[VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math" - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math" (/thread-16244.html) |
RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - C.Ret - 02-28-2021 09:35 AM Ah! Ah! Many Thanks to Valentin for this good puzzle and the good explanation and pointing out the fact that the graph is not exactly a circle. I didn't notice it and was wandering why I was unable to factorize Po(x,y) even with the correct equation of the expected, but outfitted circle equation. By the fact, checking whenever the graph is or isn’t a true circle is so easy by entering its equation in the Advanced Graphic Application of the HP Prime and zoom enough to get a good view of the disparity: [attachment=9151] Fig.: Po(x,y) black Circle green. How Can I have miss verifying this weird fact ? RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - J-F Garnier - 02-28-2021 10:32 AM Now that the challlenge is closed, let me add some comments: (02-28-2021 02:18 AM)Valentin Albillo Wrote: My original solution for "Concoction the Third: Weird Integral" Quote:The Sleuthing First, would you have used the Enhanced Math ROM, you could have just typed: >INTEG(1,P,0,GAMMA(LN(P^2-IX))/(GAMMA(LN(IX))+GAMMA(LN(P^2-IX)))) [ENDLINE] After all, you are the one who suggested the use of such shortcuts As I mentioned in my solution, the first aspect I noticed was the speed; I wasn't expecting to get a fast answer on a physical calculator of the 32S class for such complicate-looking equation combining the gamma and log functions. I also noticed that the speed and the answer were independent of the target accuracy (set by the display mode on the 32S - from FIX 1 to FIX 11). That was really weird. BTW, using a slow machine sometimes highlights some aspects that can be missed on faster systems such as Free42. Moving to the HP-71/Emu71, I investigated more: 30 Y=0 @ A=0 @ F=(1+SQR(5))/2 60 DEF FNF(X) 70 A=GAMMA(LN(F*F-X)) @ Y=A/(GAMMA(LN(X))+A) 90 PRINT X;Y 100 FNF=Y 110 END DEF 130 E=.0001 140 DISP INTEGRAL(1,F,E,FNF(IVAR)) 150 END >RUN 1.30901699438 .500000000007 1.09656781074 .169413871978 1.52146617801 .830586128022 1.19554981675 .328227901097 1.422484172 .671772098903 1.02655614795 4.82413106951E-2 1.5914778408 .951758689306 It turned out that only 7 samples were used, whatever was the target accuracy set by the E value. Having some knowledge of the Romberg algorithm, I recognized the first sample to be the midpoint, then the next two samples used for the 1st estimation and the last four samples used for the 2nd estimation. It was quickly obvious that the sample pairs (2-3, 4-5, 6-7) gave values that sum to exactly 1. That gave me the key for the explanation of the speed: the summation for any sample set was the same (and the exact one), so the algorithm reached its termination condition after the first two estimations. Extrapolating to a single sample at the midpoint, I got the symbolic answer: (φ-1) x 1/2 This is of course a consequence of the symmetry of the function to integrate as Werner and Valentin explained. It is interesting to note that my observations had also to do with the HP implementation of the Romberg algorithm: although the samples are non-uniform, they are symmetric relative to the midpoint, and that gave the effect I reported. Thanks for the challenge that was at the intersect of my interests for math puzzles and numerical algorithms (such as used in HP machines). J-F RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - Albert Chan - 02-28-2021 01:21 PM (02-18-2021 09:28 AM)Werner Wrote: The key to the value of the integral in #3 is to realize that the integral is symmetric in the integral boundaries. Basically it is Without noticing the symmetry, if we "fold" the integral, we get the same result. Let f(x) be integrand of above integral. I = ∫(f(x), x = 1 .. φ) = ∫(f(x) + f(1+φ-x), x = 1 .. φ) / 2 = ∫(f(x) + f(φ²-x), x = 1 .. φ) / 2 = ∫(1, x = 1 .. φ) / 2 = (φ-1)/2 RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - robve - 03-01-2021 01:19 AM Some additional comments on concoction five. First, the HP PRIME HPPL program with the Sieve of Eratostenes is the smart way to approach this problem efficiently. Unfortunately, sieving for primes above 20,000 or