HP 42S Version Speed Variation - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 42S Version Speed Variation (/thread-1572.html) |
RE: HP 42S Version Speed Variation - Thomas Klemm - 06-09-2014 02:56 PM (06-09-2014 02:12 PM)rprosperi Wrote: Thomas - Is there a way to create these individual post# links automagically, or only crafting them by hand (insert thread link then edit to add post#)? Quite useful and elegant way to save space in complex replies. You can right-click the number of the post in the top right corner, choose [Copy Link Location] in the context-menu and then create a link in the toolbar [Insert hyperlink]: I can't reference only this icon but it's the earth and the chain. You can even add a highlight url-parameter: #19. Cheers Thomas PS: In the old forum you had to search for the id of a post in the source in order to directly link to a certain post. RE: HP 42S Version Speed Variation - walter b - 06-09-2014 02:58 PM 10 points for pointing to this feature. -10 points for tearing even that little sub-thread to shreds by forgetting to apply that theoretical knowledge. d:-I RE: HP 42S Version Speed Variation - J-F Garnier - 06-09-2014 03:00 PM (06-09-2014 02:00 PM)Gerald H Wrote:(06-09-2014 01:54 PM)J-F Garnier Wrote: Can you make sure if by chance one of your machine is in PON (Printer On) mode and this other one in POFF? Interesting. To answer your initial question: no, such a variation between versions is not expected/common. I checked with a simple test program on my A and C machines and got no significant differences, my C machine is even about 5-10% slower than my A, so it doesn't depend on the software version. Maybe something is wrong in one of your machine regarding system clock, even if the self-test reports 1MHz in both cases. If you try to do a BEEP on both machines, can you hear a significant higher pitch on one? For your reference, here is my test program: Code: LBL "X" RE: HP 42S Version Speed Variation - walter b - 06-09-2014 03:04 PM Thomas, now you get -15 points for reasons mentioned here. d:-( RE: HP 42S Version Speed Variation - walter b - 06-09-2014 03:09 PM Again, 10 points for pointing to that, but -10 points for lack of application. Compare there. Shall I quote Albert E. next? d:-( RE: HP 42S Version Speed Variation - Gerald H - 06-09-2014 04:02 PM (06-09-2014 03:00 PM)J-F Garnier Wrote:(06-09-2014 02:00 PM)Gerald H Wrote: Both with same flag settings & printing is off. Quite amazing - this correspondent actually says something relevant to the topic! RE: HP 42S Version Speed Variation - Thomas Klemm - 06-09-2014 04:42 PM (06-09-2014 03:09 PM)walter b Wrote: d:-( Gähn RE: HP 42S Version Speed Variation - Gerald H - 06-09-2014 04:55 PM (06-09-2014 03:00 PM)J-F Garnier Wrote:(06-09-2014 02:00 PM)Gerald H Wrote: Both with same flag settings & printing is off. I've now recovered my composure. If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother. A similar request on anyone with version A & C HP 42Ss. RE: HP 42S Version Speed Variation - J-F Garnier - 06-09-2014 05:04 PM (06-09-2014 04:55 PM)Gerald H Wrote: If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother. Well, no I won't key in (twice) these rather long programs. But if you can do on your side my simple test and the BEEP check I mentioned, it could give us a clue. J-F (and don't bother about the repetitive OT messages :-) RE: HP 42S Version Speed Variation - Gerald H - 06-09-2014 05:15 PM To post # 29: Beeps sound similar. Your short test prog, & similar short loops, show the A version as marginally faster, but this would in no way account for the difference in timing for the factorization in post # 13. RE: HP 42S Version Speed Variation - J-F Garnier - 06-09-2014 05:23 PM (06-09-2014 05:15 PM)Gerald H Wrote: To post # 29: OK. So we have similar machines (A slightly faster than C). And you have a program that runs faster on one machine. Nice mystery to solve. And please use the Quote feature rather than a reference to a post in writing... thanks! J-F RE: HP 42S Version Speed Variation - Bill (Smithville NJ) - 06-09-2014 06:02 PM (06-09-2014 03:00 PM)J-F Garnier Wrote: For your reference, here is my test program: I tried your test program