RE: Vietnamese snake puzzle - Closed - Tugdual - 05-21-2015 01:51 PM
(05-21-2015 01:18 PM)fhub Wrote: (05-21-2015 11:53 AM)Tugdual Wrote: I think there are 128 in my list and this is what Haskell returned.
Do you expect more?
Yes, I do expect more.
Your list is missing 8 additional solutions (due to rounding errors), there are 136 solutions in total - here the missing 8:
183745269
183745629
269851473
269851743
783145269
783145629
869251473
869251743
If you rewrite your equation (avoiding the 2 divisions by multiplying with the 2 denominators), then your program will give you all 136 solutions.
Edit: Or change the test to something like abs(expr-66)<1e-3 ...
Franz
Thanks! I'm getting used to the 50g CAS and tend to forget about wandering floats.
[x | x <- permutations [1..9], abs(x!!0+13*x!!1/x!!2+x!!3+12*x!!4-x!!5-11+x!!6*x!!7/x!!8-10-66) < 1E-6]
and do get the 136 answers (a bit slower by the way... but still pretty quick).
RE: Vietnamese snake puzzle - Closed - Gerald H - 05-22-2015 04:42 AM
Pleased to say we ended up with all (?) the solutions.
Did we gain any insight? As far as I can see, just that there's more than one way to stuff a snake.
RE: Vietnamese snake puzzle - Closed - Tugdual - 05-22-2015 12:04 PM
(05-22-2015 04:42 AM)Gerald H Wrote: Pleased to say we ended up with all (?) the solutions.
I don't think so.
Having had a look at the equation, I just see a 9 variables ordinary equation and nothing tinkles my brain. Basically you zero this:
\[\frac { 13*b*i+c*g*h }{ ci } +12*e+a+d-f-87\]
Note: I think the guardian agrees with the ordinary aspect: "There are some puzzles that you solve with a flash of insight, and some others – like this one – where there is no alternative but trial and error."
RE: Vietnamese snake puzzle - Closed - Gerson W. Barbosa - 05-22-2015 08:00 PM
An RPL solution, basically what I did by hand, except that I was a bit smarter and didn't go through some impossible alternatives. But the hp 50g is much faster than I am, so no problem: less than four minutes to find four solutions which can be expanded to more by applying commutative properties of multiplication and addition (9 seconds on the emulator). Writing the program took a bit longer, however, no to mention I lost more the more complicated inner structers last night, by accidentally replacing it with something else. No backups, no notes as it had been done right on the calculator only.
Conclusion: better do this by hand :-)
%%HP: T(3)A(D)F(.);
\<< { 2. 3. 4. 5. 6. 7. 8. 9. } { } 2. 9.
FOR i 2. 9.
FOR b b i \=/
IF
THEN b 13. * 87. - 2. 9.
FOR e e b \=/ e i \=/ AND
IF
THEN e 12. * OVER + 4. PICK 1.
IF DUP DUPDUP i == SWAP b == OR SWAP e == OR
THEN DROP
END
\>> DOLIST 1. 4.
FOR j j 1. + 5.
FOR k DUP j GET OVER k GET DUP2 * i MOD
IF NOT
THEN 0. 0. 0. \-> g h a d f
\<< g h * i / PICK3 + OVER 1.
IF DUPDUP g == SWAP h == OR
THEN DROP
END
\>> DOLIST 1. 3.
START DUPDUP HEAD SWAP TAIL SWAP + SWAP PICK3 SWAP OBJ\-> DROP + NEG + ==
IF
THEN DUP2 NIP OBJ\-> DROP 'f' STO 'd' STO 'a' STO a b 1. d e f g h i { 9. } \->ARRY 7. ROLL + 6. ROLLD
END
NEXT DROP2
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT DROP
END
NEXT
NEXT NIP
{ [ 9. 4. 1. 5. 2. 7. 3. 8. 6. ] [ 3. 2. 1. 5. 4. 7. 8. 9. 6. ] [ 7. 3. 1. 5. 2. 6. 8. 9. 4. ] [ 6. 3. 1. 9. 2. 5. 7. 8. 4. ] }
This should work on the HP-48G also, only remember to make this changes and others I may have forgotten:
NIP: SWAP DROP
DUPDUP: DUP DUP
PICK3: 3 PICK
Gerson.
Edited to fix the range of the loops. I had found an incredible 50-second runtime but the outer loops were ranging from 2 to 6, 2 to 4 and 2 to 8, respectively, and yet the program returned the same four solutions. Something to be explored and analyzed to improve the program. There is still room for improvement such as better list handling, for instance.