so becomes tricky, due to HPPL list length restrictions to 20,000. One could populate the list with 64 bit integers and use bit banging to increase the prime sieving space 64 fold, which is just enough to find the first 5 perfect primes. Without sieving is straightforward to implement with a few loops, but slow and takes a few minutes rather than seconds (e.g. compared to C). The program hunts for perfect primes within designated bounds B and E: EXPORT SLOWPP() BEGIN LOCAL B,D,E,F,I; LOCAL J,K,P,Q; // BEGIN SEARCH AT B B := 11; // END SEARCH AT E E := 9999999; FOR P FROM B TO E STEP 2 DO IF isprime(P) THEN M := FLOOR(LOG(P)); F := 1; FOR J FROM 0 TO M DO I := 10^J; // Q = P WITH JTH DIGIT SET TO 0 Q := FLOOR(P/I/10)*I*10+ROUND(FP(P/I)*I); // D = JTH DIGIT OF P (0 to 9) D := FLOOR(P/I) MOD 10; FOR K FROM 0 TO 9 DO IF K <> D AND isprime(Q+K*I) THEN F := 0; BREAK; END; END; IF F=0 THEN BREAK; END; END; IF F THEN PRINT("PERFECT "+P); END; END; END; END; Hence, hereby my alternative submission in HPPL. Second, I stated that theoretically more perfect primes should exist for bases smaller than 10 and also gave a list of the first base-perfect primes for base 2 to 20. Running additional experiments corroborates this claim empirically verified for primes up to 1,000,000,000 (with a small modification made to the C program): base | PP count | 2 | 7179981 | 3 | 10070244 | 4 | 1521240 | 5 | 7627392 | 6 | 12456 | 7 | 3762873 | 8 | 98926 | 9 | 400411 | 10 | 3167 | 11 | 1018816 | 12 | 37 | 13 | 558553 | 14 | 403 | 15 | 2821 | 16 | 743 | 17 | 153894 | 18 | 0 | An interesting pattern emerges, which shows something else, besides the frequency of base-perfect primes is higher for smaller bases as expected. Note that prime base perfect primes are more prevalent. EDIT Try it yourself: my C program to find PPs for any base for the given max: #include <stdio.h> #include <stdlib.h> #include <math.h> int main(int argc, char **argv) { if (argc > 2) { long i, j, k; long base = atoi(argv[1]); // perfect prime base double lnbase = log(base); long max = atoi(argv[2]); // primes up to max (exclusive) long maxd = 0; // primes of maxd digits long num = 0; // number of perfect primes found long len = 0; // length of the array char *sieve; // the sieve array (0 = composite, 1 = prime) // make max odd, e.g. 1000000000 -> 99999999 has 9 digits to perturb, not 10 max -= !(max & 1L); // len = base^maxd for maxd>0 such that len >= max do len = pow(base, ++maxd); while (len < max); sieve = (char*)malloc(len); // init sieve, we should keep only odd values for (i = 0; i < len; ++i) sieve[i] = (i & 1L); // sieve for primes for (i = 3; i < len; i += 2) { while (i < len && sieve[i] == 0) ++i; for (j = 2*i; j < len; j += i) sieve[j] = 0; } // sieve for perfect primes for (i = 3; i < len; i += 2) { while (i < len && sieve[i] == 0) ++i; if (i > max) break; if (i < len) { long m = floor(log(i)/lnbase); // m = number of digits of i long p = 1; // p = base^j char h = 1; // h = 1 if i is perfect // for each jth digit in prime i, from least to most significant for (j = 0; j <= m; ++j, p *= base) { // q = prime i with jth digit zero long q = i%p + i/p/base*p*base; // d = jth digit of prime i long d = i/p%base; // twiddle jth digit and check for prime for (k = 0; k < base; ++k) if (k != d && sieve[q+k*p]) h = 0; } if (h) ++num; } } printf("num=%ld\n", num); free(sieve); } else { printf("Usage: pps <BASE> <MAX>\n"); } } /EDIT - Rob RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - robve - 03-01-2021 03:03 AM (02-28-2021 02:18 AM)Valentin Albillo Wrote: [*]robve computed the integral using the HP Prime but alas, the result he posted is wrong. He also posted a BASIC program for the SHARP PC-1350 which produced the same wrong result. Anyway, thanks for trying ... Ah, that explains why I was getting nowhere with this one! Thanks for debugging my answer now that this challenge is over. Garbage in, garbage out: by putting the wrong expression in the integral the integration area did not offer any insights in what is weird about this integration. Somehow I missed the LN in the numerator of the integrand. The rest of the integrand expression was correct. Go figure... With the LN correction applied to the numerator, I noticed that the Romberg integration