Contour Integral - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-41C Software Library (/forum-11.html) +--- Thread: Contour Integral (/thread-20833.html) |
Contour Integral - Marcel - 11-12-2023 07:22 PM Hi! I upload a document with the same program from the Advanced Functions Handbook for the HP 15C to approximate the Contour Integral of a complex Function F(z). The same example function is also program under the label FZ. The evaluation take 17 minutes 11 seconds! Brian Zilli do a general form with the same example function for the HP 15C. The HP 41C can do the math like the HP 15C! (With more time...) Marcel RE: Contour Integral - Ángel Martin - 02-25-2024 09:31 AM Thanks for putting this one together, nicely done indeed. I have made a few tweaks that save some bytes and eliminate one global label. Plus also used the 41Z functions instead of the FOCAL routines from the Advantage, which make the code better legible and reduces execution time. The resulting code is posted below. This application is somewhat limited to (non-horizontal) straight line segments for contours, I've been musing about a general-purpose implementation using the residues theorem and analytical functions but so far the challenge is not resolved... would like to hear if anybody has some suggestions. Code: 01 LBL “ZLITG” Cpx. Line Intg. and the complex function example: Code: 01 LBL “FZ” Usage: set the desired accuracy (i.e. FIX 3), enter the complex function LABEL in ALPHA (i.e. "FZ"), and the lower and upper complex limits in the complex stack (i.e. 0, ENTER^, 1, ZENTER^, 6, ENTER^, 1). Then execute the program (i.e. XEQ "ZLITG") Result in FIX 6: -0.324350+J0.382053 Best, ÁM RE: Contour Integral - Marcel - 02-25-2024 08:06 PM Hi Ángel! Thank you for your comment! Can you post the running time for your version with the same exemple.. Marcel RE: Contour Integral - Ángel Martin - 02-25-2024 09:57 PM Hi Marcel, I haven't used it on a real machine yet, but on V41 with default settings it took 4 min and 22 sec with a FIX3. Using TURBO however it takes just above 17 seconds - but of course that would be cheating :=) BTW I just noticed your mention to Brian Zilli - can you elaborate on that? I'd be curious to check other examples as well. Cheers, ÁM RE: Contour Integral - Marcel - 02-25-2024 10:50 PM Hi again! This post. Marcel RE: Contour Integral - Ángel Martin - 02-26-2024 07:43 AM (02-25-2024 10:50 PM)Marcel Wrote: This post. Thanks, I had completely missed that thread and it's well worth a detailed read. Here's my take at the updated programs, using an initial data entry section and a runtime execution entry point at LBL C (*) PMTA is available in the OS/X modules Code: 01 LBL "ZCNTR" main driver program as well as the parameterized curves z(t) and z'(t) - The routine for f(z) is the same one used in the initial program, see the second post in this thread. Code: 01 LBL "ZT" parameterized z The results obtained are the same as those presented in Brian Zilli's paper. Enjoy! |
