HP 50g — import statistical data into hypothesis test - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 50g — import statistical data into hypothesis test (/thread-11900.html) Pages: 1 2 |
RE: HP 50g — import statistical data into hypothesis test - cdmackay - 12-08-2018 11:34 PM (12-08-2018 10:52 PM)DavidM Wrote: That's where the magic happens. The ST2 program is run, which outputs (in order) x1, x2, s1, s2, n1, n2. These values are then automatically inserted into their corresponding fields in the form. You are then free to enter whatever you like for α and "pooled?" to continue. oh! That is absolutely marvellous, thanks very much indeed yes, works perfectly. No need to reach for the Prime and its Import function any more thanks again, great stuff. Noted re caveats. RE: HP 50g — import statistical data into hypothesis test - cdmackay - 12-08-2018 11:47 PM (12-08-2018 10:52 PM)DavidM Wrote: - I have no idea if the dimensions of this sample ΣDAT are correct for this type of application Strictly speaking there is no need for the sample sizes to be the same for a Student's t-test, I think, but if you had different sizes samples you'd not be able to deal with them together in ΣDAT, anyway (e.g. the MTWR will insert a 0 for an empty element), so in that case you'd have to do it entirely differently. In my case, the samples are generally the same size, so your method works perfectly, thanks again. |
