fm_unit={1.82880365761,1,0,0,0,0,0,0,0};
  const mksa_unit __ft_unit={0.3048,1,0,0,0,0,0,0,0};
  const mksa_unit __ftUS_unit={0.304800609601,1,0,0,0,0,0,0,0};
  const mksa_unit __g_unit={1e-3,0,1,0,0,0,0,0,0};
  const mksa_unit __galC_unit={0.00454609,3,0,0,0,0,0,0,0};
  const mksa_unit __galUK_unit={0.004546092,3,0,0,0,0,0,0,0};
  const mksa_unit __galUS_unit={0.003785411784,3,0,0,0,0,0,0,0};
  const mksa_unit __cu_unit={0.000236588236373,3,0,0,0,0,0,0,0};
  const mksa_unit __gf_unit={0.00980665,1,1,-2,0,0,0,0,0};
  const mksa_unit __gmol_unit={1,0,0,0,0,0,1,0,0};
  const mksa_unit __gon_unit={1.57079632679e-2,0,0,0,0,0,0,0};
  const mksa_unit __grad_unit={1.57079632679e-2,0,0,0,0,0,0,0,0};
  const mksa_unit __grain_unit={0.00006479891,0,1,0,0,0,0,0,0};
  const mksa_unit __h_unit={3600,0,0,1,0,0,0,0,0};
  const mksa_unit __ha_unit={10000,2,0,0,0,0,0,0,0};
  const mksa_unit __hp_unit={745.699871582,2,1,-3,0,0,0,0,0};
  const mksa_unit __in_unit={0.0254,1,0,0,0,0,0,0,0};
  const mksa_unit __inH2O_unit={248.84,-1,1,-2,0,0,0,0,0};
  const mksa_unit __inHg_unit={3386.38815789,-1,1,-2,0,0,0,0,0};
  const mksa_unit __j_unit={86400,0,0,1,0,0,0,0,0};
  const mksa_unit __kip_unit={4448.22161526,1,1,-2,0,0,0,0,0};
  const mksa_unit __knot_unit={0.51444444444,1,0,-1,0,0,0,0,0};
  const mksa_unit __kph_unit={0.2777777777777,1,0,-1,0,0,0,0,0};
  const mksa_unit __l_unit={0.001,3,0,0,0,0,0,0,0};
  const mksa_unit __lam_unit={3183.09886184,-2,0,0,0,0,0,1,0};
  const mksa_unit __lb_unit={0.45359237,0,1,0,0,0,0,0,0};
  const mksa_unit __lbf_unit={4.44922161526,1,1,-2,0,0,0,0,0};
  const mksa_unit __lbmol_unit={453.59237,0,0,0,0,0,1,0,0};
  const mksa_unit __lbt_unit={0.3732417216,0,1,0,0,0,0,0,0};
  const mksa_unit __lep_unit={0.857*41.76e6,2,1,-2,0,0,0,0,0};
  const mksa_unit __liqpt_unit={0.000473176473,3,0,0,0,0,0,0,0};
  const mksa_unit __lyr_unit={9.46052840488e15,1,0,0,0,0,0,0,0};
  const mksa_unit __mi_unit={1609.344,1,0,0,0,0,0,0,0};
  const mksa_unit __miUS_unit={1609.34721869,1,0,0,0,0,0,0,0};
  const mksa_unit __mil_unit={0.0000254,1,0,0,0,0,0,0,0};
  const mksa_unit __mile_unit={1609.344,1,0,0,0,0,0,0,0};
  const mksa_unit __mille_unit={1852,1,0,0,0,0,0,0,0};
  const mksa_unit __mn_unit={60,0,0,1,0,0,0,0,0};
  const mksa_unit __mmHg_unit={133.322368421,-1,1,-2,0,0,0,0,0};
  const mksa_unit __molK_unit={1,0,0,0,0,1,1,0,0};
  const mksa_unit __mph_unit={0.44704,1,0,-1,0,0,0,0,0};
  const mksa_unit __nmi_unit={1852,1,0,0,0,0,0,0,0};
  const mksa_unit __oz_unit={0.028349523125,0,1,0,0,0,0,0,0};
  const mksa_unit __ozUK_unit={2.8413075e-5,3,0,0,0,0,0,0,0};
  const mksa_unit __ozfl_unit={2.95735295625e-5,3,0,0,0,0,0,0,0};
  const mksa_unit __ozt_unit={0.0311034768,0,1,0,0,0,0,0,0};
  const mksa_unit __pc_unit={3.08567818585e16,1,0,0,0,0,0,0,0};
  const mksa_unit __pdl_unit={0.138254954376,1,1,-2,0,0,0,0,0};
  const mksa_unit __pk_unit={0.0088097675,3,0,0,0,0,0,0,0};
