Units48 v1.0: units the 48 way - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: Units48 v1.0: units the 48 way (/thread-11395.html) Pages: 1 2 |
RE: Units48 v1.0: units the 48 way - tcab - 06-02-2021 01:10 AM How do I move numbers from the Units48 app - to and from the normal Prime home view? If I'm using my Prime, in the middle of some calculations, and need to do some conversions on my interim results - how do I get those numbers into the app and back out when I'm done? In the App, I cannot even use Sto to store numbers into variables, and certainly referring to variables doesn't work either given the Alpha key has been taken over as a simulated [Left Shift] key. RE: Units48 v1.0: units the 48 way - Didier Lachieze - 06-02-2021 07:37 AM (06-02-2021 01:10 AM)tcab Wrote: How do I move numbers from the Units48 app - to and from the normal Prime home view? You can import/export to/from Units48, as mentioned in the first post of this thread the mechanism is explained in the Base48 documentation. In summary:
RE: Units48 v1.0: units the 48 way - tcab - 06-02-2021 11:31 PM Thanks for the clarification - I can get numbers in and out of the app now. In the app, the Menu button technique of getting the Home view value works reliably, the [Blue Shift][+] doesn't - not sure how to change "the app settings" to make that work. A note for others Code: 5 Enter (puts e.g. number 5 into Ans) I found I had to be careful when switching between screens - if you enter the app then immediately exit back to Home view, Ans will be altered to be the value of the last value on the stack in the app, as intended. To set Ans in Home view to the displayed value in your Home view again, you'll have to copy it and hit Enter. |
