HP-41 - Memory modules - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-41 - Memory modules (/thread-12758.html) Pages: 1 2 |
RE: HP-41 - Memory modules - Sylvain Cote - 04-21-2019 03:48 PM (04-21-2019 03:31 PM)rprosperi Wrote:I will make pdf+txt files available, in the meantime you can click on the "View a Printable Version" at the bottom, do a copy/paste on the table and save it in a text file.(04-21-2019 01:52 PM)Sylvain Cote Wrote: FYI, This is the RAM memory map for the HP-41 related to the module and memory types RE: HP-41 - Memory modules - rprosperi - 04-21-2019 04:17 PM (04-21-2019 03:48 PM)Sylvain Cote Wrote: ... in the meantime you can click on the "View a Printable Version" at the bottom, do a copy/paste on the table and save it in a text file. You're right, it works perfectly, so don't bother adding files. I did not realize the separate quoted sections would disappear in the Print view, so your suggestion is perfect (also good for future use). Thanks! |
