Adapting 'Accurate' TVM routine on HP-15C (and HP-34C) using MISO Technique - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Adapting 'Accurate' TVM routine on HP-15C (and HP-34C) using MISO Technique (/thread-324.html) Pages: 1 2 |
RE: Adapting 'Accurate' TVM routine on HP-15C using MISO Technique - Thomas Klemm - 01-11-2014 05:53 AM (01-10-2014 10:50 PM)Jeff_Kearns Wrote: There must be some subtle stack lift thing going on that recall arithmetic avoids in the subsequent substitutions. The problem is in these two lines: 021 ENTER 022 RCL * 3 If you just replace RCL * 3 with RCL 3, * then this will overwrite the value in register x since ENTER disabled the stack lift. Thus what we really need here is DUP. There are two possibilities you can circumvent this problem: ENTER ENTER RCL 3 * Or: ENTER X<>Y RCL 3 * But this is the only occurrence of this problem. In all the other situations RCL ? n can be replaced by just RCL n, ?. In these situations a stack diagram is helpful. 001 LBL E \(x\) \(x\) \(x\) \(x\) 002 STO (i) \(x\) \(x\) \(x\) \(x\) 003 RCL 2 \(x\) \(x\) \(x\) \(i\%\) 004 EEX \(x\) \(x\) \(i\%\) \(1\) 005 2 \(x\) \(x\) \(i\%\) \(100\) 006 / \(x\) \(x\) \(x\) \(i\) 007 ENTER \(x\) \(x\) \(i\) \(i\) 008 ENTER \(x\) \(i\) \(i\) \(i\) 009 1 \(x\) \(i\) \(i\) \(1\) 010 + \(x\) \(x\) \(i\) \(1+i\) 011 LN \(x\) \(x\) \(i\) \(\ln(1+i)\) 012 X<>Y \(x\) \(x\) \(\ln(1+i)\) \(i\) 013 LSTx \(x\) \(\ln(1+i)\) \(i\) \(1+i\) 014 1 \(\ln(1+i)\) \(i\) \(1+i\) \(1\) 015 X≠Y \(\ln(1+i)\) \(i\) \(1+i\) \(1\) 016 - \(\ln(1+i)\) \(\ln(1+i)\) \(i\) \(i\) 017 / \(\ln(1+i)\) \(\ln(1+i)\) \(\ln(1+i)\) \(1\) 018 * \(\ln(1+i)\) \(\ln(1+i)\) \(\ln(1+i)\) \(\ln(1+i)\) 019 RCL 1 \(\ln(1+i)\) \(\ln(1+i)\) \(\ln(1+i)\) \(n\) 020 * \(\ln(1+i)\) \(\ln(1+i)\) \(\ln(1+i)\) \(n\ln(1+i)\) 021 e^x \(\ln(1+i)\) \(\ln(1+i)\) \(\ln(1+i)\) \((1+i)^n\) 022 RCL 3 \(\ln(1+i)\) \(\ln(1+i)\) \((1+i)^n\) \(B\) 023 X<>Y \(\ln(1+i)\) \(\ln(1+i)\) \(B\) \((1+i)^n\) 024 * \(\ln(1+i)\) \(\ln(1+i)\) \(\ln(1+i)\) \(B(1+i)^n\) 025 LSTx \(\ln(1+i)\) \(\ln(1+i)\) \(B(1+i)^n\) \((1+i)^n\) 026 1 \(\ln(1+i)\) \(B(1+i)^n\) \((1+i)^n\) \(1\) 027 - \(\ln(1+i)\) \(\ln(1+i)\) \(B(1+i)^n\) \((1+i)^n-1\) 028 RCL 4 \(\ln(1+i)\) \(B(1+i)^n\) \((1+i)^n-1\) \(P\) 029 * \(\ln(1+i)\) \(\ln(1+i)\) \(B(1+i)^n\) \(P((1+i)^n-1\)) 030 EEX \(\ln(1+i)\) \(B(1+i)^n\) \(P((1+i)^n-1)\) \(1\) 031 2 \(\ln(1+i)\) \(B(1+i)^n\) \(P((1+i)^n-1)\) \(100\) 032 RCL 2 \(B(1+i)^n\) \(P((1+i)^n-1)\) \(100\) \(i\%\) 033 / \(B(1+i)^n\) \(B(1+i)^n\) \(P((1+i)^n-1)\) \(\frac{1}{i}\) 034 RCL 6 \(B(1+i)^n\) \(P((1+i)^n-1)\) \(\frac{1}{i}\) \(E\) 035 + \(B(1+i)^n\) \(B(1+i)^n\) \(P((1+i)^n-1)\) \(\frac{1}{i}+E\) 036 * \(B(1+i)^n\) \(B(1+i)^n\) \(B(1+i)^n\) \(P((1+i)^n-1)(\frac{1}{i}+E)\) 037 + \(B(1+i)^n\) \(B(1+i)^n\) \(B(1+i)^n\) \(B(1+i)^n+P((1+i)^n-1)(\frac{1}{i}+E)\) 038 RCL 5 \(B(1+i)^n\) \(B(1+i)^n\) \(B(1+i)^n+P((1+i)^n-1)(\frac{1}{i}+E)\) \(F\) 039 + \(B(1+i)^n\) \(B(1+i)^n\) \(B(1+i)^n\) \(B(1+i)^n+P((1+i)^n-1)(\frac{1}{i}+E)+F\) 040 RTN \(B(1+i)^n\) \(B(1+i)^n\) \(B(1+i)^n\) \(B(1+i)^n+P((1+i)^n-1)(\frac{1}{i}+E)+F\) Yes, I've tested it and it works fine. The blinking is amazing! Cheers Thomas Edit: Just noticed that Dieter already gave you an answer. RE: Adapting 'Accurate' TVM routine on HP-15C using MISO Technique - Dieter - 01-11-2014 03:48 PM (01-11-2014 05:53 AM)Thomas Klemm Wrote: ENTER...and one additional X<>Y afterwards. This is even one step shorter: ... RCL 3 X<>Y * LastX ... Dieter RE: Adapting 'Accurate' TVM routine on HP-15C using MISO Technique - Thomas Klemm - 01-11-2014 04:11 PM (01-11-2014 03:48 PM)Dieter Wrote: This is even one step shorter:Nice catch! Updated my listing. Cheers Thomas RE: Adapting 'Accurate' TVM routine on HP-15C using MISO Technique - Jeff_Kearns - 01-11-2014 04:26 PM (01-11-2014 04:11 PM)Thomas Klemm Wrote: Nice catch! Updated my listing. And I mine - in the software section! Jeff RE: Adapting 'Accurate' TVM routine on HP-15C using MISO Technique - Dieter - 01-11-2014 06:25 PM (01-11-2014 04:11 PM)Thomas Klemm Wrote: Nice catch! Updated my listing. Now let's see if we can do something with the %-function instead of dividing x by 100. ;-) Dieter |
