HP-21 Disassembly Help... - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-21 Disassembly Help... (/thread-5936.html) |
RE: HP-21 Disassembly Help... - Geoff Quickfall - 04-18-2016 04:18 PM I will give that a try! Thanks Katie. Been using the silicone for years, no problems (yet?). Geoff RE: HP-21 Disassembly Help... - PANAMATIK - 12-03-2016 03:42 PM (04-17-2016 06:59 PM)PANAMATIK Wrote:(04-17-2016 05:31 PM)Geoff Quickfall Wrote: Good fix Bernhard! This was a good question, which shows the knowledge of a real master restorer. After a while I needed to add glue also to the center keys, because the ENTER key didn't keep the snap. But now it is stable since months. It is important to hold the two boards tight together until the glue is fixed. Bernhard RE: HP-21 Disassembly Help... - EdS2 - 06-25-2020 07:25 AM (12-03-2016 03:42 PM)PANAMATIK Wrote: After a while I needed to add glue also to the center keys, because the ENTER key didn't keep the snap. But now it is stable since months. It is important to hold the two boards tight together until the glue is fixed. Bernhard, many thanks for the photos and the update. Do I take it that 8 blobs of epoxy was not enough, and that you now used maybe 18 or 20 more blobs? (I have an HP-25 which was disassembled before I got it, and I can't tell how many of the little plastic pillars would originally have had mushroom heads and be holding the keyboard together. Do all of them need reconstruction?) RE: HP-21 Disassembly Help... - PANAMATIK - 06-26-2020 07:09 AM (06-25-2020 07:25 AM)EdS2 Wrote: Bernhard, many thanks for the photos and the update. Do I take it that 8 blobs of epoxy was not enough, and that you now used maybe 18 or 20 more blobs? Yes, as many heat stakes as possible should be fixed with epoxy, also in the middle part of the keyboard. If one or more are loose, when a button is pressed the keyboard PCB is not stable enough and deforms, this changes the click and feel of the inner buttons and makes them wobbly. Bernhard |
