HP45 Behaviour - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP45 Behaviour (/thread-7371.html) |
HP45 Behaviour - teenix - 12-05-2016 02:18 PM Hi all, I was playing around with the HP-45 emulator and came across this problem Assume you have a value stored in Memory [1] (Example: 50 STO 1). If you do RCL 1, then 50 is placed into the C register and the stack is lifted by one and 50 is displayed as you would expect. However, when the Enter key is pressed, then the Status register bit 7 is cleared when the code gets back to the main loop. Now if you press RCL 1, the value is placed into the C register but the stack is not lifted. Stack 5 Enter 1/x RCL 1 T 0 0 0 0 Z 0 0 0 5 Y 0 5 5 0.2 X 0 5 0.2 50 (Expected) (However) Stack 5 Enter RCL 1 RCL 1 T 0 0 0 0 Z 0 0 5 0 Y 0 5 5 5 X 0 5 50 50 Anyone know if this happen on a real HP45 cheers Tony RE: HP45 Behaviour - teenix - 12-05-2016 03:08 PM sorry It's early in the morning, I figured it out No need for the duplicated entry once the enter key is pressed when another variable is expected Time for bed Cheers RE: HP45 Behaviour - Geoff Quickfall - 12-05-2016 05:49 PM As they say in the legal profession: "asked and answered." :-) |
