(55) Sulfide & Acid Synthesis in Anhydrous Methanol - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (55) Sulfide & Acid Synthesis in Anhydrous Methanol (/thread-14230.html) |
(55) Sulfide & Acid Synthesis in Anhydrous Methanol - SlideRule - 12-25-2019 04:57 PM An extract from The Synthesis of Inorganic Sulfides & Photochromic Tungstic Acid in Anhydrous Methanol, PhD. Thesis (Chemistry), UoI, 1979-09 (211 pgs.) TABLE OF CONTENTS PART TWO APPENDIX Hewlett-Packard HP 55 Computer Programs . . . . . . . . . . . . . . . 203 … X-ray Powder Diffraction Analysis … The d-spacings were calculated using a Hewlett ?Packard model 55 calculator program (Appendix) ?… … Preliminary data reduction procedure …This correction was performed by a Hewlett?Packard Model 55 calculator program (Appendix) … each reflection was corrected for Lorentz & polarization factors (47), using another calculator program (Appendix)? … … HP-55 Calculator Programs Powder Pattern dÅ generator (p-204) Lorertz - polarization correction to Weissenberg data (p-205) Net Correction of According to Fourth Order Polynomial (p-206) … BEST! SlideRule |