  const mksa_unit __psi_unit={6894.75729317,-1,1,-2,0,0,0,0,0};
  const mksa_unit __pt_unit={0.000473176473,3,0,0,0,0,0,0,0};
  const mksa_unit __ptUK_unit={0.0005682615,3,0,0,0,0,0,0,0};
  const mksa_unit __qt_unit={0.000946359246,3,0,0,0,0,0,0,0};
  const mksa_unit __rd_unit={0.01,2,0,-2,0,0,0,0,0};
  const mksa_unit __rem_unit={0.01,2,0,-2,0,0,0,0,0};
  const mksa_unit __rod_unit={5.02921005842,1,0,0,0,0,0,0,0};
  const mksa_unit __rpm_unit={0.0166666666667,0,0,-1,0,0,0,0,0};
  const mksa_unit __sb_unit={10000,-2,0,0,0,0,0,1,0};
  const mksa_unit __slug_unit={14.5939029372,0,1,0,0,0,0,0,0};
  const mksa_unit __st_unit={1,3,0,0,0,0,0,0,0};
  const mksa_unit __t_unit={1000,0,1,0,0,0,0,0,0};
  const mksa_unit __tbsp_unit={1.47867647813e-5,3,0,0,0,0,0,0,0};
  const mksa_unit __tec_unit={41.76e9/1.5,2,1,-2,0,0,0,0,0};
  const mksa_unit __tep_unit={41.76e9,2,1,-2,0,0,0,0,0};
  const mksa_unit __tepC_unit={830,1,0,0,0,0,0,0,0};
  const mksa_unit __tepcC_unit={1000,1,0,0,0,0,0,0,0};
  const mksa_unit __tepgC_unit={650,1,0,0,0,0,0,0,0};
  const mksa_unit __tex={1e-6,-1,1,0,0,0,0,0,0};
  const mksa_unit __therm_unit={105506000,2,1,-2,0,0,0,0,0};
  const mksa_unit __toe_unit={41.76e9,2,1,-2,0,0,0,0,0};
  const mksa_unit __ton_unit={907.18474,0,1,0,0,0,0,0,0};
  const mksa_unit __tonUK_unit={1016.0469088,0,1,0,0,0,0,0,0};
  const mksa_unit __torr_unit={133.322368421,-1,1,-2,0,0,0,0,0};
  const mksa_unit __tr_unit={2*M_PI,0,0,0,0,0,0,0,0};
  const mksa_unit __tsp_unit={4.928921614571597e-6,3,0,0,0,0,0,0,0};
  const mksa_unit __u_unit={1.6605402e-27,0,1,0,0,0,0,0,0};
  const mksa_unit __yd_unit={0.9144,1,0,0,0,0,0,0,0};
  const mksa_unit __yr_unit={31556925.9747,0,0,1,0,0,0,0,0};
  const mksa_unit __micron_unit={1e-6,1,0,0,0,0,0,0,0};
  const mksa_unit __hbar_unit={1.05457266e-34,2,1,-1,0,0,0,0};
  const mksa_unit __c_unit={299792458,1,0,-1,0,0,0,0};
  const mksa_unit __g__unit={9.80665,1,0,-2,0,0,0,0};
  const mksa_unit __IO_unit={1e-12,0,1,-3,0,0,0,0};
  const mksa_unit __epsilonox_unit={3.9,0,0,0,0,0,0,0};
  const mksa_unit __epsilonsi_unit={11.9,0,0,0,0,0,0,0,0};
  const mksa_unit __qepsilon0_unit={1.4185979e-30,-3,-1,5,3,0,0,0};
  const mksa_unit __epsilon0q_unit={55263469.6,-3,-1,3,1,0,0,0};
  const mksa_unit __kq_unit={8.617386e-5,2,1,-3,-1,-1,0,0};
  const mksa_unit __c3_unit={.002897756,1,0,0,0,1,0,0};
  const mksa_unit __lambdac_unit={ 0.00242631058e-9,1,0,0,0,0,0,0,0};
  const mksa_unit __f0_unit={2.4179883e14,0,0,-1,0,0,0,0};
  const mksa_unit __lambda0_unit={1239.8425e-9,1,0,0,0,0,0,0};
  const mksa_unit __muN_unit={5.0507866e-27,2,0,0,1,0,0,0};
  const mksa_unit __muB_unit={ 9.2740154e-24,2,0,0,1,0,0,0};
  const mksa_unit __a0_unit={.0529177249e-9,1,0,0,0,0,0,0};
  const mksa_unit __Rinfinity_unit={10973731.534,-1,0,0,0,0,0,0};
  const mksa_unit __Faraday_unit={96485.309,0,0,1,1,0,-1,0};
  const mksa_unit __phi_unit={2.06783461e-15,2,1,-2,-1,0,0,0};
