Multicalc Update - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Multicalc Update (/thread-16973.html) |
Multicalc Update - teenix - 05-18-2021 11:02 PM Hi all, For those using Haralds version of the MultiCalc project for Classic CPU board replacements, there is a new update available at http://www.teenix.org. The decimal point was not showing properly for the HP-3x models. cheers Tony RE: Multicalc Update - Harald - 05-19-2021 10:52 AM Thanks for the update Tony! I can't believe this has been overlooked for so long, so I think there were versions that didn't have this issue. I am curious about this, so could users report which version they are running and if the problem exists or not? Depending on wich version you have, it might be necessary to press the "shift" key while clicking on the "write" button in Tonys PC software. Cheers, Harald RE: Multicalc Update - AndiGer - 05-19-2021 03:54 PM I tried HP-34C. Didn't find an issue. @Tony: It appears only in specific situations? I think I have the original version running as file dsplab.dat is dated 01.07.2016 About tells me v040118 RE: Multicalc Update - Harald - 05-19-2021 06:34 PM I have found one calculator with old firmware as well. This one is displaying the decimal point as decimal and thousands separator. Is that what you have got also? I guess the plan was to display a space as thousands separator. That plan probably went wrong and we ended up with all spaces. Tony has fixed that now. RE: Multicalc Update - AndiGer - 05-19-2021 06:48 PM [attachment=9489] RE: Multicalc Update - Harald - 05-19-2021 07:18 PM Oh, this is a misunderstanding. This is a problem with the PCB that gets installed in a classic calculator only. Sorry for the confusion, should have noticed you were talking about the PC emulator in your original post. Cheers, Harald RE: Multicalc Update - teenix - 05-19-2021 11:39 PM (05-19-2021 10:52 AM)Harald Wrote: Depending on wich version you have, it might be necessary to press the "shift" key while clicking on the "write" button in Tonys PC software. This not required anymore as the type of upgrade is now embedded in the PIC hex file and is sorted automatically during the upgrade process. cheers Tony |