ran much faster this time on the SHARP PC-1350 compared to the incorrect integrand. When viewing the value of I (the iterator) I noticed that I=2 when the integration converges. Two successive trapezoidal approximations at alternating points are indistinguishable within MachEps. This means that the curve should be sufficiently close to linear between 1<=x<=phi. Plotting the integrand on the HP PRIME shows that this hunch is indeed the case: [attachment=9153] Observing 0<=f(x)=(x-1)/(phi-1)<=1 for 1<=x<=phi. Integrating this f gives the same result 0.309016994375. Analytically, the value of the integral of f between 1 and phi is: $$\frac{\phi^2-2\phi+1}{2\phi-2}=\frac{(1-\phi)^2}{2\phi-2}=-\frac{1}{2}\frac{(1-\phi)^2}{1-\phi}=\frac{\phi-1}{2}$$ Noticing this behavior of the quadrature algorithm is now (a bit late) helpful to answer what is weird about this integral. I am glad to use my trusty (albeit crusty) Romberg on the PC-1350. Also, what is the fun of doing math and calc exercises if we don't implement numerical integration ourselves? The Romberg quadrature program on the PC-1350 produces 0.3090169944 (10 digits exact) with the change X=LN(X*X-V) to line 300 to correct the integrand: 300 "F1" V=X,X=1.618033989,X=LN(X*X-V): GOSUB "GAMMA": W=Y - Rob RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - robve - 03-01-2021 07:05 PM One more observation that may be of interest. Based on the visual clue that the integrant behaves as (x-1)/(phi-1), but is not the same, it is prudent to numerically verify that the function (x-1)/(phi-1) equals or closely approximates the integrand $$ \frac{\Gamma\ln(\phi^2-x)}{\Gamma\ln x+\Gamma\ln(\phi^2-x)} $$ This can be done by listing the results of the two functions side-by-side for x between 1 and phi in increments of say 0.1 to compute the absolute or relative error of the difference between the two. We can also take the absolute difference of the two functions as the integrand and numerically evaluate the integral: $$ \int_1^\phi \left|\frac{\Gamma\ln(\phi^2-x)}{\Gamma\ln x+\Gamma\ln(\phi^2-x)}-\frac{x-1}{\phi-1}\right| dx \approx 5.66308603939\times10^{-3}$$ The value is the result on the HP PRIME. My PC-1350 Romberg integrator gives the same 5.66308E-3. Therefore, the total area of the difference between the two functions is small, but not zero. Based on the numerical results, it does not appear convincing to state that $$ \frac{\Gamma\ln(\phi^2-x)}{\Gamma\ln x+\Gamma\ln(\phi^2-x)} \stackrel{?}{=} \frac{x-1}{\phi-1} $$ They are approximate, but not equal. Function (x-1)/(phi-1) under estimates the integrand on the interval 1<=x<=phi/2 and overestimates the integrand on interval phi/2<=x<=phi by about 0.014 symmetrically: [attachment=9156] Because of this symmetry, one could argue that $$ \int_1^\phi \frac{\Gamma\ln(\phi^2-x)}{\Gamma\ln x+\Gamma\ln(\phi^2-x)} dx = \frac{\phi-1}{2} \approx 0.309016994375 $$ Furthermore, the integral of the difference is near zero $$ \int_1^\phi \frac{\Gamma\ln(\phi^2-x)}{\Gamma\ln x+\Gamma\ln(\phi^2-x)}-\frac{x-1}{\phi-1} dx \approx -1.13498070108\times10^{-13} $$ Suggesting that the over and under errors of the (x-1)/(phi-1) curve nicely cancel out over 1<=x<=phi. - Rob RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - Valentin Albillo - 03-02-2021 02:55 AM Hi all, These are my original solutions for "Concoction the Fifth: Weird Primes" and "Concoction the Sixth: Weird Year", which concludes all my original solutions for the six Concoctions in this S&SMC #25. You can follow these links to see my previously posted original solutions to: "Concoction the First: Weird Limit" "Concoction the Second: Weird Sum". "Concoction the Third: Weird Integral" and "Concoction the Fourth: Weird Graph" Note: My HP-71B code might use keywords from the JPC ROM, MATH ROM, HP-IL ROM and STRINGLX LEX file, executed on go71b, while RPN code is for the HP-42S, executed on a DM42. My original solution for "Concoction the Fifth: Weird Primes" "Consider a prime number so 'Perfectly Prime' (a PP for short) that changing any single [base 10] digit would turn it into a composite number. Write a program to compute: (a) the 5 smallest PP, (b) the first PP greater than 500 million, (c) the first PP greater than 777,777,777 and the second