P.S.: Considering our equation is
a + 13*b + d + 12*e - f - 11 + g*h/i = 76
We can write the following table:
b e f| result
9 x 8| > 109
8 x 9| > 95
7 2 9| > 106
6 2 9| > 90 => b < 6
x 9 8| > 100
x 8 9| > 87 => e < 8
5 7 9| > 140
5 6 9| > 120
4 5 9| > 106
3 5 9| > 90 => e < 5
Now we can safely define the ranges of the outer loops and be sure we won't miss any solution:
FOR i 2. 5.
FOR b b i \=/
IF
THEN b 13. * 87. - 2. 4.
33.6 seconds on the physical HP 50g!
This matches Tugdual's results when c=1, considering all valid permutations:
941527386
941527836
541927836
541927386
321547896
321547986
521347986
521347896
731526894
731526984
531726984
531726894
631925874
631925784
931625874
931625784
RE: Vietnamese snake puzzle - Closed - Tugdual - 05-22-2015 10:21 PM
(05-22-2015 08:00 PM)Gerson W. Barbosa Wrote: An RPL solution, basically what I did by hand, except that I was a bit smarter and didn't go through some impossible alternatives. But the hp 50g is much faster than I am, so no problem: less than four minutes to find four solutions which can be expanded to more by applying commutative properties of multiplication and addition (9 seconds on the emulator). Writing the program took a bit longer, however, no to mention I lost more the more complicated inner structers last night, by accidentally replacing it with something else. No backups, no notes as it had been done right on the calculator only.
%%HP: T(3)A(D)F(.);
FOR i 2. 9.
FOR b b i \=/
IF
IF
THEN DROP
END
\>> DOLIST 1. 4.
FOR j j 1. + 5.
IF NOT
THEN DROP
END
\>> DOLIST 1. 3.
IF
END
NEXT DROP2
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT DROP
END
NEXT
NEXT NIP
NIP: SWAP DROP
DUPDUP: DUP DUP
PICK3: 3 PICK
Gerson.
Problem is hat your assumption c==1 is not valid. You really need to consider the 2 fractions as a whole instead of 2 individual fractions that deliver integers.
RE: Vietnamese snake puzzle - Closed - Gerson W. Barbosa - 05-22-2015 11:32 PM
(05-22-2015 10:21 PM)Tugdual Wrote: Problem is hat your assumption c==1 is not valid. You really need to consider the 2 fractions as a whole instead of 2 individual fractions that deliver integers.
Hi, Tugdual,
It was more a choice rather than an assumption. Since this problem was set up for eight-year old children, or so they say, I thought solutions involving fractional intermediate results might have been avoided. In that case, 'c' has necessarily to be 1. Also, I was only interested in finding at least one solution -- and this can be done by hand. Of course, the more complex problem of finding all possible solutions does require a calculating device, better if the task is accomplished in an elegant and compact fashion like you did.
Years ago, Karl Schneiner posted another interesting problem involving nine digits without repetions and fractions:
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv017.cgi?read=112157
But please ignore my ugly brute force attemps there, except perhaps the Monte-Carlo approach at the end, despite it being extremely inefficient.
Gerson.
RE: Vietnamese snake puzzle - Closed - Werner - 05-23-2015 09:08 AM
Gerson: for the intermediate results to be integer, c must divide b, which is not the same as saying c must be 1 ;-))
I've written an RPL solution as well that, on EMU48 at full pelt, cranks out all 136 solutions in 30 seconds. But I'm not happy with it yet.
I used Heap's algorithm to generate all permutations - then it took 256 seconds.
Including the condition that
MOD(13*b*i + g*h*c,c*i)=0
after having selected 5 numbers reduced the timing to 30 seconds.
Cheers,
Werner
RE: Vietnamese snake puzzle - Closed - Gerson W. Barbosa - 05-24-2015 03:14 AM
(05-23-2015 09:08 AM)Werner Wrote: Gerson: for the intermediate results to be integer, c must divide b, which is not the same as saying c must be 1 ;-))
You're right. Anyway, by choosing c = 1 I was able to find 16 solutions in 30 seconds on a physical HP 50g (see my edited post above), better than only one which was my goal in the first place.
But I recognize I shouldn't be lazy and should try to find all 136 solutions in a reasonable time. Perhaps one of these days I will :-)
Cheers,
Gerson.
RE: Vietnamese snake puzzle - Closed - Werner - 05-24-2015 06:40 PM
My RPL solution to the arithmetic puzzle (long):
all timings are for EMU48 on my laptop. It's about 120 times faster than a real 48GX.
