Lambert W Function (hp-42s) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Lambert W Function (hp-42s) (/thread-15004.html) |
RE: Lambert W Function (hp-42s) - lyuka - 09-28-2020 04:06 PM Oh, I was overlooked this thread. The Lambert W function came out when I was writing a description of the Widlar current souce a few months ago, but it is not found in ordinary scientific calculators or spreadsheet software. So I wrote an e^W calculation program for 42S, and additionally in C. http://www.finetune.co.jp/~lyuka/technote/lambertw/lambertw-42s.html It's nice to be able to handle complex numbers easily with 42S, but if you try to find e^W with Newton-Raphson method, it will fail very close to -1/e. So, it is desirable that the approximation error of the initial value is asymptotic to 0 at -1/e. For that reason, I chose the following formula as an approximate expression that gives the initial value. y0 = 1 / e + sqrt ((2 / e) * (x + 1 / e)) + 0.3 * (x + 1 / e); Thanks to sqrt in this equation, in 42S we can automatically get the complex y0 from x less than -1 / e. Instead of the coefficient of 0.3 in the formula above, it can be "e - sqrt2 - 1" which makes zero error at x = 0, or "1 / 3" from Puiseux series, but 0.3 is quite good enough for this purpose. RE: Lambert W Function (hp-42s) - Albert Chan - 09-28-2020 10:01 PM (09-28-2020 04:06 PM)lyuka Wrote: It's nice to be able to handle complex numbers easily with 42S, I use e^W(x) guess of LN(1+x), it seems OK with close to -1/e Werner improved on it by doing everything in the stack Bonus: resulting stack X = Y = eW, Z = T = x. To recover W, we can do either "LN", or "R↓ ÷" With Free42, tried x = -1/e: 1 [+/-] [e^X] [+/-] XEQ "eW" → 0.367879441171 It worked, but result "only" have 17 good digits. Trying it in Python, eW convergence around -1/e is bad, even with good guess. >>> from cmath import * >>> g = lambda y,a: (y+a)/(log(y)+1) >>> x = -1/e >>> y = log(1+x) # eW guess >>> y (-0.45867514538708193+0j) >>> for i in range(1,101): y = g(y,x); print i, y ... 1 (-0.0183829712865+0.261809735996j) 2 (0.19954449329+0.194333174479j) 3 (0.292276297365+0.112700062519j) 4 (0.332518371694+0.0601902170855j) 5 (0.350846602748+0.0310495664127j) 6 (0.359529649069+0.0157626859032j) 7 (0.363746790135+0.00794072878334j) 8 (0.365823750457+0.00398519956333j) 9 (0.36685426371+0.00199630716024j) ... 100 (0.367879435928+2.54426772287e-11j) RE: Lambert W Function (hp-42s) - lyuka - 09-29-2020 09:21 AM I'm sorry the word fail was wrong. It meant go bad from a convergence point of view, even if it might or might not fail. In my opinion, it is not appropriate to use ln(x + 1) as the initial guess of e^W(x) if x is very close to -1 / e because it would require so many itterations very close to -1 / e (e.g. -1 / e + 1E-11). Using Free42 with the example value of x = -1 / e + 1E-11 ~= -0.3678794411614423215955237701614609, it requires 22 itterations if you start with the guess of y0 = ln(x + 1) ~= -0.4586751453712621239530755133385323. On the other hand, starting with the guess of y0 = 1 / e + sqrt ((2 / e) * (x + 1 / e)) + 0.3 * (x + 1 / e) ~= 0.3678821536620134320783140520913751, only two itterations are needed. In this case the guess is already correct upto 12 digits. RE: Lambert W Function (hp-42s) - Albert Chan - 09-29-2020 07:07 PM (09-28-2020 04:06 PM)lyuka Wrote: y0 = 1 / e + sqrt ((2 / e) * (x + 1 / e)) + 0.3 * (x + 1 / e); Very nice approximation ! However, the formula might be too good. At x = -1/e, above return *exactly* y0 = 1/e. With f(y) = y*ln(y) - x, f'(y) = ln(y) + 1, we get f'(y0) = -1 + 1 = 0 Unless we test for zero slope, Newton's formula, y -= f(y)/f'(y), will crash with divide-by-zero. You might want to adjust the formula a tiny bit ... RE: Lambert W Function (hp-42s) - lyuka - 09-29-2020 11:17 PM That case of x = -1 / e has already been handled by my code shown in the link in the previous post. RE: Lambert W Function (hp-42s) - Werner - 09-30-2020 07:08 AM (09-28-2020 04:06 PM)lyuka Wrote: http://www.finetune.co.jp/~lyuka/technote/lambertw/lambertw-42s.htmlIn that program: Code: 12 ENTER can be replaced by Code: 12 ENTER and Code: 16 X<>Y by Code: 16 STO+ ST Z saving two bytes! ;-) Cheers, Werner RE: Lambert W Function (hp-42s) - Werner - 09-30-2020 09:12 AM (09-28-2020 10:01 PM)Albert Chan Wrote: With Free42, tried x = -1/e:That is a direct consequence of using y'=y'+(y'-y)^2 as a stopping criterion.. You should do 1 extra Newton-Rhapson step Werner RE: Lambert W Function (hp-42s) - lyuka - 09-30-2020 11:04 AM Thanks to Werner, I confirmed that the code was reduced by 2 bytes and updated the web page :-) RE: Lambert W Function (hp-42s) - Albert Chan - 09-30-2020 05:28 PM (09-30-2020 09:12 AM)Werner Wrote: That is a direct consequence of using y'=y'+(y'-y)^2 as a stopping criterion.. If y' = y' + (y'-y)^2, it implied y has at least half-precision. Assuming Newton's step doubled its precision, y' has about full precision. However, this does not apply on singularity. For y = e^W(x), the newton formula is: y ← y - (y*ln(y) - x) / (ln(y) + 1) Or, equivalent version (simpler, but slightly less accurate): y ← (y + x) / (ln(y) + 1) As y approach 1/e, slope (denominator) goes to zero. With limited precision, as soon as y reached half precision, ln(y) + 1 will lose half precison too. First Newton formula suffered the same issue, with questionable correction term. Both form we are hit with 0/0 issue. However, limit do exist: XCas> x0 := -1/e XCas> limit([y - (y*ln(y)-x0)/(ln(y)+1), (y+x0)/(ln(y)+1)], y=1/e) → [1/e, 1/e] Let's try e^W(10^-34 - 1/e), using lyuka "eW": -.3678794411714423215955237701614608 x = 10^-34 - 1/e = 10^-34 - r .3678794411714423301731626197685289 g = r + sqrt(2*r*(x+r)) + 0.3*(x+r) .3678794411714423295023829145484696 y = newton(s) w/ guess g .3678794411714423286399438752146243055... Mathematica for e^W(x) Newton's step(s) gives back only 17 good digits (as expected) Had we apply 1 more newton step (with last y) -.9999999999999999785069284676275602 ln(y) .0000000000000000214930715323724398 ln(y) + 1 -.3678794411714423215955237701614608 y ln(y) We have only half-precision slope. Also, y ln(y) - x = 0. Newton steps does nothing ... RE: Lambert W Function (hp-42s) - Albert Chan - 09-30-2020 05:40 PM Hi, lyuka I extended your code to handle complex number input. Code: 00 { 57-Byte Prgm } Example: e^W(1+2j) 1 Enter 2 [complex] XEQ "eW" 1.963022024795710615403657609352963 + 1.157904818620494603558662182506434i Stack X = Y = eW, Z = T = x. Confirm: x - W e^W should be tiny [LN] [×] [−] → 5.e-34 - 1.e-33i RE: Lambert W Function (hp-42s) - lyuka - 09-30-2020 07:16 PM Hi, Albert Chan. Thanks for your complex number input extension of the code, which is elegant. I confirmed the code and updated the web page :-) RE: Lambert W Function (hp-42s) - Werner - 10-01-2020 09:37 AM nitpicking: it won't recognize (-1/e,0). We can add a code slice at the beginning that will turn a complex number with zero imaginary part into a real, as follows: Code: @ Re -> Re or Code: REAL? Cheers, Werner RE: Lambert W Function (hp-42s) - Albert Chan - 10-01-2020 12:33 PM (10-01-2020 09:37 AM)Werner Wrote: nitpicking: it won't recognize (-1/e,0). I don't like testing special cases, if I can avoid it. Better approach is to not returning guess y0 = 1/e, even if x ≈ -1/e One way is to take advantage of calculator internal extra precision of PI (lets call it π) Free42: [PI] [SIN] → -1.158028306006248941790250554076922e-34 SIN(PI) = SIN(π - PI) ≈ π - PI Instead of adding an ε to 1/e, we get more bang for the buck if ε added to (x+1/e) Thus, another approach is to remove testing x = -1/e altogether, replacing Line 1 to 11 to this: Code: 01▸LBL "eW" To have guess returning r = 1/e, we need: y0 = r + √(2r*(x+r+ε)) + 0.3 (x+r+ε) = r → √(x+r+ε) [ √(2r) + 0.3 √(x+r+ε) ] = 0 → √(x+r+ε) = 0 or (-√(2r)/0.3 ≈ -2.859213) When (x+r) approaching -ε, (x+r) will suffer massive cancellations, thus x+r+ε ≠ 0 √(x+r+ε) > 0 or gone complex. RE: Lambert W Function (hp-42s) - Werner - 10-01-2020 01:39 PM (10-01-2020 12:33 PM)Albert Chan Wrote: I don't like testing special cases, if I can avoid it. Nor do I; we all have our preferences. I don't like the fact that this solution depends on RAD mode, for instance ;-) I don't immediately see a way out of that. 9 1/X 1/X FP X^2 STO+ ST X SQRT is a bit too long for comfort. Perhaps 9 1/X 1/X FP LN1+X Werner RE: Lambert W Function (hp-42s) - lyuka - 10-01-2020 06:25 PM Using sin(PI) is machine dependent and will take some time. How about adding +ULP (unit in last place) to the initial value? Code:
Web page updated. http://www.finetune.co.jp/~lyuka/technote/lambertw/lambertw-42s.html RE: Lambert W Function (hp-42s) - Albert Chan - 10-01-2020 10:25 PM Hi lyuka: I was wrong to suggest removing x=-1/e test. e^W(-1/e) take many tries to converge. Because of catastrophically cancelled slope, we got something like this: 0.367879441171442 0.25 0.3051544444752 0.335540374899958 0.351461975177244 0.359608250433447 0.363728172008137 ... I would recommend reverting to previous version (with x=-1/e test) Besides, previous version is much easier to understand. RE: Lambert W Function (hp-42s) - lyuka - 10-02-2020 05:44 AM Hi, Albert Confirmed. And 'eW' on my page is reverted to the previous version 1.1. I was jumping to the conclusion. Thanks. RE: Lambert W Function (hp-42s) - Werner - 10-02-2020 03:02 PM (09-30-2020 05:28 PM)Albert Chan Wrote: y ← y - (y*ln(y) - x) / (ln(y) + 1) It's rather the y+x that is the culprit - or y*ln(y)-x, which is zero as you pointed out. LN(y)+1 for y close to 1/e can be calculated precisely as (LN1P being the LN1+X function) LN(y) + 1 = LN((1/e)*(1+e*(y-1/e)) + 1 = -1 + LN1P(e*(y-1/e)) + 1 = LN1P(e*(y-1/e)) eg. y = 1/e + 1e-17 then LN(y) + 1 = 2.71828182845904521e-17 LN1P(e*(y-1/e)) = 2.718281828459045198415006976699411e-17 But the cancellation happens also in y + x, and there's nothing we can do. Or at least, nothing *I* can do ;-) Cheers, Werner RE: Lambert W Function (hp-42s) - Albert Chan - 10-02-2020 05:55 PM (10-02-2020 03:02 PM)Werner Wrote: eg. y = 1/e + 1e-17 Above amazing accurate results are misleading. You have y-1/e = 1e-17 (exactly). In other words, y has infinite number of digits ... For rounded 34 digits of y, Free42 will evaluate to the same result. However, both answers only matched half precision. (log1p version does not help here) -1 [EXP] 1e-17 [+] // 3.678794411714423315955237701614609e-1 = y To get an accurate slope, log(y)+1 = log1p(ε = e*y-1) = log1p(ε = e*(y-1/e)) But, this shift the problem to get accurate ε, which required more precise 1/e 1e-17 // y - 1/e -3.255418886896823216549216319830254E-35 // (more precise 1/e) - 1/e − // 1.000000000000000003255418886896823e-17 = y - (more precise 1/e) 1 [EXP] × // 2.718281828459045244209433475626668e-17 = ε [LN1+X] // 2.718281828459045207264152980973417e-17 = log1p(ε) Mathematica gives 2.718281828459045207264152980973418e-17 Quote:But the cancellation happens also in y + x, and there's nothing we can do. Or at least, nothing *I* can do ;-) Since y ≈ -x, (y + x) is exact, without loss of precision (both x, y are inputs, thus considered exact) RE: Lambert W Function (hp-42s) - Albert Chan - 10-02-2020 07:29 PM Here is a demo of previous post results, r + err_r = 1/e (108-bits accurate) Code: r, err_r = 0.36787944117144233, -1.2428753672788363E-17 >>> from mpmath import * >>> ulp = 2**-54 >>> x = -r + ulp # -0.36787944117144228 >>> eW(x, g=g0) # simple version, half precision, as expected. 0 0.367879447562281 1 0.367879447022175 2 0.367879445804813 3 0.367879448020601 4 0.367879446543632 mpf('0.36787944701838976') >>> eW(x, g=g1) # log1p version 0 0.367879447562281 1 0.367879447562281 2 0.367879447562281 3 0.367879447562281 4 0.367879447562281 mpf('0.36787944756228136') >>> eW(x, g=g2) # log1p + more precise 1/e 0 0.367879447562281 1 0.367879446846838 2 0.367879446801743 3 0.367879446801563 4 0.367879446801563 mpf('0.36787944680156281') >>> exp(lambertw(x)) # accurate eW mpf('0.36787944680156281') |
