HP 30b: Bug in Student function? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 30b: Bug in Student function? (/thread-2403.html) Pages: 1 2 |
RE: HP 30b: Bug in Student function? - John Smitherman - 01-04-2015 04:25 PM Hi Gerald. For the problem you've stated I used the following key sequence: 5 Input 1.677 Math (shift /) Probability (down arrow, down arrow, Input) Student (down arrow, down arrow) The result is Student 0.923 I hope that helps. Regards, John RE: HP 30b: Bug in Student function? - Gerald H - 01-04-2015 06:10 PM (01-04-2015 04:25 PM)John Smitherman Wrote: Hi Gerald. For the problem you've stated I used the following key sequence: This indeed gives the correct answer. Should you then SWAP the two values in the stack & then SWAP them a second time & repeat the calculation the answer is wrong. Also, if values are recalled & the calculation carried out in a programme the answer is again wrong. RE: HP 30b: Bug in Student function? - John Smitherman - 01-05-2015 01:51 AM You're experiencing the vagaries of the HP 30B's stack. This has been discussed several times in this forum. A search should turn up several threads. John RE: HP 30b: Bug in Student function? - Gerald H - 01-05-2015 06:28 AM (01-05-2015 01:51 AM)John Smitherman Wrote: You're experiencing the vagaries of the HP 30B's stack. This has been discussed several times in this forum. A search should turn up several threads. Try a Programme that recalls memory 1 & then memory 2 then calculates ltpt - you will find the answer is wrong. This seems unconnected with "vag¢ries" oft the stack. RE: HP 30b: Bug in Student function? - walter b - 01-05-2015 03:58 PM (01-05-2015 06:28 AM)Gerald H Wrote:(01-05-2015 01:51 AM)John Smitherman Wrote: You're experiencing the vagaries of the HP 30B's stack. This has been discussed several times in this forum. A search should turn up several threads. @ Tim W.: Isn't that observation something for you to comment? d:-? RE: HP 30b: Bug in Student function? - Gerald H - 01-06-2015 02:52 PM To summarise the state of play: Some say yes, this a bug; Some are non-commital, saying under certain circumstances the answer is correct & seemingly ignoring the bug question; Some want others to give opinions; And yes, the Great Majority are silent. RE: HP 30b: Bug in Student function? - Katie Wasserman - 01-06-2015 03:15 PM (01-06-2015 02:52 PM)Gerald H Wrote: And yes, the Great Majority are silent. The great majority reading the forum don't use the HP-30b as a 30b but as a WP-34s and may never have even tried the native functions on it before they loaded the replacement firmware. RE: HP 30b: Bug in Student function? - walter b - 01-06-2015 03:39 PM (01-06-2015 03:15 PM)Katie Wasserman Wrote: The great majority reading the forum don't use the HP-30b as a 30b but as a WP-34s and may never have even tried the native functions on it before they loaded the replacement firmware. This great majority makes a statement HP should notice and take into account IMHO. “The success and prosperity of our company will be assured only if we offer our customers superior products that fill real needs and provide lasting value, and that are supported by a wide variety of useful services, both before and after sales.” At least the "after sales" customer support seems to be significantly better on the WP side. It's a shame when you remember old HP. d:-/ RE: HP 30b: Bug in Student function? - Thomas Radtke - 01-06-2015 04:24 PM (01-06-2015 02:52 PM)Gerald H Wrote: And yes, the Great Majority are silent.Is this a poll about that bug being a bug? ;-) Seriously, I think financial models are of interest to only a few members. RE: HP 30b: Bug in Student function? - Gerald H - 01-06-2015 04:52 PM (01-06-2015 04:24 PM)Thomas Radtke Wrote:(01-06-2015 02:52 PM)Gerald H Wrote: And yes, the Great Majority are silent.Is this a poll about that bug being a bug? ;-) No, not a poll. But, & here I want add weight, so I'll quote Aristotle, "Everyone has an opinion". Should I apologise for starting a thread about an unworthy financial calculator? If not here, where? Still, thanks for opining (implicitly) it is a bug. RE: HP 30b: Bug in Student function? - Thomas Radtke - 01-06-2015 06:19 PM (01-06-2015 04:52 PM)Gerald H Wrote: Should I apologise for starting a thread about an unworthy financial calculator?Sorry, I just tried to explain the silence. Of course, the 30b is on-topic in this forum. [Edited to replace 20b for 30b] RE: HP 30b: Bug in Student function? - lrdheat - 02-15-2016 12:19 AM I checked this on the Prime...the HP 30b, when the = or other keystroke is entered is allowing (as with the Prime), decimal degrees of freedom, and is calculating cum from 0 to 1.677 for 1.677 degrees of freedom (to arrive at .8706... ). Why it does so is odd? RE: HP 30b: Bug in Student function? - lrdheat - 02-15-2016 12:35 AM Correction....cum from -infinity to 1.677. RE: HP 30b: Bug in Student function? - Dieter - 02-15-2016 06:56 AM (02-15-2016 12:19 AM)lrdheat Wrote: I checked this on the Prime...the HP 30b, when the = or other keystroke is entered is allowing (as with the Prime), decimal degrees of freedom, and is calculating cum from 0 to 1.677 for 1.677 degrees of freedom (to arrive at .8706... ). Why it does so is odd? What exactly is odd here? Non-integer degrees of freedom can be handled easily as the Student CDF can be expressed by the Incomplete Beta function. The 34s also returns 0,8706432972715508 here. Dieter RE: HP 30b: Bug in Student function? - lrdheat - 02-15-2016 02:57 PM Odd referring to why the 30b is using 1.677 for X and n when a key such as = is pressed before going into the menu tree to find the answer in the example... |