First, generate permutations:
The following routine will accept a list L on level 2 and an executable object
ob in level 1, and will apply ob to all permutations of the list L. All result
objects (from executing ob), if any, will be wrapped up in an output list.
It does not use Heap's algorithm, for two reasons:
- Heap's algorithm uses a single object swap between permutations. But a swap in RPL is a ROLL and a ROLLD, and it can be done with just a single ROLL.
- at every level, the order at the beginning and end of the level are the same - which is not the case for Heap's algorithm
@ DOPERM1
@ In : L ob
@ out: { r1..rM }
@ L : a list of objects { l1 .. lN }
@ ob: an executable object
@ In : l1 .. lN permutation of the list objects
@ Out: r1..rm l1..lN
@ ob receives the list objects in the first N levels of the stack, in permuted
@ order. It must leave them in the same order, and place any result object(s)
@ above them. These will all be wrapped up in the end in the output list.
@ the original list size N is available to ob as the compiled local variable \<-N
DEPTH DUP DUP @ two levels of dummies to be filled in later
\-> ob D DoP \<-N
\<< @ definition of the recursive function DoP
\-> n
IF n 1 SAME THEN @ at bottom level, execute ob
ob EVAL
ELSE @ else, recurse
1 n START
n ROLL
n 1 - DoP EVAL
NEXT
END
'DoP' STO
LIST\-> '\<-N' STO @ explode the list on the stack, save N
\<-N DoP EVAL @ permute(N)
\<-N DROPN @ drop permutations
DEPTH D - 2 + @ wrap results in a list
IF DUP 0 \>=
THEN \->LIST
ELSE DROP
END
To simply generate all permutations in a list, for instance, the following ob
can be used:
@ l1 .. lN -> { l1 .. lN } l1 .. lN
\<< \<-N \->LIST DUP LIST\-> DROP\>>
running
{ 1 2 3 }
DOPERM1
results in
{ { 2 1 3 } { 2 3 1 } { 3 2 1 } { 3 1 2 } { 1 3 2 } { 1 2 3 } }
and listing all solutions to the arithmetic challenge can be done like this:
{ 1 2 3 4 5 6 7 8 9 }
9 DUPN
\-> A B C D E F G H I
'(13*B*I + G*H*C)/(C*I) + A + D - F + 12*E'
IF 87 SAME THEN 9 \->LIST DUP EVAL END
DOPERM1
427 seconds, 136 solutions, 9! = 362880 permutations tested
We may speed this up unrolling inner loops and so, but we're still testing 362880
permutations. We had better find ways to cut this number down.
Suppose we find B C G H I first, an test whether (13*B*I + G*H*C)/(C*I) is an
integer. If it isn't, there's no need to further test all permutations of A D E
and F. We can do this if we change DOPERM1 as follows:
@ DOPERM2
@ In : L ob
@ out: { r1..rM }
@ In : l1 .. lN level
@ Out: r1..rm l1..lN 0/1
@ ob receives the list objects in levels 2..N+1 of the stack, in permuted
@ order. Stack level 1 contains the level of the permutation, n.
@ On output, l1..lN must be left in the same place, and any result object(s)
@ must be placed above them. These will all be wrapped up in the end in the output
@ list.
@ Stack level 1 must contain 0 or 1 (anu non-zero number will do)
@ 0 : conyinue permuting
@ 1 : skip permutation level, saving level! permutations
DEPTH DUP DUP
\-> ob D DoP \<-N
\-> n
IF n ob EVAL NOT THEN @ level check, skip if test(n) true
1 n START
n ROLL
n 1 - DoP EVAL
NEXT
END
'DoP' STO
LIST\-> '\<-N' STO
\<-N DoP EVAL
\<-N DROPN
DEPTH D - 2 +
IF DUP 0 \>= THEN \->LIST ELSE DROP END
This time, the simple permutation list generating 'ob' looks like this:
IF 1 SAME
THEN
ELSE 0
END
and the ob for straightforward generation of all solutions like this:
IF 1 SAME
THEN
9 DUPN
\-> A B C D E F G H
1
ELSE 0
END
The execution now takes even longer: 495 seconds
