RE: What are good PRNG for calculators? - John R. Graham - 09-01-2014 07:00 PM
(08-22-2014 02:16 PM)Namir Wrote: (08-22-2014 01:45 PM)John R. Graham Wrote: ...On the "less than short" side, just for fun I implemented the Mersenne Twister on my HP 50g.
Listing for the HP-50G implementation?
Namir
Attached. Sorry for the delay. Short operating instructions:
- Run Start to create the state variable structure.
- Run SeedN or SeedT one or more times to seed the PRNG. SeedN takes a numeric argument but SeedT fetches a little bit of real entropy from the TICKS variables and uses that as a seed. You can seed the PRNG up to 624 times, which completely fills out the state variable, but typically you would seed it once, or just a few times.
- Run Init to fully initialize the state variable and prepare the PRNG for use.
- Use MtRnB or MtRnR to retrieve pseudo-random numbers. MtRnR returns traditional HP pseudo-random numbers (0 < n < 1) with 32 bits of precision. MtRnB returns the native 32-bit binary numbers that Mersenne Twister produces.
This implementation has been tested against the Math::Random::MT Perl library available from CPAN and demonstrated to produce identical results through 5,000 iterations.
- John
RE: What are good PRNG for calculators? - ttw - 09-04-2014 04:41 AM
The appropriate PRNG for a calculator depends on the problem being solved. Computing an integral is quite different from playing a game or trying to encrypt something.
RE: What are good PRNG for calculators? - John R. Graham - 09-06-2014 05:55 PM
When do you think it's inappropriate to use a really good PRNG? The only contraindication I can think of that is potentially valid is if the resource requirements and/or execution time is onerous on the platform.
- John
RE: What are good PRNG for calculators? - ttw - 09-06-2014 06:03 PM
(09-06-2014 05:55 PM)John R. Graham Wrote: When do you think it's inappropriate to use a really good PRNG? The only contraindication I can think of that is potentially valid is if the resource requirements and/or execution time is onerous on the platform.
- John
A quasi-random generator is never worse when evaluating a (Riemann) integral. This is in terms of error-bounds rather than error estimates. Of course, QRNGs are useless (in general) for cryptography or in other cases where non-predictability is needed (in a gaming machine, for example.)
It's a bit more work to use QRNGs but the payoff can be big. The analysis is more like that of using traditional integration formulas.
RE: What are good PRNG for calculators? - John R. Graham - 09-06-2014 07:05 PM
Interesting. What form does the payoff come in?
- John
RE: What are good PRNG for calculators? - jdimijian - 11-05-2014 11:02 AM
(08-21-2014 07:05 PM)Thomas Klemm Wrote: (08-21-2014 03:25 PM)Namir Wrote: So saying that the Rand# in the HP-15C is very good does not count, because it is already hardwired in the firmware.
This Python program simulates the RAN# function of the HP-15C:
seed = 7365289446 # or any other number
def rand():
global seed
seed = (1574352261 * seed + 1017980433) % 10000000000
return seed
Of course in the HP-15C the value will be e.g. 0.7365289446 instead.
PS: It's similar in the HP-48. How RAND Works
Hi Thomas,
I'm so glad to find these 2 figures for the first time on the web ! 1017980433 and 1574352261.
I have a HP11C (now, I use an emulator on my iPhone) and I searched in the late 80's how the RAN function was generated. I finished to find an algorithm (not this you are using, but doing partial additions) and revealing these 2 figures.
I have programmed it in Turbo Pascal and used this as a Benchmark programm for the PCs (I was interested by numeric simulations).
Today, when I need a rand function, I always use this agorithm :-)
And you, where and how did you find it ?
Regards.
Joseph.
RE: What are good PRNG for calculators? - Thomas Klemm - 11-05-2014 05:05 PM
(11-05-2014 11:02 AM)jdimijian Wrote: Hi Thomas,
Not affiliated with HP but I used the trace produced by the Nonpareil emulator of the HP-15C. IIRC you have to build the project with the correct settings. Then you can enable it via Debug -> ❐ Trace.
