Program with the same name as a command - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Program with the same name as a command (/thread-3826.html) |
Program with the same name as a command - salvomic - 05-13-2015 09:15 PM When a custom program has the same name of a command, writing the name, who has the precedence? i.e. a program of mine, gammad_cdf has the same name as the new command (7820): if I write gammad_cdf starts the new command, ok: is there no way to use instead my program? should I change the name to the function? Salvo |