This time, however, we can cut the permutations short: once we selected 5 numbers (when permutation 'level' equals 4), we can perform our test, as follows:
CASE
DUP 4 SAME THEN DROP
9 DUPN 4 DROPN
\-> C I B G H '(13*B*I+G*H*C) MOD (C*I)'
END
DUP 1 SAME THEN DROP
9 DUPN
\-> C I B G H E F A D
1
END
DROP 0
END
DOPERM2
56 seconds, 136 solutions, 29232 level-1 permutations checked
We can check C or I are not 5 or 7:
CASE
9 DUPN
\-> C I B G H A D E F
1
END
9 DUPN 4 DROPN
END
DUP 7 SAME THEN DROP
{ 5 7 } 9 PICK POS
END
DUP 8 SAME THEN DROP
{ 5 7 } 10 PICK POS
END
DROP 0
END
DOPERM2
52 seconds, 136 solutions, 29232 level-1 permutations checked
We can unroll the level-4 permutations. Since A and D are commutable, we need
generate only 8 permutations (the bottom 2 need not be swapped if those are A
and D). At the same time, we can re-use the already calculated amount
Also, let's output the solutions in ABCDEFGHI order again:
CASE
9 DUPN DROP2
\-> C I B G H J ob
'(13*B*I+G*H*C)/(C*I)' EVAL
IF DUP FP
THEN DROP
ELSE
'J' STO @ save value (13*B*I+G*H*C)/(C*I)
\<< @ ob to execute at level-1
4 DUPN
\-> E F A D
'J+A+D-F+12*E' EVAL
IF 87 SAME THEN
A B C D E F G H I
9 \->LIST
10 ROLLD
END
'ob' STO
1 4 START @ level-4 permutations unrolled
4 ROLL @ and without level-2 swap
ROT ob EVAL
ROT ob EVAL
ROT ob EVAL
NEXT
END
1
END
{ 5 7 } 9 PICK POS
END
{ 5 7 } 10 PICK POS
END
DROP 0
END
DOPERM2
15 seconds for 68 solutions, 14616 level-1 permutations checked
We can roughly halve that number again by generating the 36 (G,H) combinations
first and permuting the 7 other numbers
1 8 FOR G
G 1 + 9 FOR H
9 8 7 6 5 4 3 2 1
H ROLL DROP
G ROLL DROP
7 \->LIST
CASE
7 DUPN DROP2
\-> B C I J ob
IF DUP FP
THEN DROP
ELSE
4 DUPN
\-> E F A D
'J+A+D-F+12*E' EVAL
IF 87 SAME THEN
A B C D E F G H I
9 \->LIST
8 ROLLD
END
'ob' STO
ROT ob EVAL
ROT ob EVAL
ROT ob EVAL
NEXT
END
1
END
{ 5 7 } 9 PICK POS
END
{ 5 7 } 10 PICK POS
END
DROP 0
END
DOPERM2 +
NEXT
NEXT
10 seconds, 34 solutions, 7308 level-1 solutions checked
To be complete, here's a version to find all solutions where B/C and G*H/I
are integers:
1 8 FOR G
G 1 + 9 FOR H
9 8 7 6 5 4 3 2 1
H ROLL DROP
G ROLL DROP
7 \->LIST
CASE
7 DUPN DROP2
\-> B C I J ob
'G*H/I' EVAL
IF DUP FP
THEN DROP
ELSE
'13*B/C' EVAL + 'J' STO
4 DUPN
\-> E F A D
'J+A+D-F+12*E' EVAL
IF 87 SAME THEN
A B C D E F G H I
9 \->LIST
8 ROLLD
END
'ob' STO
1 4 START
4 ROLL
ROT ob EVAL
ROT ob EVAL
ROT ob EVAL
NEXT
END
1
END
DUP 5 SAME THEN DROP
7 PICK 7 PICK MOD @ test C divides B
END
DROP 0
END
DOPERM2 +
NEXT
NEXT
3.8 seconds, 5 solutions, 4632 level-1 permutations checked
{ { 5 4 1 9 2 7 3 8 6 }
{ 9 3 1 6 2 5 7 8 4 }
{ 6 9 3 5 2 1 7 8 4 }
{ 5 3 1 7 2 6 8 9 4 }
{ 5 2 1 3 4 7 8 9 6 }
Cheers, Werner
RE: Vietnamese snake puzzle - Closed - Gerson W. Barbosa - 05-24-2015 08:20 PM
(05-23-2015 09:08 AM)Werner Wrote: I've written an RPL solution as well that, on EMU48 at full pelt, cranks out all 136 solutions in 30 seconds. But I'm not happy with it yet.
I've decided to change my RPL program to handle c for other values than 1, since it was just a matter of including another loop and do the necessary modifications. Perhaps the most difficult one would be determining the new the MOD condition, but I shamelessly used yours above (Thanks! :-). I've obtained 34 solutions (136/4) as expected, in 49.47 seconds on the emulator (Debug4x, Emu-50g, WinXP, Intel Core Duo CPU @ 1.86 GHz) -- 23 minutes and 31.9 seconds on the physical HP 50g. Ok, each solution should be processed to generate three additional ones, but that would take irrelevant time so I won't mind doing it.
