New Version: 2016.08.29 r10637 - Printable Version
+--- Thread: New Version: 2016.08.29 r10637 (/thread-6803.html)
Pages: 1 2 3 4 5
RE: New Version: 2016.08.29 r10637 - zahi48g - 09-19-2016 04:20 PM
How to choose my next computer so that it will accept the prime CK ?
Thank you .
RE: Computer ??? - BERNARD MICHAUD - 09-19-2016 04:40 PM
I'm not an expert in the field, but my best guess would be a nice advanced HP Laptop.
RE: New Version: 2016.08.29 r10637 - zahi48g - 09-19-2016 04:48 PM
Thank you but which one between 500 euros and 1000 euros ?
RE: New Version: 2016.08.29 r10637 - BERNARD MICHAUD - 09-19-2016 05:21 PM
I'm not sure what you would like or can afford, but I would like an HP Pavilion 13-s120ca x360 Convertible Notebook, 6th-Gen Intel® Core™ i3-6100U, 4GB RAM, Bilingual
RE: New Version: 2016.08.29 r10637 - zahi48g - 09-19-2016 05:28 PM
Thank you BM.
Any comment about my dream machine from hp team ?
RE: New Version: 2016.08.29 r10637 - zahi48g - 09-20-2016 11:07 PM
Hi.
Is it possible to export from the sequence app the values of say U1 (from U1(o) to U1(400)) into list L5 ?
I'm talking about a sequence of numbers that cannot be generated with MAKELIST , for instance a sequence whose generation requires another sequence.
RE: New Version: 2016.08.29 r10637 - Didier Lachieze - 09-21-2016 12:35 AM
(09-20-2016 11:07 PM)zahi48g Wrote:  Is it possible to export from the sequence app the values of say U1 (from U1(o) to U1(400)) into list L5 ?
L5:=MAKELIST(Sequence.U1(J),J,0,400)
RE: New Version: 2016.08.29 r10637 - zahi48g - 09-21-2016 01:40 AM
Thank you DL.
I was close to that solution but in order to do so the sequence app had to be open .
Thanks to you , I can refer to it even closed .
RE: New Version: 2016.08.29 r10637 - zahi48g - 09-21-2016 04:04 PM
Hi.
Suppose i have created an app solver ,say for astronomy , and my equations (more than ten) are stored in a dedicated note catalog.
When I copy several equations (4 for instance) and want to paste them in another duplicated app solver , only one equation appears in the paste menu . why ?
RE: New Version: 2016.08.29 r10637 - johna - 10-13-2016 10:55 AM
Hi there, any progress on the issue of the CK and VC not running with windows?
I am running Windows 8.1 Pro on a Dell laptop. Both startup briefly and then shutdown. I have re-installed C++ 2013 but still no success.
Both run perfectly on Win 7 Pro laptop that I also have.
Any clues as to what next I should try?
Kind Regards
RE: New Version: 2016.08.29 r10637 - Tim Wessman - 10-13-2016 04:08 PM
I'm assuming you mean they start running, then basically immediately crash.
You probably are having a similar problem as the "surface" units. You'll need to wait for just a little bit longer as the plan was to get the translations back, and then release them with a fixed connkit/emu. The last translation just came back...
RE: New Version: 2016.08.29 r10637 - johna - 10-13-2016 06:40 PM
Thanks for the quick reply Tim. The problem is exactly as you described.
I appreciate the feedback.
Kind regards
RE: New Version: 2016.08.29 r10637 - StephenG1CMZ - 10-13-2016 09:43 PM
(09-19-2016 04:40 PM)BERNARD MICHAUD Wrote:  I'm not an expert in the field, but my best guess would be a nice advanced HP Laptop.
That gives me an interesting idea.
I wonder whether HP might consider including the virtual emulator for the Prime preinstalled on their HP PC's as a unique selling point?
It might bring the calculator to the attention of people who otherwise wouldn't have considered buying one.
And it would remind older users of the good old days when a computer could compile code as soon as it is switched on, like in the 1980's...without first having to spend a couple of days downloading Visual Studio, as in the 2000's.
RE: New Version: 2016.08.29 r10637 - zahi48g - 10-13-2016 11:23 PM
Hi.
It's strange , when I graph a function with the advanced graphing app or geometry app ,I don't get the same
quality of display as with the app function,polar app or parametric app .
Is it possible to improve that with the next upgrade ?
Also , is it possible to copy and paste from excel to the spreadsheet app ?
Thank you .
RE: New Version: 2016.08.29 r10637 - jrozsas - 10-14-2016 12:00 PM
(10-13-2016 11:23 PM)zahi48g Wrote:  Also , is it possible to copy and paste from excel to the spreadsheet app ?
Thank you .
Yes, it is possible. But we need some adjustments.
See:
RE: New Version: 2016.08.29 r10637 - zahi48g - 10-14-2016 07:08 PM
Thank you .
RE: New Version: 2016.08.29 r10637 - zahi48g - 10-14-2016 08:59 PM
Hi .
Did you know ?
Even though the help menu about the CONCAT command only mentions lists , you can concatenate matrices too .
Now , how to concatenate a row-matrix under another ( without copy/paste ) , or even several row-matrices one under another , that's another story .
Let's investigate.
By the way here are some lines from star wars revenge of the siths .
Palpatine : Have you ever heard about the hp prime ?
Anakin : hmm... No !
Palpatine : I'm not surprised . That's not the kind of story the jedis will teach you !
Anakin : How come you ...
Palpatine : Anakin , the hp prime is the only way to esoteric maths ,astronomy, chemistry , physics and algorithms !
Anakin : Is it possible to learn that power !
Palpatine : Not from a texas instrument !
Bye .
RE: New Version: 2016.08.29 r10637 - zahi48g - 10-14-2016 10:34 PM
Hello .
Found ! (But it works only in CAS view)
Suppose you want to concatenate a finite sequence of n row-matrices (of p columns each) one under another .
step 1 : CONCAT(RM1,RM2,....,RMn)
step 2 :mat2list(Ans)
step 3 :list2mat(ans,p)
Et voilà !
RE: New Version: 2016.08.29 r10637 - zahi48g - 10-15-2016 09:19 PM
Hi .
I've found an anomaly .
MAKEMAT(RANDINT(0,9),1,5) gives the expected outcome , [ 1 0 8 9 2 ] for instance , and from home view .
On the other hand , from CAS view the outcome is [1 1 1 1 1], or [2 2 2 2 2] , etc ...
But while in cas view , using menu and importing MAKEMAT(RANDINT(0,9),1,5) from home view
gives the expected outcome .
This should be on the LIST for the next upgrade .
RE: New Version: 2016.08.29 r10637 - Joe Horn - 10-16-2016 04:09 AM
(10-15-2016 09:19 PM)zahi48g Wrote:  I've found an anomaly .
This is another example of the aggravating phenomenon of uppercase/lowercase command differences in CAS. Try doing your example with "makemat" (lowercase) and again with "MAKEMAT" (uppercase). It works as expected in uppercase and fails in lowercase. This is especially sad because the Toolbox Catalog in CAS echoes MAKEMAT in lowercase. Sad
