HP Prime CAS programming - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: HP Prime CAS programming (/thread-3149.html) Pages: 1 2 |
RE: HP Prime CAS programming - roadrunner - 08-29-2020 11:25 AM Have you tried: CMD1:="diff(3*x^2+5*x,x,1)" or CAS.diff("3*x^2+5*x,x,1") Both return 6*x+5 for me. -road RE: HP Prime CAS programming - ramon_ea1gth - 08-29-2020 07:13 PM (08-29-2020 11:25 AM)roadrunner Wrote: Have you tried:Good point. In fact I left on purpose the example with the two "different" results, so it is possible to quickly imagine alternatives like yours or, e.g., if you implement a custom CAS function to be called this way, add an extra simplify() command if needed. |