Cheers,
Gerson.
%%HP: T(3)A(D)F(.);
\<< { 1. 2. 3. 4. 5. 6. 7. 8. 9. } { } 1. 9.
FOR i 1. 9.
FOR c c i \=/
IF
THEN 1. 9.
FOR b b c \=/ b i \=/ AND
IF
THEN b 13. * c / 87. - 1. 7.
FOR e e b \=/ e c \=/ AND e i \=/ AND
IF
IF DUPDUP DUPDUP i == SWAP c == OR SWAP b == OR SWAP e == OR
THEN DROP
END
\>> DOLIST 1. 4.
FOR j j 1. + 5.
FOR k DUP j GET OVER k GET DUP2 * c * b 13. * i * + i c * MOD
IF NOT
THEN DROP
END
\>> DOLIST 1. 3.
START DUPDUP HEAD SWAP TAIL SWAP + SWAP PICK3 SWAP OBJ\-> DROP + NEG + - ABS .000001 <
IF
THEN DUP2 NIP OBJ\-> DROP 'f' STO 'd' STO 'a' STO a b c d e f g h i 9. \->LIST 1. \->LIST 7. ROLL SWAP + 6. ROLLD
END
NEXT DROP2
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT DROP
END
NEXT
END
NEXT
NEXT NIP
{ { 7. 6. 4. 8. 5. 9. 1. 3. 2. } { 9. 6. 4. 3. 5. 8. 1. 7. 2. } { 1. 9. 6. 4. 5. 8. 3. 7. 2. } { 9. 4. 8. 5. 6. 7. 1. 3. 2. } { 2. 8. 6. 9. 4. 1. 5. 7. 3. } { 2. 6. 9. 8. 5. 1. 4. 7. 3. } { 6. 3. 1. 9. 2. 5. 7. 8. 4. } { 7. 3. 1. 5. 2. 6. 8. 9. 4. } { 7. 3. 2. 8. 5. 9. 1. 6. 4. } { 5. 7. 2. 8. 3. 9. 1. 6. 4. } { 8. 9. 2. 3. 1. 5. 6. 7. 4. } { 5. 9. 3. 6. 2. 1. 7. 8. 4. } { 3. 2. 8. 6. 5. 1. 7. 9. 4. } { 7. 2. 8. 9. 6. 5. 1. 3. 4. } { 3. 2. 1. 5. 4. 7. 8. 9. 6. } { 9. 4. 1. 5. 2. 7. 3. 8. 6. } { 1. 3. 2. 4. 5. 8. 7. 9. 6. } { 7. 5. 2. 8. 4. 9. 1. 3. 6. } { 8. 5. 2. 1. 4. 7. 3. 9. 6. } { 1. 5. 2. 3. 4. 8. 7. 9. 6. } { 9. 5. 3. 1. 4. 2. 7. 8. 6. } { 3. 2. 4. 8. 5. 1. 7. 9. 6. } { 1. 4. 8. 2. 7. 9. 3. 5. 6. } { 1. 3. 9. 4. 7. 8. 2. 5. 6. } { 9. 1. 2. 5. 6. 7. 3. 4. 8. } { 9. 3. 2. 1. 5. 6. 4. 7. 8. } { 7. 1. 4. 9. 6. 5. 2. 3. 8. } { 2. 1. 4. 3. 7. 9. 5. 6. 8. } { 7. 3. 4. 1. 6. 5. 2. 9. 8. } { 1. 3. 6. 2. 7. 9. 4. 5. 8. } { 7. 9. 6. 1. 5. 2. 3. 4. 8. } { 2. 9. 6. 3. 5. 1. 4. 7. 8. } { 7. 8. 3. 1. 4. 5. 2. 6. 9. } { 1. 2. 6. 4. 7. 8. 3. 5. 9. } }
I think this is correct, but I haven't checked it yet.
RE: Vietnamese snake puzzle - Closed - Gerson W. Barbosa - 05-24-2015 08:34 PM
(05-24-2015 06:40 PM)Werner Wrote: My RPL solution to the arithmetic puzzle (long):
This means about 20 minutes on a real HP-48G. Mine takes 23m 32s on the HP 50g, but the 50g is about 5 to 7 times faster than the 48G. Also, high quality documentation -- unlike mine (none).
Congratulations!
Gerson.
RE: Vietnamese snake puzzle - Closed - Werner - 05-25-2015 06:33 AM
(05-24-2015 08:20 PM)Gerson W. Barbosa Wrote: I think this is correct, but I haven't checked it yet.
