(41) Sizing of ball mills (spanish) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-41C Software Library (/forum-11.html) +--- Thread: (41) Sizing of ball mills (spanish) (/thread-13852.html) |
(41) Sizing of ball mills (spanish) - SlideRule - 10-24-2019 12:13 AM An extract from Dimensionamiento de molinos de bolas, Alejandro Cartagena, Remetallica (pgs. 77-80) "EI algoritmo de cálculo es el desarrollado por Fred Bond, para dimensionar molinos de bolas a escala industrial … El método nos da una aproximación del consumo real de energía necesaria para moler un mineral determinado en un molino a nivel industrial, siendo el error de cálculo ± 20% … The calculation algorithm is the one developed by Fred Bond, for sizing ball mills on an industrial scale ... The method gives us an approximation of the real energy consumption necessary to grind a given mineral in a mill at an industrial level, the calculation error being ±20% … PROGRAMA "MOLINOS" OCUPA 31 MEMORIAS Y 338 LINEAS DE PROGRAMA (pg-80) "MOLINOS" PROGRAM OCCUPIES 31 MEMORIES AND 338 PROGRAM LINES (pg-80) fully documented - español / española. BEST! SlideRule |