PP greater than 666,666,666." What's so weird about these primes? The Sleuthing The first thing to do is to write a program which will find these PP starting from any given integer, and this straightforward 4-line HP-71B program will nicely do: 1 DESTROY ALL @ INPUT K,N @ FOR P=1 TO K 2 N=FPRIM(N+2) @ N$=STR$(N) @ FOR I=1 TO LEN(N$) @ M$=N$ @ FOR D=0 TO 9 3 M$[I,I]=STR$(D) @ IF M$=N$ THEN 4 ELSE IF NOT PRIM(VAL(M$)) THEN 2 4 NEXT D @ NEXT I @ DISP P;N @ NEXT P It asks how many PP to output and the lower limit to begin the search from. Let's run it to output the 5 smallest PP, as asked. We begin at 11 as obviously no single-digit prime can be a PP: [RUN] ? 5,11 [ENDLINE] 1 294001 { PP #1 } 2 505447 { PP #2 } 3 584141 { PP #3 } 4 604171 { PP #4 } 5 971767 { PP #5 } As for the remaining questions, we proceed likewise: [RUN] ? 1,5E8 [ENDLINE] -> 1 500004469 { PP #1318 } [RUN] ? 1,777777777 [ENDLINE] -> 1 777781429 { PP #2259 } [RUN] ? 2,666666666 [ENDLINE] -> 1 666850699 { PP #1845 } 2 666999929 { PP #1846 } The Results Once the sleuthing's over, the results are as follows:
The Comments Though for a prime being a PP seems a rare occurrence (the very first one is 294001; that any do actually exist is weird), it's been proved that in fact there's an infinity of PP and what's more, a positive proportion (in terms of asymptotic density) of the primes are PP. That's weirder ! We can try to (very roughly) "guesstimate" said proportion: there are 5,761,455 primes and 334 PP less than 100 million, so the rate comes out as 0.00580 %, i.e.: one PP per ~ 17,200 primes. Going for the next order of magnitude, there are 50,847,534 primes and 3,167 PP less than 1 billion, so the rate now comes out as 0.00623 %, i.e.: one PP per ~ 16,000 primes, hence the proportion, though very small, seems to be increasing (and in any case, it's asymptotically > 0 .) Furthermore, if that wasn't weird enough, there's also a positive proportion of primes which are PPP (Perfect Prime Plus), which have the property that if any single digit is changed (including any zero among the prime's infinitely many leading zeros), then the resulting number is always composite. That's weirdest !! For instance, notice that the first PP, 294001, is not a PPP since changing, say, the second leading zero of ...000294001 results in ...010294001, which is prime. Matter of fact, even though a (much smaller, but still) positive proportion of the primes are PPP, none are yet known. Let's end these Comments by listing some peculiar PP you may find useful to check or optimize your code:
So much for Perfect Primes but there's more: you might want to try your hand at these four lingering questions (for which I won't provide answers, you'll be on your own):
The Hall of Fame This time the one expert which dealt with this Concoction the Fifth: Weird Primes is:
My original solution for "Concoction the Sixth: Weird Year" "2020 shares a very striking numeric property with many other catastrophic years [...] try and discover what simple numeric property {which can be unambiguously stated by saying that the year's number "is a (five words)"} is shared by all the aforementioned numbers, and then write a program to output a listing of all years between AD 4 and AD 5000 (both included) which have this very property. Additional questions are: (a) How many years will be listed in the output ? (b) What will be the next predicted potentially catastrophic year after 2020 ? and (c) Should we be concerned ? The Sleuthing Here, the very first thing to do is to discover the "striking numeric property" in question, which isn't as difficult as it seems because there are only so many such properties which can be unambiguously stated in just five words, e.g.: the number is a "sum of some prime numbers" does fit, but this is far too generic because every integer > 1 has that property. Many variations are possible (say "5" instead of "some" or replacing "primes" by "squares", "cubes", "factorials", etc.) One very useful heuristic is to analyze possible properties of the smallest numbers given: we first discover some property they have in common and then check if it applies to the bigger numbers as well. The numbers stated as sharing the sought-for property are 458, 662, 666, 1348, 1556, 1849 and 2020, so the smallest number is 458 and the sleuthing process begins with it. After discarding many sums of squares and cubes (e.g.: "sum of four square numbers", as every integer is a sum of four square numbers, including 02) and "sum of some prime numbers" and variations, we eventually discover that 458 = 132 + 172, a sum of exactly two non-zero squares, but regrettably 662 is not. We also notice that the numbers 13 and 17 are primes so we refine the property to "sum of some squared primes" but again that's too generic and gets us nowhere. Cutting to the chase, eventually we also notice that 13 and 17 are consecutive primes so the property becomes "sum of consecutive squared primes" (5 words!) and this time we hit the jackpot: 458 = 132 + 172 and 662 = 32 + 52 + 72 + 112 + 132 + 172, and checking the bigger numbers we readily get: 666 = 22 + 32 + 52 + 72 + 112 + 132 + 172 1348 = 132 + 172 + 192 + 232 1556 = 22 + 32 + 52 + 72 + 112 + 132 + 172 + 192 + 232 1849 = 432 { a sum with just one summand is also a sum; the empty sum is 0 } 2020 = 172 + 192 + 232 + 292 so bingo !. Now it's just a matter of writing a program to find all the years in the given interval having that property, and this 7-line program for the HP-71B will do: 1 DESTROY ALL @ OPTION BASE 1 @ DIM P(19) @ K=2 @ L=0 @ C=0 2 REPEAT @ L=L+1 @ P(L)=K*K @ K=FPRIM(K+1) @ UNTIL K>70 3 FOR N=4 TO 5000 @ J=L @ WHILE P(J)>N @ J=J-1 @ END WHILE 4 M=N @ I=J 5 M=M-P(I) @ IF NOT M THEN C=C+1 @ DISP N; @ GOTO 7 6 IF M<0 THEN J=J-1 @ GOTO 4 ELSE I=I-1 @ IF I THEN 5 7 NEXT N @ DISP @ DISP "Total:";C [RUN] 4 9 13 25 34 38 49 74 83 87 121 169 170 195 204 208 289 290 339 361 364 373 377 458 529 579 628 650 653 662 666 819 841 890 940 961 989 1014 1023 1027 1179 1348 1369 1370 1469 1518 1543 1552 1556 1681 1731 1802 1849 2020 2189 2209 2310 2330 2331 2359 2384 2393 2397 2692 2809 2981 3050 3150 3171 3271 3320 3345 3354 3358 3481 3530 3700 3721 4011 4058 4061 4350 4489 4519 4640 4689 4714 4723 4727 4852 4899 Total: 91 where the years given as examples appear in bold and the next one after 2020 appears in bold red, which is 2189 = 132 + 172 + 192 + 232 + 292. The Results Based on the data obtained by the sleuthing process above and the results from running the program, the answers are:
The Comments The joke explanation of why 2020 was such a catastrophic year is an original idea of mine, and implementing it was just a matter of finding some nice but simple numeric property of 2020. After some sleuthing I found it to be that 2020 = 172 + 192 + 232 + 292, which are the squares of consecutive primes (pretty nice indeed), and then I wrote the program to compute all other years between AD 4 and AD 5000 sharing this property. So far, so good. Then I searched Wikipedia for a list of big catastrophes, and cross-checking the years found there with the years listed by my program I finally selected the ones most remarkable while ignoring numbers too low, to avoid reducing the difficulty too much (e.g.: if chosing AD 13 it would be instantly recognizable as 22 + 32, all too easy!) and le voilà, Concoction 6 ready ! I also wrote the following 6-line program for the HP-71B which accepts a given year in range and demonstrates whether it has the required numeric property (thus, if it indeed was/might be catastrophic) or not.). 1 DESTROY ALL @ OPTION BASE 1 @ DIM P(19),S$[80] @ K=2 @ L=0 2 REPEAT @ L=L+1 @ P(L)=K*K @ K=FPRIM(K+1) @ UNTIL K>70 @ INPUT N 3 J=L @ WHILE P(J)>N @ J=J-1 @ END WHILE 4 S$="" @ M=N @ I=J 5 M=M-P(I) @ S$=STR$(SQR(P(I)))&"^2+"&S$ @ IF NOT M THEN S$[LEN(S$)]="" @ DISP S$ @ END 6 IF M<0 THEN J=J-1 @ GOTO 4 ELSE I=I-1 @ IF I THEN 5 ELSE DISP "Not a sum" [RUN] ? 2020 -> 17^2+19^2+23^2+29^2 { VAL(S$) = 2020 } ? 666 -> 2^2+3^2+5^2+7^2+11^2+13^2+17^2 { VAL(S$) = 666 } ? 1849 -> 43^2 { VAL(S$) = 1849 } ? 555 -> Not a sum The Hall of Fame Again, the one and only expert who dared to deal with this Concoction the Sixth: Weird Year is no other but
That's all, this concludes my original solutions for all 6 Concoctions 6 of this S&SMC #25 of mine. Thank you very much to those who contributed their solutions or at least posted some comments, much appreciated. I really hope you enjoyed it as well as all the readers in general. Over and out.
Best regards. V. RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - EdS2 - 03-02-2021 09:46 AM Very nice, thanks again for the motivations and explanations. Just one query: I'd interested to know the runtimes of some of these 71B programs. (Even if approximate, from memory.) For example, the time to find PP#1 and then PP#2. Another example, the most expensive calculation relating to the PP challenge - how long did that run for? (If I had a 71B I could find this out directly!) (Edit: answered in PM. VA (re)noting the use of go71b, about 128x faster than 71b, and taking 186s and 337s for PP's 1 and 2, and 4117s for PP# 1846. Noting also that a real 71b is about 10x or more the speed of a 41C. HP85 about 5x faster than 71. And noting that none of the code is written for speed.) RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - robve - 03-02-2021 09:32 PM Very nice last challenge and results! The combinatorial space of possible methods to apply seems quite large, perhaps too large for some to consider attacking this challenge when given limited time to work on this, despite helpful hints such as “five words”. (03-02-2021 02:55 AM)Valentin Albillo Wrote: After discarding many sums of squares and cubes (e.g.: "sum of four square numbers", as every integer is a sum of four square numbers, including 02) I for sure could have guessed this challenge had something to do with a sum of squares for a specific year*. (03-02-2021 02:55 AM)Valentin Albillo Wrote: Cutting to the chase, eventually we also notice that 13 and 17 are consecutive primes so the property becomes "sum of consecutive squared primes" (5 words!) OK (duh), it happens that with many such methods other “special years” will coincidently fall in place too, with the often sought after number of the beast (which according to Numberphile is debatable whether it is 666 or 616 because both spell out Nero, the most evil ruler of the Roman era). If the solutions to the equation are very limited, then it won’t be likely. But if there are a couple of hundred solutions to an equation in a limited integer range and the definition of "special year" is less specific, then the odds are in favor of matching some special years. The result is nice because of the series of primes is consecutive. Not only does this reduce the number of solutions reasonably, and thus the years that match, it also saves time not having to check all subsets of a certain set of integers (such as squares of primes). For example, checking all subsets of integers between 1 and sqrt(Y) for a given year Y is an O(2Y/2) time process to compute. Reducing it to linear O(Y) makes it not only fast, but much simpler to implement (on a calculator). The method is linear in Y to generate primes up to sqrt(Y) and to check if the sum of squares of consecutive primes 2 to sqrt(2) is equal to Y (i.e. in time O(sqrt(Y2))=O(Y)). Now that the results are in, I will share an effective approach to tackle the kinds of questions that require an exhaustive search among subsets. In general, we can approach these type of problems using the classic generate-and-test paradigm. Essentially brute force, but a bit smarter to generate combinations with a classic combination generating algorithm. Listed below is a generic generate-and-test HPPL program to generate and check all subsets of a set of integers that sum up to a given integer, with a modification to sum up squares of primes to match a given year. First, the values are generated with GENVALUES and stored in list L1. Second, all subsets of the list are then tested to verify if their sum of squares match the given number NUM: EXPORT GENVALUES(N) BEGIN LOCAL I; L1:=[2]; FOR I FROM 3 TO N DO IF isprime(I) THEN L1:=append(L1,I); END; END; END; EXPORT SUMSQ(NUM) BEGIN LOCAL N=FLOOR(SQRT(NUM)),K,I,F=0,X,Y; GENVALUES(N); FOR K FROM 1 TO SIZE(L1) DO L0:=MAKELIST(I,I,1,K); REPEAT L2:=MAKELIST(L1[L0[ I]],I,1,K); IF ΣLIST(L2^2)=NUM THEN PRINT(L2); F:=1; END; PNXCB(SIZE(L1),K,X,Y); UNTIL L0(K)=K; // IF F THEN // RETURN; // END; END; END; Note that L0:=MAKELIST(I,I,1,K) is an index vector with values 1 to K. This vector is used to generate all subsets of values though indirect indexing, with elements of L0 pointing to elements of L1. For example, L0=[1,2,3] is the subset of the first three primes L1=[2,3,5,...] whereas L0=[1,4,7] is the subset of three primes L1=[2, , ,7, , ,17,…]. The list L2:=MAKELIST(L1[L0[ I]],I,1,K) produces this list of subset of primes, which we then check if their sum of squares equals NUM with ΣLIST(L2^2)=NUM. If so, the list L2 satisfies the conditions and is displayed. Also note that we start with the smallest subsets first, a set of size 1, then a set of size 2, and so on by populating L0:=MAKELIST(I,I,1,K) for K from 1 to the size of L1. The program displays the smallest subsets only. If all sets should be displayed, then uncomment the three lines in SUMSQ. To check with another function rather than squaring, just replace L2^2 with another function and adjust sqrt(NUM) to assign to N accordingly (we limit the iteration space to sqrt(NUM) to avoid iterating over values who’s square exceeds NUM and therefore are never part of the solution). The workhorse for this program is the clever PNXCB combination generator which I’ve rewritten below in HPPL: EXPORT PNXCB(N,K,X,Y) BEGIN LOCAL J=1; WHILE 1 DO X:=L0(J); Y:=X+1; IF J=K THEN IF Y>N THEN Y:=K; L0(J):=Y; RETURN; END; L0(J):=Y; IF J>1 THEN L0(J-1):=X; X:=J-1; END; RETURN; END; IF Y<L0(J+1) THEN L0(J):=Y; IF J>1 THEN L0(J-1):=X; X:=J-1; END; RETURN; END; J:=J+1; X:=L0(J); Y:=X-1; IF Y>=J THEN L0(J):=Y; IF J>1 THEN Y:=J-1; L0(J-1):=Y; END; RETURN; END; IF J=K THEN Y:=N; L0(J):=Y; RETURN; END; J:=J+1; END; END; We start with an index list L0 containing the values 1 to K. PNXCB takes L0 as input. The next combination of the binomial C(N,K) (N choose K) is generated by PNXCB and is stored in L0. PNXCB generates exactly C(N,K) selections K of N in L0. But we do not need to count them to stop the REPEAT loop! Here is the clever part: if we start with a list of values 1 to K then the PNXCB cycles through all combinations to arrive back to the initial list, exactly after C(N,K) calls to PNXCB. Therefore, the C(N,K) cycle is complete when the last value in the list is K, a useful property of PNXCB. The PNXCB routine rewritten for classic BASIC calculators: ' Algorithm PNXCB Combination Generators ' PNXCB(P,N,K) cycles through "pointers" P(1:K) to N items ' Calling PNXCB NCR(N,K) times produces all combinations ' If initiallly P(I)=I, then NCR(N,K) cycle is complete when P(K)=K ' TEST PROGRAM 10 CLEAR: N=5,K=2: INPUT "N=";N,"K=";K 20 DIM P(K): FOR I=1 TO K: P(I)=I: NEXT I 30 FOR I=1 TO K: PRINT P(I);: NEXT I: PRINT 40 GOSUB 100 ' all pointers were left-most initialized, if P(K)=K then end 50 IF P(K)=K END 60 GOTO 30 ' PNXCB(P,N,K) -> P, X (old), Y (new), changes J 100 J=1: REM GOTO 180 FOR DOWN-UP SEQUENCE 110 X=P(J),Y=X+1 120 IF J<>K GOTO 160 130 IF Y>N LET Y=K,P(J)=Y: RETURN 140 P(J)=Y: IF J>1 LET P(J-1)=X,X=J-1 150 RETURN 160 IF Y<P(J+1) GOTO 140 170 J=J+1 180 X=P(J),Y=X-1 190 IF Y>=J GOTO 230 200 IF J=K LET Y=N,P(J)=Y: RETURN 210 J=J+1 220 GOTO 110 230 P(J)=Y: IF J>1 LET Y=J-1,P(J-1)=Y 240 RETURN It's all basic, isn't it? - Rob *) the year 2021 has 17 minimal sets of 3 squares that sum up to 2021. Run SUMSQ with GENVALUES changed to L1:=MAKELIST(I,I,1,N) and uncomment the IF F THEN clause to display these minimal solutions. RE: [VA] Short & Sweet Math Challenge #25 "San Valentin's Special: Weird Math... - Gerson W. Barbosa - 03-04-2021 02:53 PM (03-02-2021 02:55 AM)Valentin Albillo Wrote: Gerson W. Barbosa, who posted RPL code for such models as the