It passes the test:
DUP EVAL \-> A B C D E F G H I '(13*B*I+G*H*C)/(C*I)+A+D-F+12*E'
IF 87 SAME THEN DROP END
DOLIST
Though none of your solutions matches mine ;-) You take a different A/D order.
Cheers, Werner
RE: Vietnamese snake puzzle - Closed - Gerald H - 05-25-2015 07:14 AM
What a can of snakes I opened.
& then I innocently believed it was done when all solutions were found!
RE: Vietnamese snake puzzle - Closed - Gerson W. Barbosa - 05-26-2015 04:54 AM
(05-25-2015 06:33 AM)Werner Wrote: (05-24-2015 08:20 PM)Gerson W. Barbosa Wrote: I think this is correct, but I haven't checked it yet.
It passes the test:
DOLIST
I tried to optimize the innermost loop so that one, two or three permutations of the candidates to a, d and f were made as needed, rather than always three, but the DO-UNTIL loop ended up being slower than START-NEXT. Now it takes almost one minute longer: 24 min 53 sec. The output list pass the test also, mainly because it's the same list, only with the elements in reverse order :-).
The two nested FOR-NEXT loops one level higher generate the 10 combinations [ C(5,2)] of the five candidates to g, h, a, d and f. An optimization here might help. The HP 50g has C2P, P2C and CIRC, but I don't know if those can be used for this purpose.
Cheers,
Gerson.
%%HP: T(3)A(D)F(,);
\<< { 1, 2, 3, 4, 5, 6, 7, 8, 9, } { } 1, 9,
FOR i 1, 9,
FOR c c i \=/
IF
THEN 1, 9,
IF
THEN b 13, * c / 87, - 1, 7,
IF
THEN e 12, * OVER + 4, PICK 1,
THEN DROP
END
\>> DOLIST 1, 4,
FOR j j 1, + 5,
FOR k DUP j GET OVER k GET DUP2 * c * b 13, * i * + i c * MOD
IF NOT
THEN 0, 0, 0, \-> g h a d f
\<< g h * i / PICK3 + OVER 1,
THEN DROP
END
\>> DOLIST 0, 1, CF
DO 1, + UNROT SWAP OVER OBJ\-> DROP + NEG + OVER - ABS ,000001 <
IF
THEN 1, SF OVER OBJ\-> DROP 'd' STO 'a' STO 'f' STO a b c d e f g h i 9, \->LIST 1, \->LIST 8, ROLL + 7, ROLLD
END 1, FS? NOT
IF
THEN SWAP DUP HEAD SWAP TAIL SWAP + SWAP
END UNROT SWAP DUP 3, == 1, FS? OR
UNTIL
END 3, DROPN
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT DROP
END
NEXT
END
NEXT
NEXT NIP
P.S.:
Time on the HP 49G: 1h 09m 32s. 1h 12m 25s on the HP 48GX.
HP 48GX version:
%%HP: T(3)A(D)F(.);
\<< TIME { 1 2 3 4 5
6 7 8 9 } { } 1 9
FOR i 1 9
FOR c c i \=/
IF
THEN 1 9
FOR b b c \=/
b i \=/ AND
IF
THEN b 13
* c / 87 - 1 7
FOR e e
AND
IF
THEN
e 12 * OVER + 4
PICK 1
IF DUP DUP DUP2 i
== SWAP c == OR
SWAP b == OR SWAP e
== OR
THEN DROP
END
\>> DOLIST 1 4
FOR j j 1 + 5
FOR k DUP j GET
OVER k GET DUP2 * c
* b 13 * i * + i c
* MOD
IF NOT
THEN 0 0 0 \-> g
h a d f
\<< g h * i / 3
PICK + OVER 1
IF DUP
DUP g == SWAP h ==
OR
THEN DROP
END
\>> DOLIST 0
1 CF
DO 1 + ROT
DROP + NEG + OVER -
ABS .000001 <
IF
THEN 1 SF
STO 'a' STO 'f' STO
a b c d e f g h i 9
\->LIST 1 \->LIST 8
ROLL + 7 ROLLD
END 1 FS?
NOT
IF
THEN SWAP
DUP HEAD SWAP TAIL
SWAP + SWAP
END ROT
ROT SWAP DUP 3 == 1
FS? OR
UNTIL
END 3 DROPN
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT
DROP
END
NEXT
END
NEXT
NEXT SWAP DROP
TIME ROT HMS-
RE: Vietnamese snake puzzle - Closed - Gilles - 05-26-2015 08:57 PM
Thanks a lot Werner for your usefull and efficiant DOPERM program !
