arg() crashes the emulator - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: arg() crashes the emulator (/thread-3151.html) Pages: 1 2 |
RE: arg() crashes the emulator - Angus - 02-25-2015 04:25 PM Good You Pointed that out! Totally my fault I was mislead by the exact. Problem solved. Thanks RE: arg() crashes the emulator - salvomic - 02-25-2015 07:01 PM (02-25-2015 02:54 PM)Han Wrote: Based on what I can observe, both return and RETURN are used to return a value; however, RETURN will also exit the current function/procedure whereas return does not. As for return 0 vs. return(0), I believe this is the same. Now I understand because a program of mine didn't work: with return it didn't exit... Thank you, Han. I'll amend it with uppercase. RE: arg() crashes the emulator - salvomic - 02-25-2015 07:22 PM (02-25-2015 02:54 PM)Han Wrote: Also: Code:
end with 10 but Code:
So, return (lowercase) pass a value to the rest of the program, isn't it? |
