New Prime crashing - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: New Prime crashing (/thread-13485.html) |
New Prime crashing - nlawrence - 08-21-2019 05:43 PM Hi All, I have just purchased a new HP Prime and am trying it out. I have written a small program to generate a boolean truth table from an expression but I am getting inconsistent results. Assuming I am running the program repeatedly with the same input, sometimes it will not have any issues and run fine each time, sometimes it will run 2 or 3 times and then crash on the next run, sometimes it will crash every time I run the program. Each time I use a different expression it seems to randomly select from one of the 3 described behaviours and then will keeping repeating the behaviour until I change the expression. The most common result is the intermittent crashing. It's hard to write out without taking up a lot of vertical space but imagine that each line below is the function being typed in once and executed multiple (10+) times, with it being retyped after a crash. e.g. BTT("x+y+z") - works fine each time (each time I press the enter key in home screen) BTT("x+y>z") - crashes on each run (crash reboot, retype, crash, reboot, etc.) BTT("x+y+z") - will now crash intermittently (run two or three times, then crash, retype, etc.) BTT("x+y>z") - will now work fine with no crashing at all BTT("x+y+z") - will now crash on every run etc. My questions are:
Software Version: 2.1.14181 (2018 10 16) Hardware Version: D CAS Version 1.4.9 Operating System V2.060.650 RE: New Prime crashing - thenozone - 08-21-2019 08:26 PM No expert but would suggest you save your program to PC and upload as an attachment and some one is more likely to be able to assist you that way. |
