is the HP 17bII+ Financial Calculator being discontinued? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: is the HP 17bII+ Financial Calculator being discontinued? (/thread-21301.html) |
is the HP 17bII+ Financial Calculator being discontinued? - HP-12C - 02-16-2024 08:51 PM Hi is the HP 17bII+ Financial Calculator being discontinued? I've noticed some stores in Australia listing the 17bII+ as clearance stock RE: is the HP 17bII+ Financial Calculator being discontinued? - rprosperi - 02-17-2024 02:25 AM Nothing has been announced to date; hopefully Moravia can comment. I've found that many retailers simply say this when they are out of stock or nearly so, for example when that particular chain will stop selling a model. Have you seen the same behavior from multiple different chains? RE: is the HP 17bII+ Financial Calculator being discontinued? - HP-12C - 02-17-2024 05:42 AM Hi Bob thank you for the response, yes I have seen this from two different stores. I did wonder rather cynically, if it was just a way of moving stock on before the next shipment arrives as I have seen this also with the 12C and then after awhile the stock clearance label disappears. |
