stopwatch features on calculators - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: stopwatch features on calculators (/thread-11363.html) |
RE: stopwatch features on calculators - Jake Schwartz - 02-06-2019 09:06 PM (01-12-2019 01:27 AM)dbbotkin Wrote: I've been using (and programming) HP calculators since 1972, starting with the HP 70 business model. Since the HP-80 was introduced on February 1, 1973 and the HP-70 was introduced on August 1, 1974, which machine would you have been using in 1972? Just askin'.... Thanks, Jake RE: stopwatch features on calculators - pier4r - 10-06-2019 07:15 PM Little update to say that the 50g has run for thousand of hours as timer / stopwatch (weighted with value). I think I never let it run for so long for anything else (as the stopwatch on a 50g is a busy wait, there are no easy interrupts) RE: stopwatch features on calculators - PANAMATIK - 10-08-2019 06:38 AM I think we should also add to the list: The HP-01 calculator has a stopwatch. Also the "new ACT" HP-21E, HP-22E, HP-25E, HP-27E, HP-29E, HP-67E .... and the "Woodstock Low Power". Bernhard |