  const mksa_unit __alpha_unit={7.29735308e-3,0,0,0,0,0,0,0};
  const mksa_unit __mpme_unit={1836.152701,0,0,0,0,0,0,0};
  const mksa_unit __mp_unit={1.6726231e-27,0,1,0,0,0,0,0};
  const mksa_unit __qme_unit={1.75881962e11,0,-1,1,1,0,0,0};
  const mksa_unit __me_unit={9.1093897e-31,0,1,0,0,0,0,0};
  const mksa_unit __qe_unit={1.60217733e-19,0,0,1,1,0,0,0};
  const mksa_unit __h__unit={6.6260755e-34,2,1,-1,0,0,0,0};
  const mksa_unit __G_unit={6.67259e-11,3,-1,-2,0,0,0,0};
  const mksa_unit __mu0_unit={1.25663706144e-6,1,1,-2,-2,0,0,0};
  const mksa_unit __epsilon0_unit={8.85418781761e-12,-3,-1,4,2,0,0,0};
  const mksa_unit __sigma_unit={ 5.67051e-8,0,1,-3,0,-4,0,0};
  const mksa_unit __StdP_unit={101325.0,-1,1,-2,0,0,0,0};
  const mksa_unit __StdT_unit={273.15,0,0,0,0,1,0,0};
  const mksa_unit __R__unit={8.31451,2,1,-2,0,-1,-1,0};
  const mksa_unit __Vm_unit={22.4141e-3,3,0,0,0,0,-1,0};
  const mksa_unit __k_unit={1.380658e-23,2,1,-2,0,-1,0,0};
  const mksa_unit __NA_unit={6.0221367e23,0,0,0,0,0,-1,0};
  const mksa_unit __mSun_unit={1.989e30,0,1,0,0,0,0,0};
  const mksa_unit __RSun_unit={6.955e8,1,0,0,0,0,0,0};
  const mksa_unit __PSun_unit={3.846e26,2,1,-3,0,0,0,0};
  const mksa_unit __mEarth_unit={5.9736e24,0,1,0,0,0,0,0};
  const mksa_unit __REarth_unit={6.371e6,1,0,0,0,0,0,0};
  const mksa_unit __sd_unit={8.61640905e4,0,0,1,0,0,0,0};
  const mksa_unit __syr_unit={3.15581498e7,0,0,1,0,0,0,0};
02-02-2018, 01:42 PM (This post was last modified: 02-02-2018 01:43 PM by toml_12953.)
(02-02-2018 06:48 AM)parisse Wrote:  I guess this refers to CAS constants. If someone want to have them updated, please correct the code below:
Here's the code with corrected constants.
                   mergevecteur(makevecteur(_C_unit,_F_unit,_Gy_unit,_H_unit,_Hz_unit,_J_unit,​​_mho_unit),
                        makevecteur(_N_unit,_Ohm_unit,_Pa_unit,_rad_unit,_S_unit,_Sv_unit,_T_unit))​​,
  const mksa_unit __cal_unit={4.184,2,1,-2,0,0,0,0,0};
  const mksa_unit __mmHg_unit={133.322387415,-1,1,-2,0,0,0,0,0};
  const mksa_unit __ozUK_unit={2.84130625e-5,3,0,0,0,0,0,0,0};
  const mksa_unit __pc_unit={3.08567758149e16,1,0,0,0,0,0,0,0};
  const mksa_unit __Torr_unit={133.322368421,-1,1,-2,0,0,0,0,0};
The corrections are to the following:
_ozUK, _pc, capitalizing the constant Torr, _mmHg, _inH2O, and _cal
These have all been posted before by other people but we'll keep at it until they're corrected. For a discussion on this topic, see
http://www.numericana.com/answer/hp-prime.htm
Scroll down to the section on Physical Units. It would also be nice to include the entries marked in gray in that table but I haven't included them in the above code since I don't know it there's room or not.
Tom L
Cui bono?
02-03-2018, 07:44 AM
I have fixed the values in giac source, I did not see any difference for _inH2O in the code slice, I took 249.08193551052 from your web link.
User(s) browsing this thread:
