HP-65 goes on hold after reading a card - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-65 goes on hold after reading a card (/thread-15899.html) |
RE: HP-65 goes on hold after reading a card - albertofenini - 11-30-2020 10:23 AM Hi Tony, Hi Everyone don't worry, we will ask Santa to bring us a new reworking station, our is quite dated .. The hybrid pins reparation works very well, is the hybrid itself that doesn't work ... To your knowledge, is the process of storing and executing a program involving the ROMS ? I feel that the storage space for programs is in the hybrid, and the card reader handling as well, so I would say ROMs have little to do with that ... We have a set from a old unit and we will give it a try replacing the actual ones It would be nice to know what exactly each ROM ids responsible for, is that complicated ? By the way, the unit that keeps on all the C segments (Disp0 and RCD low in amplitude...) would benefit from a ROM change ? HP-65 1605A02841 - weird display and card reader issues (11-29-2020 10:06 PM)teenix Wrote:(11-29-2020 05:03 PM)albertofenini Wrote: Hi Tony, hi everyone RE: HP-65 goes on hold after reading a card - teenix - 11-30-2020 11:17 AM (11-30-2020 10:23 AM)albertofenini Wrote: Hi Tony, Hi Everyone Lucky you :-) The commands that access the program storage are in each of the 3 ROMs. I assume ROM 0-3, ROM 4-7, ROM 8-B are in ascending chip numbering 1818-0073 - 1 command 1818-0074 - 11 commands 1818-0075 - 8 commands All the logic is in the hybrid Yes a ROM change might fix the display, even though it seems more likely elsewhere. cheers Tony RE: HP-65 goes on hold after reading a card - albertofenini - 11-30-2020 11:20 AM What do you mean with 1 command or 11 commands or 8 commands ? Do they contain specific instructions that are loaded at the power up ? Thanks ! Take care ! (11-30-2020 11:17 AM)teenix Wrote:(11-30-2020 10:23 AM)albertofenini Wrote: Hi Tony, Hi Everyone RE: HP-65 goes on hold after reading a card - teenix - 11-30-2020 12:01 PM (11-30-2020 11:20 AM)albertofenini Wrote: What do you mean with 1 command or 11 commands or 8 commands ? Whereas the HP-67 does code handling of the program which is stored in memory, the HP-65 does it through instructions that interface to the program buffer which is a separate chip not related to other memory storage. These are the program buffer access commands and what hexadecimal ROM address they appear in. pointer advance - Advance the program pointer by one 1EA 47B 49B 49D 930 9F4 mark and search - subroutine handling 444 488 4FC search for label - Looks for a label like LBL A 4A8 4AC 4AF 4C2 9A7 A09 memory insert - insert a program step at the current pointer position 4E2 A1F memory initialize - clear the program memory 936 A3C memory full -> a - determines if program buffer is full B6B Memory Delete - delete a program step 091 460 462 4B4 In your case, maybe the [Memory Full -> A] instruction is not working properly. There is only one of these codes in ROM 3 (probably 1818-0075) Through a bunch of other instructions, this is what eventually lights the G segment when the buffer is full. It may not be the instruction however, as the program buffer and or its logic might be faulty. Hard to tell. cheers Tony RE: HP-65 goes on hold after reading a card - albertofenini - 12-01-2020 11:01 PM Hi Tony, Hi Everyone we swapped the ROMs, all of them but nada ... We put the spare ROMs in the unit with the C segments always on but it still behaves like that At this point we took the ROMS taken out from that unit and we put them in the unit the goes on hold, but it still does it ... I would say both types of problem do not depend from ROMs ... Would can we try if anything ? take care !!! (11-30-2020 12:01 PM)teenix Wrote:(11-30-2020 11:20 AM)albertofenini Wrote: What do you mean with 1 command or 11 commands or 8 commands ? RE: HP-65 goes on hold after reading a card - teenix - 12-02-2020 06:45 AM (12-01-2020 11:01 PM)albertofenini Wrote: Hi Tony, Hi Everyone As the problem moved when you switched CPUs to a known working 65, I would say the logical culprit is the hybrid. The only other circuitry is the power supply. cheers Tony |