Very interesting. It's now in my favorite programs ;D I wonder what could be the gain of a sys-RPL version ? Strangely there is no (as far I know) permutations library for the 50G.
RE: Vietnamese snake puzzle - Closed - Werner - 05-27-2015 10:12 AM
@Gilles: thanks. I have a 'DOCOMB' lying around for years as well, that will let you execute an object for all combinations of m (input) out of n (size of list) objects.
For the arithmetic puzzle:
The G-H equivalence can be implemented in a much easier way: just test G>H (or vice versa) at the appropriate level ( 5 here):
CASE
9 DUPN DROP2
\-> B C G H I J ob
'G*H/I' EVAL
IF DUP FP
THEN DROP
ELSE
4 DUPN
\-> E F A D
'J+A+D-F+12*E' EVAL
IF 87 SAME THEN
A B C D E F G H I
9 \->LIST
10 ROLLD
END
'ob' STO
1 4 START
4 ROLL
ROT ob EVAL
ROT ob EVAL
ROT ob EVAL
NEXT
END
1
END
DUP 5 SAME THEN DROP @ test G > H
7 PICK 7 PICK >
END
9 PICK 9 PICK MOD @ test C divides B
END
DROP 0 @ default: continue
END
DOPERM2
And it's even slightly faster.
Cheers, Werner
RE: Vietnamese snake puzzle - Closed - Gerson W. Barbosa - 05-28-2015 09:20 PM
(05-23-2015 09:08 AM)Werner Wrote: Including the condition that
I've changed to the condition FP(13*b/c + g*h/i)=0, which is simpler and uses four multiplication/division operations instead of six. Since I take 13*b/c from the stack, this is reduced to only one multiplication and one division in the inner loop. Also, local variables 'a', 'd' and 'f' are not defined anymore. Running times are now 1h 05m 32.9s on the HP-48GX and 21m 51.9s on the HP 50g. I should revert to my original innermost loop, which apparently is faster, but I prefer to optimize the current one later. I'd be pleased with less than one hour's time on the HP-48GX :-)
Cheers,
Gerson.
HP-48GX:
%%HP: T(3)A(D)F(.);
6 7 8 9 } { } 1 9
FOR i 1 9
FOR c c i \=/
IF
THEN 1 9
FOR b b c \=/
b i \=/ AND
IF
THEN b 13
* c / DUP 87 - 1 7
FOR e e
AND
IF
THEN
e 12 * OVER + 5
PICK 1
IF DUP DUP DUP2 i
== SWAP c == OR
SWAP b == OR SWAP e
== OR
THEN DROP
END
\>> DOLIST 1 4
FOR j j 1 + 5
FOR k DUP j GET
OVER k GET DUP2 * i
/ 7 PICK + FP
IF NOT
THEN \-> g h
\<< g h * i / 3
PICK + OVER 1
IF DUP
DUP g == SWAP h ==
OR
THEN DROP
END
\>> DOLIST 0
1 CF
DO 1 + ROT
DROP + NEG + OVER -
ABS .000001 <
IF
THEN 1 SF
OVER OBJ\-> DROP SWAP
ROT ROT b c ROT e 5
ROLL g h i 9 \->LIST
1 \->LIST 9 ROLL + 8
ROLLD
END 1 FS?
NOT
IF
THEN SWAP
DUP HEAD SWAP TAIL
SWAP + SWAP
END ROT
ROT SWAP DUP 3 == 1
FS? OR
UNTIL
END 3 DROPN
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT
DROP2
END
NEXT
END
NEXT
NEXT SWAP DROP
TIME ROT HMS-
HP 50g:
%%HP: T(3)A(D)F(.);
FOR i 1. 9.
FOR c c i \=/
IF
THEN 1. 9.
IF
THEN b 13. * c / DUP 87. - 1. 7.
IF
THEN e 12. * OVER + 5. PICK 1.
THEN DROP
END
\>> DOLIST 1. 4.
FOR j j 1. + 5.
FOR k DUP j GET OVER k GET DUP2 * i / 7. PICK + FP
IF NOT
THEN \-> g h
THEN DROP
END
\>> DOLIST 0. 1. CF
DO 1. + UNROT SWAP OVER OBJ\-> DROP + NEG + OVER - ABS .000001 <
IF
THEN 1. SF OVER OBJ\-> DROP SWAP UNROT b c ROT e 5. ROLL g h i 9. \->LIST 1. \->LIST 9. ROLL + 8. ROLLD
END 1. FS? NOT
IF
END UNROT SWAP DUP 3. == 1. FS? OR
UNTIL
END 3. DROPN
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT DROP2
END
NEXT
END
NEXT
NEXT NIP
RE: Vietnamese snake puzzle - Closed - Werner - 05-29-2015 07:14 AM
Quote:I've changed to the condition FP(13*b/c + g*h/i)=0
Yes, I changed it to avoid rounding errors, but it turns out in the 48's decimal arithmetic we don't have any - in hindsight ;-)
My latest posted routine to find the 5 'full integer' solutions runs in 375 seconds on the EMU48 at 'authentic speed' setting, which should not be far off.
