Are US units correct? - Printable Version
+--- Thread: Are US units correct? (/thread-3918.html)
Pages: 1 2
RE: Are US units correct? - Thomas_Sch - 05-21-2015 12:49 PM
Hello Nigel,
thanks for your checking and your research results.
It took some time until I have seen the difference ;-)
Edit:
@HP / @ Tim:
In my virtual calculator there are always the chinese characters
instead of "inch" or "in":
[attachment=2092]
Any comments?
RE: Are US units correct? - JimS - 05-22-2015 01:16 PM
(05-21-2015 12:49 PM)Thomas_Sch Wrote:  Hello Nigel,
Edit:
@HP / @ Tim:
Any comments?
Do a shift home(icon) and go to the second page. there is a Textbook Display , uncheck the box(make it blank). Joe Horn mentioned a few times that Textbook Display and CAS sometimes cause strange results.
Jim
RE: Are US units correct? - Thomas_Sch - 05-22-2015 02:23 PM
(05-22-2015 01:16 PM)JimS Wrote:
(05-21-2015 12:49 PM)Thomas_Sch Wrote:  ..
Edit:
@HP / @ Tim:
Any comments?
Jim
Yes!
The chinese characters now are away.
It's very strange, that settings in Home mode are responsible for that effects in CAS mode ...
Thank you for your hint!
RE: Are US units correct? - Tim Wessman - 05-22-2015 03:27 PM
(05-22-2015 02:23 PM)Thomas_Sch Wrote:  It's very strange, that settings in Home mode are responsible for that effects in CAS
Well, those are supposed to be the whole "system" settings. Unfortunately, they aren't yet as you can tell with things like complex representation and so on.
The CAS settings would be for things like arbitrary precision calculation (if we can get that turned on at some point in the future), specific CAS settings (exact/approx), and so on.
RE: Are US units correct? - Thomas_Sch - 05-22-2015 05:48 PM
Hello Tim,
Many thanks for your answer!
Do you have an idea, where the chinese-like characters come from?
RE: Are US units correct? - Tim Wessman - 05-22-2015 06:57 PM
In the prior releases, the 2D CAS display didn't display units nicely. We fixed that for this release, but there were two cases that caused problems that was not caught unfortunately. Specifically, "inch" and "μ" prefix. In both cases, when it attempted to match to the HP units, the match did not find something. The μ case was that there are two unicode μ characters and apparently the CAS uses one and the HP code the other...