with my Version C units. I consistently get between 510 and 530. Variation is probably due to my inability to press R/S exactly at the same moment on each run. Bill RE: HP 42S Version Speed Variation - walter b - 06-09-2014 06:39 PM (06-09-2014 04:42 PM)Thomas Klemm Wrote: Gähn Oooh, that link shows exhausted poor little Thomas passed/past his limits. Don't overstress again. Get well soon! d;-) RE: HP 42S Version Speed Variation - Bill (Smithville NJ) - 06-09-2014 06:42 PM (06-09-2014 04:55 PM)Gerald H Wrote: If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother. Okay, I have entered your program on a Version C machine. I double & triple checked the code enter to make sure it matches your posted listing. I have printed it out and then checked the printout line by line with your listing. So I'm pretty sure it is entered correctly. Unfortunately, it does not seem to end - I've let it run for over 30 minutes with so solution. Maybe I'm not initializing the program correctly. I do the following: enter 11,111,111,111 into the X register. enter "seed" (11,111,111,111 is still in the X register I then do XEQ "POBR" It then runs, but doesn't seem to end. Am I'm doing something wrong? Is there something I should initialize or do? Bill RE: HP 42S Version Speed Variation - walter b - 06-09-2014 06:52 PM (06-09-2014 02:12 PM)rprosperi Wrote:(06-09-2014 01:59 PM)Thomas Klemm Wrote: Usually, you won't need a post# for anything. Just use the link at the # top right to refer e.g. to this post. Or use <Quote>, delete almost everything, and the reader can still click on the little right green arrow. Want more? d:-) RE: HP 42S Version Speed Variation - J-F Garnier - 06-09-2014 07:45 PM (06-09-2014 05:23 PM)J-F Garnier Wrote: Nice mystery to solve. I was curious and entered your program in the Emu42 emulator and ran it using either ROM A and C. In this way, I was sure to have exactly the same operating conditions. No significant difference. What you are observing is not caused by the software version. One question: in you first post, you reported that a program of yours was running slower on version A than on version C (+20% running time). Then you reported than your posted program POBR was slower on version C than on version A (now +40% running time). Is that correct? J-F RE: HP 42S Version Speed Variation - Gerald H - 06-10-2014 05:23 AM (06-09-2014 07:45 PM)J-F Garnier Wrote:(06-09-2014 05:23 PM)J-F Garnier Wrote: Nice mystery to solve. Very sorry my first post is botched - version A was faster & consistently so. A took 200s & C 280s. I can hardly believe that I wrote that original error. RE: HP 42S Version Speed Variation - Gerald H - 06-10-2014 05:37 AM (06-09-2014 06:42 PM)Bill (Smithville NJ) Wrote:(06-09-2014 04:55 PM)Gerald H Wrote: If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother. I have checked against the programmes as stored in my HP 42S & the coding is identical - my calculators produce correct factorizations. I believe post # 36 indicates that the posted programmes are written correctly. Please check your coding again, as errors do occur - see my previous post & the initial posting on this matter. RE: HP 42S Version Speed Variation - J-F Garnier - 06-10-2014 07:34 AM (06-10-2014 05:23 AM)Gerald H Wrote: Very sorry my first post is botched - version A was faster & consistently so. A took 200s & C 280s. Thanks for the confirmation. And the running time difference is not +20% as I wrote but +40%. RE: HP 42S Version Speed Variation - J-F Garnier - 06-11-2014 07:37 AM (06-10-2014 05:37 AM)Gerald H Wrote: I have checked against the programmes as stored in my HP 42S & the coding is identical - my calculators produce correct factorizations. Gerald, For the sake of completeness, I run your programs on my physical A and C machines. I got: version A machine: 414s version C machine: 432s consistent with the observation that version A is slightly faster (+5%). I assume that there is something different in the implementation of your programs in your C machine. Can you please check again? - Errors do occur :-) Only you can do it since you are the only one to get such a speed difference (40%). Please share your findings, I'm now curious... J-F |