The output is huge but there's the assembler instruction lc to load a constant. Here's the part where 1574352261 is loaded:
06120: 0120 lc 1
cycle 2122 P=b q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1000000000000
06121: 0520 lc 5
cycle 2123 P=a q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1500000000000
06122: 0720 lc 7
cycle 2124 P=9 q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1570000000000
06123: 0420 lc 4
cycle 2125 P=8 q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1574000000000
06124: 0320 lc 3
cycle 2126 P=7 q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1574300000000
06125: 0520 lc 5
cycle 2127 P=6 q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1574350000000
06126: 0220 lc 2
cycle 2128 P=5 q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1574352000000
06127: 0220 lc 2
cycle 2129 P=4 q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1574352200000
06130: 0620 lc 6
cycle 2130 P=3 q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1574352260000
06131: 0120 lc 1
cycle 2131 P=2 q=4 carry=0 stat=.........9....
a=00000000000000 b=02592332694000 c=f1574352261000
And then I tried to figure out from the code and the rest of the trace what's going on. Fortunately it turned out not to be very complicated. On the basis of my posts it took me about two hours.
But I was not the first one to find these numbers:
Le Compte est bon - The Total Is Right - Numbers
*& Form HP11C_RAND *
FORM hp11c_rand USING value(p_lim_haute) TYPE i
CHANGING p_tirage TYPE i.
CONSTANTS : kincr TYPE p LENGTH 10 VALUE '1017980433',
kbase TYPE p LENGTH 10 VALUE '1574352261',
k10e10 TYPE p LENGTH 10 VALUE '10000000000'.
DATA : lseed TYPE i.
IF next = 0.
IF ppartie = 0.
CALL FUNCTION 'GENERAL_GET_RANDOM_INT'
EXPORTING
range = 100000000
IMPORTING
random = lseed.
next = lseed.
ELSE.
next = ppartie * 10000.
ENDIF.
ENDIF.
next = ( next * kbase + kincr ) MOD k10e10.
p_tirage = TRUNC( next / k10e10 * ( p_lim_haute + 1 ) ).
ENDFORM. " HP11C_RAND
How did you find these numbers?
RE: What are good PRNG for calculators? - Namir - 11-05-2014 08:23 PM
(11-05-2014 05:05 PM)Thomas Klemm Wrote: (11-05-2014 11:02 AM)jdimijian Wrote: Hi Thomas,
06120: 0120 lc 1
06121: 0520 lc 5
06122: 0720 lc 7
06123: 0420 lc 4
06124: 0320 lc 3
06125: 0520 lc 5
06126: 0220 lc 2
06127: 0220 lc 2
06130: 0620 lc 6
06131: 0120 lc 1
IF next = 0.
IF ppartie = 0.
EXPORTING
range = 100000000
IMPORTING
random = lseed.
next = lseed.
ELSE.
ENDIF.
ENDIF.
According to the literature the modulo number should be 2^P or 2^P-1 for some P value. My guess is that using 10^Q would produce poor values.
Namir
RE: What are good PRNG for calculators? - Gilles - 11-05-2014 09:37 PM
Here is a small program to "display" random numbers on the screen of the HP PRIME...
EXPORT PRNG()
//R:=FP(9821*R+0.211327);
//R:=FP((PI+R)^5);
//R:=FP(997*R);
R:=FP(123*R);
EXPORT PRNG_DSP(A)
RECT();
FOR I:=1 TO A DO
PIXON_P(320*PRNG,240*PRNG);
FREEZE;
This program can't assure you that your PRNG program is a good one, but it can show you that it is bad ;D for example FP(123*R)
Don't forget to initialise R with a 0.xxxxxxx number , then :
PRNG_DSP(10000)
or TIME(PRNG_DSP(10000)) to evaluate the complexity of the algorithm
RE: What are good PRNG for calculators? - brouhaha - 11-05-2014 09:51 PM
(08-25-2014 05:15 PM)Marcus von Cube Wrote: The TI SR-51(A) has a RAN# function that returns a two digit random number. I couldn't find more info about it but I have the feeling that it's not a pseudo random number generator but a real random number function. Can someone confirm this? To support my assumption, there is no seed function.
