Need help for some HP Prime calculus/functions - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Need help for some HP Prime calculus/functions (/thread-14188.html) Pages: 1 2 |
RE: Need help for some HP Prime calculus/functions - toml_12953 - 12-22-2019 11:53 PM (12-22-2019 09:49 PM)CyberAngel Wrote:(12-22-2019 07:47 PM)toml_12953 Wrote: All of my Primes (HW A, two HW C (old and new keyboard) and D) had Trig Explorer 2 and 3 on them. I deleted all of them. Am I the only one who ended up with multiple Explorers? Good! I feel so special! RE: Need help for some HP Prime calculus/functions - Nigel (UK) - 12-23-2019 10:06 AM (12-22-2019 07:36 PM)Devil69 Wrote: Hi Nigel thank you very much I followed your instructions and it finally worked! Glad to help. I agree with you about including an integer in the solution. The strange thing is that the Prime already does this when solving trigonometric equations: try solving \(\sin(x)=\frac12\), with "Principal" unticked in the CAS settings. So the mechanism is there, but for some reason it isn't applied to inequalities. Nigel (UK) RE: Need help for some HP Prime calculus/functions - Devil69 - 12-23-2019 09:30 PM (12-23-2019 10:06 AM)Nigel (UK) Wrote:(12-22-2019 07:36 PM)Devil69 Wrote: Hi Nigel thank you very much I followed your instructions and it finally worked! After unticking Pricipal in CAS settings and trying to solve \(\sin(x)=\frac12\), I have this result: (12*n_24*π+π)/6, (12*n_24*π+5*π)/6, what does mean 12*n_24*π ? Thanks RE: Need help for some HP Prime calculus/functions - Aries - 12-24-2019 07:30 AM 12*k*pi Best, Aries RE: Need help for some HP Prime calculus/functions - Nigel (UK) - 12-24-2019 12:03 PM (12-23-2019 09:30 PM)Devil69 Wrote:(12-23-2019 10:06 AM)Nigel (UK) Wrote: Glad to help. I agree with you about including an integer in the solution. The strange thing is that the Prime already does this when solving trigonometric equations: try solving \(\sin(x)=\frac12\), with "Principal" unticked in the CAS settings. So the mechanism is there, but for some reason it isn't applied to inequalities. n_24 is an arbitrary integer. If you run the command again you should get n_25 in the answer, and so on. This is better than using n or c or k, as these are common variable names which might already be in use elsewhere. Nigel (UK) RE: Need help for some HP Prime calculus/functions - Devil69 - 12-24-2019 03:53 PM (12-24-2019 07:30 AM)Aries Wrote: 12*k*pi Quote: n_24 is an arbitrary integer. If you run the command again you should get n_25 in the answer, and so on. This is better than using n or c or k, as these are common variable names which might already be in use elsewhere. Alright then thanks for your help guys and have a nice Xmas Eve! RE: Need help for some HP Prime calculus/functions - Aries - 12-25-2019 08:38 AM (12-24-2019 03:53 PM)Devil69 Wrote:(12-24-2019 07:30 AM)Aries Wrote: 12*k*pi Happy XMas to you too and everyone ! Best, Aries |
