Information on calculator Random Number Generators from PPC Journal articles - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Information on calculator Random Number Generators from PPC Journal articles (/thread-7196.html) |
RE: Information on calculator Random Number Generators from PPC Journal articles - Dieter - 11-15-2016 10:26 PM (11-15-2016 09:32 PM)Paul Dale Wrote: You didn't include the \( frac ( 2^{20} x_n ) \) part. The leading bits don't pass the randomness tests but going down the mantissa a bit does. Sorry, it was not clear to me that R_n is returned and not x_n. Adding the 20-bit shift improves the results very much, if (!) the algorithm runs in a regular binary double precision environment with 53 bit mantissa. On the other hand the method may not be the first choice on a standard 10-digit BCD calculator: here only three digits may remain in the fractional part after the multiplication by 2^20. I tried shifting by 13 bits, i.e. x_n*8192, which yields 2..3 more digits, but here other problems arise. Dieter RE: Information on calculator Random Number Generators from PPC Journal articles - Paul Dale - 11-15-2016 10:40 PM For a BCD device, I'd multiply by a power of ten instead. Pauli RE: Information on calculator Random Number Generators from PPC Journal articles - Paul Dale - 11-15-2016 10:47 PM (11-15-2016 05:12 PM)Namir Wrote: I checked the method with Excel VBA and realized that the random calculation noise (generated when you take the fractional part of large numbers) was particular to Matlab! Might the noise be correct and Excel is doing naughty things in the background? See e.g. pages 7 & 8 of https://people.eecs.berkeley.edu/~wkahan/ARITH_17.pdf Pauli RE: Information on calculator Random Number Generators from PPC Journal articles - Dieter - 11-15-2016 11:05 PM (11-15-2016 10:40 PM)Paul Dale Wrote: For a BCD device, I'd multiply by a power of ten instead. OK, but 2^20 = 1.048.576 or 1.000.000 does not make much of a difference. ;-) Dieter RE: Information on calculator Random Number Generators from PPC Journal articles - Paul Dale - 11-15-2016 11:51 PM It might be possible to reduce the multiplier to \( 10^4 \) or \( 10^5 \)without losing the apparent entropy. The choice of \( 2^{20} \) was fairly arbitrary. Pauli RE: Information on calculator Random Number Generators from PPC Journal articles - Dieter - 11-16-2016 01:53 PM (11-15-2016 11:51 PM)Paul Dale Wrote: It might be possible to reduce the multiplier to \( 10^4 \) or \( 10^5 \)without losing the apparent entropy. The choice of \( 2^{20} \) was fairly arbitrary. I tried a multiplier of 1000 which leaves 5 or 6 digits on a 10-digit calculator. Which is not too much since some game programs use the first four digits to get two 2-digit random numbers. #-) After a few runs with 10 batches of 1000 numbers each I discovered a similar phenomenon like the one you can see in the table at post #39. This time there were several 1000-number-runs where not a single random number appeared between 0,7 and 0,8. The pattern was like this, leading to Chi² = 202,9. While the first three 10.000-number-runs looked fine, all following ones had this pattern, maybe here and there ±1 in the one or other bin, but always the 8th one empty: Code: 0,0... 117 Very strange. I wonder if it's the RNG, Excel or my coding. The random numbers were calculated this way, starting with a seed of x0 = 0.546703671. Code: z = Exp(Round(x + x + 1, 9)) Any idea what would cause strange results like these? Dieter RE: Information on calculator Random Number Generators from PPC Journal articles - Dieter - 11-16-2016 06:20 PM (11-16-2016 01:53 PM)Dieter Wrote: Any idea what would cause strange results like these? I did another test. This time starting with x0 = 0,45642414. The implementation mentioned above generates the following sequence: 0,350905 0,42875 0,62931 0,93117 0,02565 0,42874 0,643333 ... A sample of 1000 consecutive random numbers showed a period length of 77. The 78th number is 0,350905 again, and the above sequence starts over. In fact the 78th x-value is 0,45642414 again, the original seed. Thus in 1000 numbers every value occured 13 times. OK, except one since 13x77=1001. This exeption is the seed itself, i.e. Rn=0, 42414. And in fact there is not one single Rn in [0,7; 0,8[. In the sorted list of these 1000 random numbers 0,69777 is directly followed by 0,84506. I have also checked this with an HP41 implementation: Code: RCL 00 Starting with 0,45642414 in R00 the program yielded exactly the same results, and after 77 numbers the sequence restarted, with 0,45642414 in R00 again. For the record, here is the complete list of the first 80 Rn: Code: 1. 0,350905 Hm, hmm, hmmm... Dieter RE: Information on calculator Random Number Generators from PPC Journal articles - Paul Dale - 11-16-2016 10:22 PM Working in higher precision, the \( e^{2x+1} \) generator seems to work okay with a scale factor of \( 10^5 \) but no so well with \( 10^4 \). However, I've not tried limiting calculations to 10 digits as you are doing. Pauli RE: Information on calculator Random Number Generators from PPC Journal articles - Namir - 11-29-2016 05:09 AM In the previous messages in this thread, the following similar PRNGs were mentioned: r=frac((pi+r)^3) r=frac((pi+r)^5) Their general form is: r=frac((a+r)^b) I chose a = pi + cos(k * c2 / pi) and b = 4 + sin(k * c1 / pi) Where c1=127, c2=113, and k is a counter that is incremented every time we invoke the PRNG function. I tested 5 runs of 10,000 random numbers. The maximum absolute auto-correlation was less than 0.03. The Chi-Square was in (4, 10.3) range. The mean and sdev of all 50,000 random numbers were 0.500016257 and 0.288179175, respectively. The above PRNG should be adequate for calculation apps, simulations, and games. Enjoy! Namir PS: You can also use a = pi + sin(k * c2 / pi) and b = 4 +cos(k * c1 / pi) and get similar results. |
