How to convert units Using HP Prime - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: How to convert units Using HP Prime (/thread-11646.html) |
How to convert units Using HP Prime - hp48g - 10-24-2018 01:28 PM I will like to know how to convert units using the the HP Prime, the same way like the hp 48 g+ or hp 50g calculator? Can any one help me? I want to convert units with my prime like this RE: How to convert units Using HP Prime - john gustaf stebbins - 10-26-2018 04:32 AM You will have to use the CONVERT command. Not as slick as the 50g, but with the touch screen I've found it works well, since it is easy to edit previous commands. -jgs RE: How to convert units Using HP Prime - Giancarlo - 10-26-2018 05:18 AM Hello, I also suggest you to use the UNIT48 application for the Prime which mimic the Hp48 menu system. It is not made by HP but it is very well done. It is stored into the Hp Prime software in this forum. I hope it helps, Giancarlo RE: How to convert units Using HP Prime - Didier Lachieze - 10-26-2018 06:16 AM (10-26-2018 05:18 AM)Giancarlo Wrote: It is stored into the Hp Prime software in this forum. Here is a direct link: Units48 RE: How to convert units Using HP Prime - cyrille de brébisson - 10-26-2018 06:22 AM Hello, The sto "arrow" (shown as |> here) is a shortcut to convert: 12(_m) |> _cm Will convert from meter to cm... Cyrille RE: How to convert units Using HP Prime - cdmackay - 10-26-2018 06:31 PM (10-26-2018 06:22 AM)cyrille de brébisson Wrote: Hello, That doesn't work for me; I think it needs to be: 12_(m) |> _cm edit: nice to see that entering n_ automatically adds the () RE: How to convert units Using HP Prime - cdmackay - 10-26-2018 06:47 PM I have to add, I think the native menu-based way is pretty good, surely on a par with that on my 50g. • Enter number • press Units key • select from dimension and chosen unit • touch Sto▸ on screen (or key) • press Units key • select to dimension and chosen unit • Enter Another nice touch is that it builds up the shortcut for you as you type, which you can remember for non-menu key use, and then finally converts to the full CONVERT() form on Enter, e.g. for programming. RE: How to convert units Using HP Prime - NetMage - 10-28-2018 03:19 AM (10-26-2018 06:47 PM)cdmackay Wrote: I have to add, I think the native menu-based way is pretty good, surely on a par with that on my 50g. I think it is terrible compare to the 48g-50g series. Ignoring handling complicated units or unit math, consider: Enter number Press right shift+Units Select unit type Press unit Press left shift+new unit I count 11 keystrokes on the Prime versus 6 on the 50g counting touching the screen as one keystroke (which isn’t entirely fair) and of course the comparison is much worse if you then want to convert to another unit. Is there a similar shortcut to STO> in RPN Enty mode on the Prime? RE: How to convert units Using HP Prime - CyberAngel - 10-28-2018 04:06 AM (10-28-2018 03:19 AM)NetMage Wrote:(10-26-2018 06:47 PM)cdmackay Wrote: I have to add, I think the native menu-based way is pretty good, surely on a par with that on my 50g. Splendid idea! - Now something more...how to implement it? HP calculatrice team should introduce soft menu keys MENU CUSTOM 'CST' borrowed from the old 48-series would fit the new touch screen perfectly! "Just" Introduce [Shift] hold feature: There is already the [Menu] key there - use [Shift] & hold [Shift] & hold [Units] is ready for a soft menu approach! [Shift] & [View] could view the next page of menus and don't forget the [Help]-system update ________________________________________ MENU used to work on one row only = a list with this calculator one has already the six soft keys here and there. Several lists inside the list would help to build a custom menu MATRIX Yes! A screen filled with soft menus in a touch screen: 10 rows of keys! What do you think, Cyrille? A week or two? Easy as an Android 9? VPN PS: if you would rather have a secondary ordinary Shift NOW : [Shift] = shift on, 2nd [Shift] = shift off FUTURE:[Shift] = shift on, 2nd [Shift] = 2nd shift on, 3rd [Shift] = shift off You need to code the annunciator in the top row with a new color (just don't use yellow) RE: How to convert units Using HP Prime - cdmackay - 10-28-2018 04:35 PM (10-28-2018 03:19 AM)NetMage Wrote: I think it is terrible compare to the 48g-50g series. Ignoring handling complicated units or unit math, consider: True (although I make that 7, not 6), but you also need to add a few more if your chosen unit type and unit aren't in the first "page" displayed, which case the Prime handles a little better, with the larger screen estate available. I'm also perhaps not familiar enough with 50g units to be used to it; I don't find the Prime method slower, cognitively or physically. Nice to have the Units48 app though, so you have the best of both worlds. RE: How to convert units Using HP Prime - NetMage - 12-21-2018 07:04 AM I’ll havbe to try that program. Why do you think the 50g has 7? RE: How to convert units Using HP Prime - cdmackay - 12-21-2018 06:24 PM (12-21-2018 07:04 AM)NetMage Wrote: I’ll havbe to try that program. Why do you think the 50g has 7? I think I might have been testing it with a unit that required a Nxt on the 50g, but no extra action on the Prime, since they're all in one list, albeit that would require a scroll. |
