HP35s any good for EE? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP35s any good for EE? (/thread-3648.html) Pages: 1 2 |
RE: HP35s any good for EE? - Csaba Tizedes - 04-18-2015 09:07 AM You're right also but I guess NOT every engineer knows that 1_Pa = 1_J/m^3. When I learned statics and mechanics (from 1999 to 2004), we used always MPa for stress calculations. Of course the tables gives properties in cm^3 and mm^4. All force in practice always kN. Old engineers "feels the range" when they are make a division of kN*m/cm^3. But I need a "conversion" because in my head everything is MPa. My 48SX is perfect for this. For fluid flow calculations (m^3/h, l/min, bar, mmWG, Pa, etc...) I can feel the right values. (04-18-2015 08:39 AM)walter b Wrote: BTW, that example result "feels" a bit large - did you mean cm^3 instead?It was an example for unit conversion only, this is not a real life calculation. But you're right this beam section property typically given in cm^3. RE: HP35s any good for EE? - Simone Cerica - 04-22-2015 05:05 PM (04-17-2015 11:50 AM)emece67 Wrote: At the risk of being OT. RPL calculators (HP 48/49/50) can emulate CASIO's ENG key: https://groups.google.com/forum/#!topic/comp.sys.hp48/Ud03tImdu-w ex. real numbers 0.01 'ENG\->' 10.E-3 'ENG\->' 10000.E-6 'ENG\->' 10000000.E-9 'ENG\->' 10000000000.E-12 0.01 'ENG\<-' 10.E-3 'ENG\<-' .01E0 'ENG\<-' .00001E3 'ENG\<-' .00000001E6 'ENG\<-' .00000000001E9 5000.E-3 'NORM' --> 5. (STD format) real numbers with unit '1_m' 'U\->' '1000._mm' 'U\->' '1000000._\Gmm' ('\Gm' = 'μ' = micro) '1_m' 'U\<-' '.001_km' 'U\<-' '.000001_Mm' ('k' = kilo, 'M' = mega) useful programs for units: Unit Scaling for HP 48 http://www.hpcalc.org/details.php?id=1649 UTool and Unitman for HP 49/50 http://www.hpcalc.org/details.php?id=4612 http://www.hpcalc.org/details.php?id=4275 |