I expect it's a PRNG. There's no RNG hardware in the 51, so the only source of "random" numbers would be timing of key presses, and they can't get enough bits of entropy from a single key press for a two digit number. During a running program, using RAN# repeately would have no entropy input, so even if they time keypresses it would only be useful as a seed.
If the RAN# doesn't give the same results after each power-up, that could be due to not initializing the storage for the PRNG, which would act as a semi-random seed, though the entropy content would be very low.
RE: What are good PRNG for calculators? - Thomas Klemm - 11-06-2014 12:06 AM
(11-05-2014 08:23 PM)Namir Wrote: According to the literature the modulo number should be 2^P or 2^P-1 for some P value.
[citation needed]
Quote:My guess is that using 10^Q would produce poor values.
These numbers fulfill the three requirements of the Hull-Dobell Theorem:
- c = 1017980433 and m = 10000000000 are relatively prime
- a - 1 = 1574352260 is divisible by all prime factors of m = 10000000000: 2 and 5
- a - 1 = 1574352260 = 4*393588065 is a multiple of 4 if m = 10000000000 is a multiple of 4.
Thus we can conclude to have maximal period.
RE: What are good PRNG for calculators? - jdimijian - 11-06-2014 09:36 AM
06120: 0120 lc 1
06121: 0520 lc 5
06122: 0720 lc 7
06123: 0420 lc 4
06124: 0320 lc 3
06125: 0520 lc 5
06126: 0220 lc 2
06127: 0220 lc 2
06130: 0620 lc 6
06131: 0120 lc 1
IF next = 0.
IF ppartie = 0.
EXPORTING
range = 100000000
IMPORTING
random = lseed.
next = lseed.
ELSE.
ENDIF.
ENDIF.
LOL ! The program extract that you have found is mine, it's written in ABAP (SAP development language)and as I told you, I use it every time I need random function.
It took me several years to find the algorithm, I was knowing nothing about these aglorithms and there was no Internet at this time ;-)
I was able to progress and find because I could fix the seed, I realized very soon that between 2 runs, the last digit (that is hidden but can appear with f-prefix) was incremented by 3. I explored this fact and progressively found all the stuff (without guessing that there is a simple multiplication !).
But today, knowing the existing algorthms, and having 2 or 3 successive random numbers, we can easyly retreive the different numbers.
Thanks for your attention Thomas.
Best regards.
Joseph.
RE: What are good PRNG for calculators? - Thomas Klemm - 11-06-2014 08:03 PM
(11-06-2014 09:36 AM)jdimijian Wrote: But today, knowing the existing algorthms, and having 2 or 3 successive random numbers, we can easyly retreive the different numbers.
CLx
STO RAN#
RAN#
PREFIX
1017980433
STO 0
EEX 10 CHS
STO RAN#
RAN#
RCL - 0
PREFIX
1574352261
RE: What are good PRNG for calculators? - Shawn Gibson - 11-12-2014 02:03 PM
I seem to recall early personal computers that created a random number in a game/program by using a very fast counter and the most random thing in the room.. a human. When the human presses the key it grabs whatever the number that the counter was set to, at the time of the keypress.
Shawn
RE: What are good PRNG for calculators? - Gerald H - 11-13-2014 10:52 AM
- John
Should you wish to eg find the area under a curve you would also want to avoid clumping, which clumping is a characteristic of a good PRNG. For such applications a Quasi Monte Carlo sequence of D-dimensional Halton sequence vectors is preferable, providing good spread within the set lower & upper limits & avoiding clumping.
For eg crypto purposes, QMCS is not so good.
In short, there are some uses where real randomness approxination is not the chief criterion of efficacy.
RE: What are good PRNG for calculators? - Namir - 11-14-2014 01:41 PM
(11-13-2014 10:52 AM)Gerald H Wrote: (09-06-2014 05:55 PM)John R. Graham Wrote: When do you think it's inappropriate to use a really good PRNG? The only contraindication I can think of that is potentially valid is if the resource requirements and/or execution time is onerous on the platform.
- John
Gerald,
You are the first person who discusses the negative aspects of very good PRNGs! It is very easy to have poor PRNGs and hard to develop good ones.
BTW .. I love your city and plan to visit my beloved Vienna in the fall of 2015. My wife and I usually stay at the Astoria hotel near the Opera house.
