G2 screen refresh rate (20200121) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: G2 screen refresh rate (20200121) (/thread-14403.html) Pages: 1 2 |
RE: G2 screen refresh rate (20200121) - cdmackay - 01-25-2020 06:12 PM (01-24-2020 06:06 AM)cyrille de brébisson Wrote: The new frequency selection mechanism allows a setup from 55hz to 120hz. (01-24-2020 06:42 AM)Joe Horn Wrote: When the indicator is at the far right, the refresh rate is 120Hz. Out of interest, what are the intermediate steps, please? There are 8 positions, that's 7 intervals; are they ~9.3Hz each? Or is it 55Hz, 60Hz, then in 10Hz intervals to 120Hz? thanks! RE: G2 screen refresh rate (20200121) - toml_12953 - 01-25-2020 06:30 PM (01-25-2020 06:12 PM)cdmackay Wrote:(01-24-2020 06:06 AM)cyrille de brébisson Wrote: The new frequency selection mechanism allows a setup from 55hz to 120hz. Yeah, a digital indicator would be more helpful. RE: G2 screen refresh rate (20200121) - Tim Wessman - 01-27-2020 03:20 AM Well, it really isn't meant to be used regularly honestly. The default should be good for nearly everyone at this point... RE: G2 screen refresh rate (20200121) - cyrille de brébisson - 01-27-2020 06:05 AM Hello, Sorry, 55hz to 125hz with 10 Hz intervals. Cyrille RE: G2 screen refresh rate (20200121) - cdmackay - 01-27-2020 11:27 PM (01-27-2020 03:20 AM)Tim Wessman Wrote: Well, it really isn't meant to be used regularly honestly. The default should be good for nearly everyone at this point... Yes, of course, thanks Tim. Unfortunately, if you've changed it, and didn't happen to notice where the slider was beforehand (oops), it's not obvious how to set it back to the default, even if you know the default is 55Hz, unless you know that 55Hz is also the lower bound. Yes, agreed, it's all somewhat academic, especially the intermediate points, and thanks to you both for even considering it might be usefully adjustable. RE: G2 screen refresh rate (20200121) - cdmackay - 01-27-2020 11:28 PM (01-27-2020 06:05 AM)cyrille de brébisson Wrote: Hello, thank you! RE: G2 screen refresh rate (20200121) - john gustaf stebbins - 02-01-2020 05:22 AM At the risk of causing an epileptic outbreak--I wrote a couple programs to explore the screen refresh. I started this before Cyrille gave us the details, but there is still some interesting behavior to be seen. STROBE flashes a square on the screen at a given frequency. STROBEH and STROBEV move a line and bar across or down the screen, stepping at the given frequency. STROBE shows banding, so there must be something going on with the vertical refresh of the screen. I think the faster refresh improves the looks of a couple graphics programs I've written, such as PENDULUMS2. Not worth burning battery most of the time, but cuts down on some afterimage blurring. -jgs STROBE Code:
STROBEH Code:
STROBEV Code:
PENDULUMS2 Code:
RE: G2 screen refresh rate (20200121) - cyrille de brébisson - 02-03-2020 06:19 AM cool, thanks! Cyrille RE: G2 screen refresh rate (20200121) - coolfrost6 - 08-19-2020 12:38 PM My unit suffered from some pretty bad flickering/shimmering which was solved when i increased the refresh rate. I linked a video of the before https://www.youtube.com/watch?v=IJz44s47HA0. Im my case all shimmering disappeared at about the third highest refresh setting. My thought is that there is some manufacturing variance in the lcd's which finetuning the refresh rate solves. |