HP50G and BASIC code for the HP-75C, ... Hello, Valentín, Thank you for the compliment and sorry for the belated reply (I’ve been busier than usual lately). Unlike you, didactics is not one of my strengths, but I will try to demonstrate how I arrived at the solution to your sixth concoction. At first I was not intending to participate in any of these as I was 400 kilometers away from home and I had brought no calculator along. When I visited this thread again, all the other concoctions had been solved. It was late in the evening already, I had neither pencil nor paper but I found a copybook and a pen somewhere and decided to give it a go. As I am not smart enough to look at a small set of numbers and spot its common property right away, I submitted all your examples but one to Wolfram Alpha, which told me that 2020 = 16² + 42² = 24² + 38²; 1348 = 18² + 32²; 1556 = 20² + 34²; 458 = 13² + 17²; 1849 = 43² + 0² and 666 = 15² + 21². “Quite easy!”, I thought. These are just numbers that can be represented as a sum of two squares (although that didn’t look like a ‘striking’ property to me). Then I wrote a simple RPN program on the emulated 49G+ on my smartphone running m48+: « { } 0 71 FOR x x 71 FOR y x SQ y SQ + + NEXT NEXT SORT DUP SIZE 1 - 1 SWAP FOR k k GETI UNROT GETI NIP ROT == { k { 0 } REPL } IFT NEXT SORT WHILE DUP HEAD NOT REPEAT TAIL END » After a rather long time, it returned a list with way more elements than the one specified by you (less than 100 elements), even when discarding the ones greater than 5000. Also, one of your examples were missing: 662. It turns out that was the only one I had left out. I was disappointed of course, but not everything was lost. I noticed that two of your examples involved either the some of the squares of consecutive primes or the square of a prime: 458 and 1849. The Wikipedia article on 666 only confirmed that 666 = 2² + 3² + 5² + 7² + 11² + 13² + 17². Likewise, it wasn’t difficult to verify that all the remaining examples could be expressed as the sum of the squares of consecutive prime numbers. Now, I only needed to figure out a suitable algorithm. But at daft o’clock my reasoning was starting to fail, so I went to sleep and early next morning after I woke up I soon came out with a working program. The argument to the program in post #15 is the number of elements in the list of the squares of the first consecutive prime numbers, { 4, 9, 25, 49, 121, ... }. I started with a 15-element list, but I noticed the resulting list of ‘weird years’ would not include some of your examples. Then I increased it to 16, then to 20, when the list seemed to be complete (the list up to 5000 would not be changed by further increases). I thought it would be nice if the program calculated the size of the basic list automatically, so I researched at OEIS, which led me to an interesting recent article on the subject. That’s where I ‘borrowed’ the formula I used in my next programs, which has to do with the size of the list of the first squares of primes necessary to produce the list of all years up to certain limit (hopefully I have simplified the correct formula – the article looks complicated to me). Next day I was tired after driving all the way back home, but I took the time to write an HP-75C version per your suggestion of using programming languages other than RPL for more clarity. But it payed off, as I noticed the BASIC program was more optimized than the RPL program (the output list never would grow longer than it needed to be). As a result, I was able to write a faster RPL program, but really expert RPL programmers, which I am not, can optimized it even more. Thank you also for taking the time to concoct these S&SMCs. Even when we don’t participate it’s a joy just to read them, especially your final comments and solutions. Best regards, Gerson. |
