Statistics_1Var H1 definition - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Statistics_1Var H1 definition (/thread-8915.html) |
Statistics_1Var H1 definition - webmasterpdx - 08-26-2017 11:03 PM I've seen the Statistics_1Var app used to plot data in several programs. However, as part of this, somewhere it sets H1 as in these 2 examples. H1:={"D1", "D2",1,0}; and H1:={"D1", "D2",1,0,#FF:24h}; Can someone tell me what the values in the lists in the assignments are? Thanks in advance -Donald RE: Statistics_1Var H1 definition - webmasterpdx - 08-27-2017 10:46 AM I've finally figured this out....it's taken quite a while of scouring various articles, etc, etc and trying just about every option in the symbolic view and changing them and looking at the value of H1. So, H1:={"D1","D2",4,0,#FF:24h} means... D1 is the independent variable. D2 is the frequency of each entry of D1. 4 is the plot type (Line in this case). 0 is the option for the plot type. Certain plot types have more than one option. #FF:24h is the color, represented as FF hex as a 24bit unsigned integer. This is really #0000FFh, or BLUE. e.g. Red would be #FF0000:24h This info should really be in the User manual....maybe someone from HP could do this? Thx -Donald RE: Statistics_1Var H1 definition - Tim Wessman - 08-27-2017 03:51 PM It is in 2 places already. Page 620 (english) of the current user guide in the Programming in HPPPL section, Symbolic view variables. Quote:H1...H5 Also you can look in your on calculator help. It will be under HP Apps->Stat 1 Var App-> Statistics 1 Var Variables->Symbolic variables You could tap the "Search" button in the tree, type H1, tap the case sensitive, and I expect you'd end up there with 1-2 taps. RE: Statistics_1Var H1 definition - webmasterpdx - 08-27-2017 06:11 PM Just a matter of knowing where to look I guess. I spent 2 days unable to find that info... |