To find all solutions it needs approx. 1212 seconds or 20 minutes.
Cheers, Werner
RE: Vietnamese snake puzzle - Closed - Gerson W. Barbosa - 05-31-2015 05:37 AM
(05-29-2015 07:14 AM)Werner Wrote: Quote:I've changed to the condition FP(13*b/c + g*h/i)=0
Cheers, Werner
In addition to the condition e < 8, now I am using -17 < (f - a - d) < 7, which I had done when manually searching for a solution. Now the primary 34 solutions are found in 52m 15.9s on the HP-48GX and in 17m 38.7s on the HP 50g (17m 40.4s in the HP 50g version using DO-UNTIL instead of START-NEXT - definitely not worth in this case since most f, a, d in agreement with the second condition will have to be permutated three times anyway).
I think finding all solutions under one hour's time on the HP-48GX is quite acceptable :-)
Cheers,
Gerson.
HP-48GX:
%%HP: T(3)A(D)F(.);
6 7 8 9 } { } 1 9
FOR i 1 9
FOR c c i \=/
IF
THEN 1 9
FOR b b c \=/
b i \=/ AND
IF
THEN b 13
* c / DUP 87 - 1 7
FOR e e
AND
IF
THEN
e 12 * OVER + 5
PICK 1
IF DUP DUP DUP2 i
== SWAP c == OR
SWAP b == OR SWAP e
== OR
THEN DROP
END
\>> DOLIST 1 4
FOR j j 1 + 5
FOR k DUP j GET
OVER k GET DUP2 * i
/ 7 PICK + FP
IF NOT
THEN \-> g h
\<< g h * i / 3
PICK + DUP DUP -16
< SWAP 6 > OR
IF
THEN DROP
ELSE OVER 1
IF DUP
DUP g == SWAP h ==
OR
THEN
DROP
END
\>> DOLIST
1 3
START DUP
TAIL OVER HEAD + 3
PICK ROT OBJ\-> DROP
+ NEG + - ABS
.000001 <
IF
THEN
DUP OBJ\-> DROP ROT
ROT b c ROT e 6
1 \->LIST 8 ROLL + 7
ROLLD
END
NEXT
DROP2
END
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT
DROP2
END
NEXT
END
NEXT
NEXT SWAP DROP
TIME ROT HMS-
HP 50g:
%%HP: T(3)A(D)F(.);
FOR i 1. 9.
FOR c c i \=/
IF
THEN 1. 9.
IF
IF
THEN DROP
END
\>> DOLIST 1. 4.
FOR j j 1. + 5.
IF NOT
THEN \-> g h
\<< g h * i / PICK3 + DUPDUP -16. < SWAP 6. > OR
IF
THEN DROP
ELSE OVER 1.
THEN DROP
END
\>> DOLIST 1. 3.
START DUP TAIL OVER HEAD + PICK3 ROT OBJ\-> DROP + NEG + - ABS .000001 <
IF
THEN DUP OBJ\-> DROP UNROT b c ROT e 6. ROLL g h i 9. \->LIST 1. \->LIST 8. ROLL + 7. ROLLD
END
NEXT DROP2
END
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT DROP2
END
NEXT
END
NEXT
NEXT NIP
%%HP: T(3)A(D)F(.);
FOR i 1. 9.
FOR c c i \=/
IF
THEN 1. 9.
IF
IF
THEN DROP
END
\>> DOLIST 1. 4.
FOR j j 1. + 5.
IF NOT
THEN \-> g h
IF
THEN DROP
ELSE OVER 1.
THEN DROP
END
\>> DOLIST 0.
IF
THEN 3. DUP UNPICK OVER OBJ\-> DROP SWAP UNROT b c ROT e 5. ROLL g h i 9. \->LIST 1. \->LIST 9. ROLL + 8. ROLLD
END OVER TAIL ROT HEAD + ROT DUP 3. ==
UNTIL
END 3. DROPN
END
ELSE DROP2
END
NEXT
NEXT DROP2
END
NEXT DROP2
END
NEXT
END
NEXT
NEXT NIP
