12c problems with display - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: 12c problems with display (/thread-16668.html) |
12c problems with display - antondel - 04-16-2021 12:10 PM Hello everyone. I don't know if there is such a topic on the forum, I could not find a solution to my problem. My 12C doesn't fully show the 5th and 7th digits. I rebooted it, changed the batteries, turned it off for a day and nothing helped. It's new, I bought it in a sealed box. How to solve this problem? Help me please! RE: 12c problems with display - rprosperi - 04-16-2021 04:47 PM (04-16-2021 12:10 PM)antondel Wrote: Hello everyone. I don't know if there is such a topic on the forum, I could not find a solution to my problem. My 12C doesn't fully show the 5th and 7th digits. I rebooted it, changed the batteries, turned it off for a day and nothing helped. It's new, I bought it in a sealed box. How to solve this problem? Help me please! Get your money back! Demand a full refund as this unit is defective. You will be much happier buying an old 12C (made in USA or Brazil are best, Singapore not too bad) on eBay or from a local auction site. The old units are not as fast as the new production units, but feel better and will almost certainly outlive a new production unit from China. RE: 12c problems with display - antondel - 04-17-2021 03:57 PM Thanks for the answer. But I cannot return it, as I bought it in another country. RE: 12c problems with display - rprosperi - 04-17-2021 05:37 PM I'm not aware of any way to restore the digits in the display of your device; even some brand-new units from China seem to have these problems, most likely due to poor build and QA problems. It's too bad you can't get a refund... But the good news is you can find used ones really cheap, here's one that costs < $17 with shipping included. https://www.ebay.com/itm/VINTAGE-Hewlett-Packard-HP-12C-Financial-Calculator-Gold-Case-Working-Batteries/143993813260 It's not perfect, but for probably $5 more you can get one that's close. Typically, more than 10 12Cs are listed on eBay every day, so there are always plenty to choose from. RE: 12c problems with display - Gamo - 04-18-2021 03:58 AM Keep this defective one just in case it can be use as a spare parts. I'm personally like the HP-12C Platinum (made in Philippines) and the HP-12C (made in Singapore) both of this calculators work flawlessly to me. Gamo RE: 12c problems with display - antondel - 05-05-2021 09:12 AM Hello everyone! I solved my problem. I opened the calculator and inside with a soldering iron I warmed up the loop that connects the screen. You can see it in the photo. Warmed up through a piece of paper. The numbers all appeared. Hopefully someone can help this way to repair his calculator. RE: 12c problems with display - Dreato - 05-05-2021 03:40 PM Nice fix! Good for you! RE: 12c problems with display - rbt.lzo - 07-24-2023 08:30 PM (05-05-2021 09:12 AM)antondel Wrote: Hello everyone! I solved my problem. I opened the calculator and inside with a soldering iron I warmed up the loop that connects the screen. You can see it in the photo. Warmed up through a piece of paper. The numbers all appeared. Hopefully someone can help this way to repair his calculator. Apologies for reviving an old thread, but... this worked for me! My display only had a few segments working but, after about 30 minutes off and on with the soldering iron, they've all been reactivated. RE: 12c problems with display - Divasson - 07-26-2023 10:16 AM Calculators arrived and starting to send to customers!!! [attachment=12352] RE: 12c problems with display - MarkB - 07-26-2023 10:44 AM (07-26-2023 10:16 AM)Divasson Wrote: Calculators arrived and starting to send to customers!!! Wrong thread? ? RE: 12c problems with display - Maximilian Hohmann - 07-26-2023 10:50 AM (07-26-2023 10:44 AM)MarkB Wrote: Wrong thread? ? Hopefully! Otherwise I may be unpacking an HP-12C soon... RE: 12c problems with display - Massimo Gnerucci - 07-26-2023 12:14 PM (07-26-2023 10:50 AM)Maximilian Hohmann Wrote:(07-26-2023 10:44 AM)MarkB Wrote: Wrong thread? ? Yep! Not another one, please. RE: 12c problems with display - linq2008 - 07-27-2023 02:53 AM HP 15C CE (07-26-2023 10:16 AM)Divasson Wrote: Calculators arrived and starting to send to customers!!! |
