Have you used your calculator for something that was not really math related? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Have you used your calculator for something that was not really math related? (/thread-7909.html) |
RE: Have you used your calculator for something that was not really math related? - Rogier - 03-06-2019 09:29 PM (03-02-2019 05:31 PM)ijabbott Wrote:(03-02-2019 01:15 PM)Maximilian Hohmann Wrote: Now the cassette players of the time had non-linear tape counters. There was no 1:1 relation between the playing time of the music and the counter. The relationship between counter value and time was definitely non-linear. I programmed my HP11 tot convert between the two. For converting counter value to time I had to add a sinus-like function (doing one cycle per side-length 45 minutes) to a straight line. If anyone is interested I'll post it. Particularly useful for owners of a working early '80s Philips cassette player. Some other non-math applications: * games; Mastermind, Mahjong-scores (both posted), Blackjack. * dice (like many others) * medical calculations: - multiple category-counter (for counting white bloodcells by type) - expected lung volumes for a given sex, age & height, - blood-gas analysis - body surface area - glomerular filtration rate (eGFR/MDRD) RE: Have you used your calculator for something that was not really math related? - Gamo - 03-07-2019 01:08 PM I use my calculator to generate lottery quick-pick numbers. Using a quick and easy to remember program but in order to use this it is math related at first in order to use it in program. for HP-12C or 12CP to generate 6 digits randomly. Procedure: 0 < seed < 1 [R/S] display xxx,xxx Program: RPN mode Code:
Program: ALG mode Code:
Gamo RE: Have you used your calculator for something that was not really math related? - Dieter - 03-08-2019 08:30 PM (03-07-2019 01:08 PM)Gamo Wrote: I use my calculator to generate lottery quick-pick numbers. The two programs generate numbers between 100000 and 999998. Is this what you intended? I don't know anything about this lottery, but if you want six-digit random numbers up to 999999 you have to replace this 899999 with 900000, i.e. 9 E5. Dieter RE: Have you used your calculator for something that was not really math related? - Csaba Tizedes - 03-09-2019 11:07 PM Have you used your watch for something that was not really timing related? Oh, yes Csaba RE: Have you used your calculator for something that was not really math related? - Jlouis - 03-10-2019 12:42 AM (03-09-2019 11:07 PM)Csaba Tizedes Wrote: Have you used your watch for something that was not really timing related? This is the same principle that an aircraft reads indicated air speed through pitot tubes. By the way, I didn't know that this Casio has that wonderfull display contrast...I really don't like non programmable calculators, but now I have a crush in this one...hmmmm This is C.A.S...... RE: Have you used your calculator for something that was not really math related? - brickviking - 03-10-2019 09:36 AM I've really enjoyed the displays on my 82MS, 82TL and 9750gII. They're (at least in my opinion) much nicer to view than the slightly blue LCD of the 9750g+. I also like the shapes of the characters on the lower LCD for the 82 series, though that could just be a case of not having used anything else here where I live. No TI to be seen here. (Post 327) RE: Have you used your calculator for something that was not really math related? - pier4r - 03-10-2019 05:00 PM (03-09-2019 11:07 PM)Csaba Tizedes Wrote: Have you used your watch for something that was not really timing related? It is sort of OT but I use my digital clock as random source (if I don't look at it too often). For example getting 0 or 1. If the seconds are between 0 and 4, it means 0, otherwise it means 1. It is pretty nice when cycling / walking through a city to explore in a random way. Although sometimes I need to add rules to avoid going back on the same route, or when there are more than 2 directions. RE: Have you used your calculator for something that was not really math related? - freelanzr - 04-12-2019 12:55 AM This is a great thread topic, with some really interesting use cases. The very first HP Prime program I ever wrote was a Roll Dice program specifically for the game of Risk, since we had lost some of the Die. Of course, it would query for Attacker and Defender # of die to roll, and then output the roll results and lost armies for each side. I added a counter for tracking Attack/Defense win ratio and percentage. RE: Have you used your calculator for something that was not really math related? - Valentin Albillo - 04-12-2019 02:17 AM . Hi, pier4r: Quote:Have you used your calculator for something that was not really math related? For assorted HP RPN calculators (HP-25, HP-12C, HP-67, HP-41C and HP-71B), apart from dice, games (all types, including adventure-like, word games, board games such as Checkers, Minichess, Othello and even a "Scrambler"-type graphic one), simulations (Life, random walks, mazes, genetic algorithms, a cross-compiler, etc.) and all that (including my Modest Mater and Sudoku Solver programs), I also wrote an ELIZA-like conversational HP-71B program which of course has nothing to do with math, it's all logic, pattern recognition, some heuristics and lotsa lotsa text handling. Limited (mainly because of limited RAM) but fun. Another "not really math related" HP-71B program I wrote was one to create arbitrary text 3D stereograms, viewable either in a physical or emulated HP-IL monitor or by printing them to paper. If interested, it's included in my PDF article Long Live the HP-71B !. Enjoy Best regards. V. . RE: Have you used your calculator for something that was not really math related? - Jlouis - 04-14-2019 03:04 PM This guy have https://youtu.be/5Qf9ADP5Tis RE: Have you used your calculator for something that was not really math related? - vassilisprevelakis - 04-20-2019 11:03 AM (03-04-2019 03:53 PM)EugeneNine Wrote: Is that similar to the old GPIB (I think that was the name), it looked like a narrow centronics connector. HP-IB: Not just IEEE-488, but the hardware, documentation and support that delivers the shortest path to a measurement system. :-) **vp RE: Have you used your calculator for something that was not really math related? - Sylvain Cote - 04-20-2019 12:13 PM (04-20-2019 11:03 AM)vassilisprevelakis Wrote:(03-04-2019 03:53 PM)EugeneNine Wrote: Is that similar to the old GPIB (I think that was the name), it looked like a narrow centronics connector. Chronology of the HP-IB evolution:
