Plot equation in Home view (e.g Function plot) using result from CAS view - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Plot equation in Home view (e.g Function plot) using result from CAS view (/thread-13299.html) |
Plot equation in Home view (e.g Function plot) using result from CAS view - teerasak - 07-19-2019 07:37 AM In many cases, I have got analysis result in CAS view with x (lower-case x) as a variable. I then need to draw the graph of this equation in Home view. However, in Home view, it accepts X (upper-case x) as a variable. What I'm doing is to change from x to X manually. Is there any better way to allow me to have result from CAS to plot in Home view directly without manually changing it. RE: Plot equation in Home view (e.g Function plot) using result from CAS view - toshk - 07-19-2019 02:11 PM Make sure you are on Function App. On cas screen type F1(x):=your cas equation Or Just use cas function. plotfunc() RE: Plot equation in Home view (e.g Function plot) using result from CAS view - Han - 07-19-2019 02:13 PM (07-19-2019 07:37 AM)teerasak Wrote: In many cases, I have got analysis result in CAS view with x (lower-case x) as a variable. I then need to draw the graph of this equation in Home view. However, in Home view, it accepts X (upper-case x) as a variable. What I'm doing is to change from x to X manually. F0 through F9 are the global variables for functions to be plotted. You can use these within the CAS environment and define, for example, F1 to be a function to plot. In CAS view, functions take the form similar to: (x)->(x^2+2*x-3). So you can do something like: F1:=x->x^2-4; Notice that the calculator will automatically convert to upper case and return: (X)->(X^2-4). Since the variables of functions are just placeholders, you could really use whatever variable you want. However, the system variables F0 through F9 only accept X as their placeholder variable (hence the auto-conversion). Here's a short example of how you can use this in your calculations: g1:=x^3-4*x^2+2*x-1; g2:=diff(g1,x); F1:=unapply(g2,x); In this example, diff() computes the derivative, and unapply() turns the expression (in this case, g2) into a function whose placeholder variable is 'x'. Since we are saving the result into F1, it will auto-convert for us. RE: Plot equation in Home view (e.g Function plot) using result from CAS view - victorvbc - 07-19-2019 09:38 PM (07-19-2019 02:13 PM)Han Wrote:(07-19-2019 07:37 AM)teerasak Wrote: In many cases, I have got analysis result in CAS view with x (lower-case x) as a variable. I then need to draw the graph of this equation in Home view. However, in Home view, it accepts X (upper-case x) as a variable. What I'm doing is to change from x to X manually. Hello, I was making a script for my control systems class and needed to plot some resulting expressions in the function app using "F1:=...". It works perfectly from the CAS environment, but doing it in a #cas function simply attributes the name of the variable that contained the expression to F1 in my case. An example: Code:
Am I doing something wrong? RE: Plot equation in Home view (e.g Function plot) using result from CAS view - toshk - 07-20-2019 12:25 AM Try this; #cas test(myPoly):= BEGIN L0:=myPoly //myPoly pass straight up to my Poly2symb cause your error; but saving it to L0 forces it to list STARTAPP(Function); //F1 is not only reserved Var for Function App but also Spreadsheet F1:=unapply(poly2symb(L0,x),x); RETURN F1(x); END; #end Also Function App can straight up take some built in function: F1 type in poly2symb({1,2,3},X) RE: Plot equation in Home view (e.g Function plot) using result from CAS view - teerasak - 07-21-2019 03:27 PM Thank you all for your help. That works! |
