HP-97 Card Reader install tool - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-97 Card Reader install tool (/thread-17782.html) |
HP-97 Card Reader install tool - wbvreeuwijk - 12-03-2021 08:34 AM Hi All, I recently revised an HP-97 and before removing the card reader I took a few measurements and designed an install tool so that when I was going to re-assemble it would be in the right position. Should you need something similar and have a 3D printer available please have a look here: https://www.thingiverse.com/thing:5153770/files [attachment=10121] Regards, Bas RE: HP-97 Card Reader install tool - Dreato - 12-03-2021 11:33 PM Thanks - this is super useful! I'm printing one tonight. Regards, Dave RE: HP-97 Card Reader install tool - GreyUser - 12-04-2021 12:21 AM For those without a 3D printer, match marking the three screw positions on the base of the card reader with a paint marker and returning the reader to the same position works every time ;-) RE: HP-97 Card Reader install tool - teenix - 12-04-2021 01:39 AM Also, from what I have seen the screws leave an indent in the plastic so is easy to refit. The tool is nice however. cheers Tony RE: HP-97 Card Reader install tool - wbvreeuwijk - 12-04-2021 05:01 AM Hi Dave, Let me know if it works for you, so I can adjust the design if needed. Regards, Bas (12-03-2021 11:33 PM)Dreato Wrote: Thanks - this is super useful! RE: HP-97 Card Reader install tool - wbvreeuwijk - 12-04-2021 05:04 AM Yes, that's what I should have done on the first HP-97 that I disassembled :-) (12-04-2021 12:21 AM)GreyUser Wrote: For those without a 3D printer, match marking the three screw positions on the base of the card reader with a paint marker and returning the reader to the same position works every time ;-) |
